clanking when shifting
#51
I'm probably used to the belt drive on my previous bike. The shifts can be a little noisy, but i doubt it's from the transmission engaging gears. I'm thinking I'm just not used to hearing the chain move around during less than ideal shifts. Does that make a noticeable difference in smoothness? My last chain drive bike was years ago. Kawasaki kz1000p. It was my first bike.
Folks, the bike's shift changer has to be moved through the NEUTRAL position going from first to second. There is an extra layer of mechanical complexity there. You are in effect shifting into neutral and then into second. It sounds more brutal than the other shifts because it is, there's more going on. Got to give any bike a firm boot from 1-2, unless it's one of those race-type bikes where neutral is all the way down or up (depending on if the bike is GP shift or standard).
That would be N-1-2-3-4-5-6 instead of 1-N-2-3-4-5-6.
The "N" is the cause of your big clunk. Just ride it.
Also I have always felt that first gear was only good to get the bike moving. Get out of it ASAFP (As Soon As Finely Possible) and into second for better control and less driveline lash.
I can hear noise going into 3rd and such sometimes, I'm pretty sure it's just me not being 100% smooth on the shift. I've only put 2000 miles on the bike. Maybe I'm just not quite used to it yet. Much different character than my previous one.
(11-09-2016, 03:32 AM)ryanschillinger_imp Wrote: I can hear noise going into 3rd and such sometimes, I'm pretty sure it's just me not being 100% smooth on the shift. I've only put 2000 miles on the bike. Maybe I'm just not quite used to it yet. Much different character than my previous one.
Takes about 10K miles for everything to break in. More, really.
  Shifting issue Cormanus 31 2,176 05-15-2024, 12:59 AM
  Smooth shifting DougsZ28_imp 16 1,333 07-09-2021, 07:32 AM
  No clutch shifting Mixagon_imp 26 1,708 06-21-2021, 10:35 AM
Last Post: cj599_imp
  Trouble shifting CB1100AZ_imp 27 1,873 03-01-2021, 08:25 AM
  Chain making clanking grinding sound. bflint 36 2,622 11-09-2020, 05:04 AM
Last Post: LakeWylieJoe_imp
  I have two challenges... shifting down and checking the oil level Inhouse Bob 15 1,146 02-11-2019, 01:55 PM
  I fixed my clunky-shifting transmission dave 11 1,282 11-20-2017, 05:22 AM
Last Post: SportsterDoc
  Bike stalls shifting into 1st gwallis_imp 19 1,197 11-07-2016, 04:10 AM
Last Post: kennyw
  Trouble With Shifting From 1st to 2nd & 2nd to 1st goldeneye_imp 14 853 09-26-2015, 05:31 AM
Last Post: wiredgeorge_imp
  Very clunky shifting kDiqq_imp 39 2,460 04-26-2015, 10:42 AM
Last Post: Zappertomm_imp
