Tire Options for our CB1100
(04-14-2024, 07:09 AM)Yata-Garasu_imp Wrote:
(04-14-2024, 02:19 AM)mvk24_imp Wrote: I saw another post that the kenda cruiser in our rear size is on sale. (I actually LOVED the handling of the kenda cruisers on my Xj600 secas).
When I check on my bike in the garage it seems I have developed a really slow leak. I have to top it off like every 3 weeks.
Can't find a puncture anywhere and I have changed the valve core.
Thinking about grabbing the kenda to throw on the rear but I'm not huge on having a Metzler on the front and Kenda on the rear since I've always changed at the same time and matched the tire models. (no front tire in our size from kenda AFAIK).
Any feedback on issues or not running different tire models? Hoping I can start riding again soon I'd be taking it easy for a while anyways.
I really wanted to go up a size on the rear but its hard to argue with a $100 tire for the rear right now.
I just noticed this part of your post. I haven't actually measured them, but the calibrated eyeball says the K671 rear tire puts nearly an inch more tread on the ground compared to the Bridgestone BT54. The BT54 is more rounded, like a sportbike tire, while the K671 is flatter, which makes sense since it's a crusing tire.
I suspect the difference in "turning in" is most likely because of the flatter, wider contact patch on the Kenda.
If you were thinking about going with a 160 on the back for more contact, the Kenda K671 might actually do what you want but with the 140 width profile.
If you were thinking about going with a 160 on the back for more contact, the Kenda K671 might actually do what you want but with the 140 width profile. O wow okay awesome. Thanks for that information I never would have known that.
(04-15-2024, 01:13 AM)m in sc_imp Wrote: I'm all for modifying stuff, but a larger tire will usually result in less contact area where it actually counts by it being 'pinched' in on the rim moreso than a 'stock' size designated for that rim width. want to run wider tires? get a wider rim.
Normally I'd agree but it seems pretty common around here to run the 160 on the rear with nobody really noticing any difference as far as I've seen at least.
I havent taken the cb on a track in years.
The rear rim will technically accommodate a 160 tire, unlike the front one. It will take 120 in the front but its rim is out of spec/ too thin for a 120.
My 2013 had PR3, 120/160
My present 2014 std has 110/160 and my DLX has 110/140 combination.
The time is nigh for me to get a new rear tire. The limited options have me leaning toward one of the 160 choices I see from others, and my mix of interstate commuting and backroad curves make me want a dual-compound tire.
That brings me to my question: Are y'all with the 160 rear tire still running them with a tube? I have the OEM spoked wheels with tubes, and I don't think I can put a tube inside a tubeless tire, especially when it's 20mm wider than OEM, and have normal performance from the tire. Feedback/thoughts/observations?
Our Canadian member, Alain Lee has converted his tube rims to tubeless, and if I recall correctly, he runs OEM sizes 110/140 tubeless tires on his mighty red 2017 EX with sophisticated plane like cockpit.
Biker
To follow up on what Peter said I believe there was a write up here on the forum on how to convert the spokes wheels to tubeless. It was a pretty simple process as far as I remember if you can get the tire off the rim.
I have the mag wheels so I'm tubeless from the factory.
For sure there were some write ups if not threads with some feedbacks from different members and countries using different materials/technics and kits.
(04-15-2024, 04:36 AM)peterbaron_imp Wrote: For sure there were some write ups if not threads with some feedbacks from different members and countries using different materials/technics and kits.
Thanks, all. I found a few threads that did not seem to be relevant judging by the names, but after this encouragement I started in-depth reading and found some posts linking to relevant threads. Looks like converting is my best way forward.
Thanks, all. I found a few threads that did not seem to be relevant judging by the names, but after this encouragement I started in-depth reading and found some posts linking to relevant threads. Looks like converting is my best way forward. Glad you found some info you needed. It i had spoked wheels i would be converting to tubeless as well.
Rather do a plug on the side of the road than patch a tube.
(04-15-2024, 03:33 AM)peterbaron_imp Wrote: Our Canadian member, Alain Lee has converted his tube rims to tubeless, and if I recall correctly, he runs OEM sizes 110/140 tubeless tires on his mighty red 2017 EX with sophisticated plane like cockpit.
Biker
Alain Lee and I run the Outex Kit (tubeless conversions) on both front and rear tires. I am going on three years now, Alain many more years and a few more day long treks. No problems to date.
  NGK spark plug options Jonnyteabag_imp 6 629 08-05-2026, 11:35 PM
Last Post: JRD
  Chain and Sprocket Options? Yata-Garasu_imp 22 2,023 12-23-2024, 04:47 AM
  Software options? josh mcelfresh_imp 2 373 08-09-2023, 03:46 AM
Last Post: josh mcelfresh_imp
   Oil Filter Options Yata-Garasu_imp 78 7,326 09-28-2022, 08:03 AM
Last Post: Yata-Garasu_imp
  Air filter options - W/ Part #'s PowerDubs_imp 10 906 09-21-2022, 04:02 AM
  Tires yet again - spoked wheel options Rogerdj_imp 12 954 09-05-2021, 04:56 PM
Last Post: Henrik_imp
  Cb1100 EX tire dilemma Cqrlm911_imp 20 1,554 06-19-2021, 11:21 PM
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 954 07-18-2018, 06:50 AM
Last Post: SportsterDoc
