Front sprocket bolt cant be moved
#51
(03-13-2023, 06:29 AM)peterbaron_imp Wrote: me too, worn at 30K miles...???Confused
Not a lot of mileage.
Here are my sprockets after about 41K miles[/u]...and the main reason I replaced both was kinking chain at few spots, so did everything at one shot.
Sprockets and chain received average service, often 4K miles without any service intervals.
[Image: 896dd02ada02a1d4c899024f765da952.jpg]
[Image: 767679796778d0c289f3d9090609665c.jpg]
Mine at 36K miles still looked good. I replaced all the parts since I had already bought them. On my NC I replaced the 520 chain at 23,000 and used the same sprockets. My chain gets the same kind of service. Rarely adjusted between tire changes. Lubed occasionally when it looks dry or after I get caught in a lot of rain.
My chains have never stretched even halfway to replacement in the past 25 years. Sprockets have never needed changing.
I imagine if one is an aggressive rider, off-roader, or terrible at shifting gears, then yes: Chain, sprockets and tires would be often replaced.
Nothing lasts forever, well except infinity...
(03-13-2023, 10:16 AM)GoldOxide_imp Wrote: My chains have never stretched even halfway to replacement in the past 25 years. Sprockets have never needed changing.
Yyyep
For my part the aggressive riding managed to eventually kink up the chain a bit which made it worse, but most of the wear was already done by then. Hard acceleration. Higher revs, Lots of engine brake.
  Chain and Sprocket Options? Yata-Garasu_imp 22 2,039 12-23-2024, 04:47 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,252 07-30-2024, 10:05 AM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,211 11-29-2022, 07:49 AM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 986 01-03-2022, 08:30 AM
  How To :19 tooth front, and now, a 37 tooth rear sprocket on 2013 pekingduck 60 4,117 03-07-2021, 09:32 PM
  Fork Tube hex head bolt tool fitment ? bflint 8 707 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
  Oil Leak - Just got work done and then moved. NickyV_imp 34 2,314 10-15-2020, 02:13 PM
Last Post: max
  Another chain and sprocket question bflint 20 1,517 10-13-2020, 01:00 PM
Last Post: tod.branko_imp
  Alloy Sprocket woes Ninemeister_imp 22 1,705 09-24-2020, 09:23 AM
Last Post: Ninemeister_imp
  Engine mount bolt torque value TCinNC_imp 43 2,662 07-31-2020, 05:00 PM
Last Post: treedoc_imp
