connection to control unit with OBD
#41
Bflint, they had to SEND you an update? I update the software on-line.
Or did you somehow update the tool?
(12-05-2020, 02:27 AM)bflint_imp Wrote: Finally got my new HealTech OBD diagnostic tool working. HealTech had to send me a software update, but now I see pretty graphs and moving numbers. Now I have to spend some time figuring out what is all means Smile
Nice- what is it capable of showing you?
Awesome. Pics please for the Forum!
(12-05-2020, 02:36 AM)Lord Popgun_imp Wrote: Bflint, they had to SEND you an update? I update the software on-line.
They emailed me a fix/update of the computer software and I sent them back a short analysis recording from the fix/update. They confirmed that the fix/update seemed correct and to just use it until they published a new version on the web site. Do you want a copy now?
Ok, will try to hook up and figure out today Smile
No, but appreciate it. I don’t use mine much so will just wait on the update.
Here are HealTech OBD sample outputs from my 1st use. FULL DISCLOSURE here ... I have never used an OBD tool and am not a tech. I bought this tool for interest and to hedge my bets for future times when my ride has more years on it. FYI, it did show me a fault message that I have yet to research. Anyway, Attached are some pics and some pdf prints of the outputs.
PIC of the tool/computer setup.
PIC of tool hookup.
PIC of software screen with ignition on and engine off.
PIC of software screen with ignition on and engine off and some type of connection fault detection message.
PDF report with with ignition on and engine off.
[Image: da109fe53e09146c630ab9f9877bdc0f.gif] [url=attachment.php?aid=12695]obd.engineoff.pdf (Size: 333.07 KB / Downloads: 10)
MORE STUFF ON NEXT POST
SOME MORE OBD PDF REPORTS:
PDF Report with engine on and running in neutral.
[Image: dbc58b3996b3ec53e99edeafc13e3a23.gif] [url=attachment.php?aid=12696]obd.engineon.neutral.pdf (Size: 332.34 KB / Downloads: 14)
PDF Report with engine on and running in 2nd gear.
[Image: 545d771524e2ebde66b4331bfb7b381d.gif] [url=attachment.php?aid=12697]obd.engineon.2ndgear.pdf (Size: 332.91 KB / Downloads: 17)
PDF Report after running in 2nd gear for awhile then switched to neutral (before turning off).
[Image: 4e6ee50bec8329f04fe0b7fe2c908e9b.gif] [url=attachment.php?aid=12698]obd.engineon.neutral-2.pdf (Size: 333.55 KB / Downloads: 12)
"Open or short circuit in the TXD/RXD wire" ... is this still an issue?
That is referring to the serial transmit/receive wire pair. Maybe they are reversed? Or maybe they are mixed up with the ground or source pins.
If the TXD/RXD wires (in the OBD2 cable) have not been sorted out, any "readings" you may get will be meaningless.
Nice information, let me help decipher some of them ...
As per your data list, I am just wondering why the reading is the following:
Why the "ECT" (Engine Coolant Temperature) reading is displayed instead of the "EOT" (Engine Oil Temperature) which the CB1100 is using?
For the idling complaint issues:
Keep in mind for future reference that at regular idling speed with the Throttle position at 0 (Tp = 0):
at idling speed of 1121 RPM, the ECT of 253 deg.,IAT of 78 Deg., the IACV valve count is at 34 steps.
at idling speed of 1074 RPM, the ECT of 197 deg, IAT of 71 Deg., the IACV valve count is at 39 steps.
From your KOEO ((Key On, Engine Off) data I was wrong in one of my previous comments under a different blog, I did mentioned that with the KOEO the IACV reading should be at 125 steps - your picture that it is at 99 steps.
Also, can you post a graphic view (let's say 10 seconds) of some selected data instead of just line data? (selected data of Idle speed, ECT, IAT and IACV?
FYI, the "Graph" information is more helpful since it shows information during a selected time period instead of just that "one" instant.
To make it easier to understand, it is explained like this ... Graph information is like you are watching a full movie (with thousands of frames) compared to line data which is "looking" only at "one" specific frame. - I am not sure whether I explained myself properly.
The MAP information, is it possible to change from "PSIG" value to let's say Inch of mercury absolute?
Also, the ST and LT Fuel trim is at 1.0 which means that your engine is running at perfect stoichiometric - not too lean or not too rich - there is no ECM correction required.
I should buy that OBD2 adaptor for my CB to play with.
Regards
Alain
Nice work with samples Bflint
Very sure that Lord Popgun is going to carry post #46 under his seat, in case if his HealTech fails...while on the road , NARSe to him Smile
Beer
Don’t have to PB. I can just pull up this thread Big Grin
Alain, the software makes run files as long as you have space to store them. You can see the time at the top of the first data screen pic.
These files are saved on your PC and you can play them back anytime. There are also sample files to watch. I have baseline files I made during our idle speed problem investigation.
The file type is proprietary, but you can still watch files from other users. How? Well, you have to go to the Healtech web site and download and install the software (you don’t need the ODB tool) then someone can send you a run file and you have to put it in the proper directory and then you can run it.
You can actually hook the thing up, and go for a ride while it logs data.
  Another source for plug-in LED flasher unit. FLYTYM_imp 7 633 01-31-2022, 09:53 AM
  Cruise control DougsZ28_imp 12 944 07-27-2021, 05:14 PM
  McCruise Cruise Control cmc1891_imp 28 1,823 07-06-2021, 11:40 AM
Last Post: DougsZ28_imp
   Fuel line connection came undone and left me stranded! Riko_imp 33 3,619 12-04-2020, 12:29 PM
Last Post: 17-CB-002
  Indicator connection Chris Goldson_imp 4 377 04-21-2018, 07:09 PM
Last Post: Chris Goldson_imp
  left control wiring caddy425_imp 2 319 03-26-2018, 12:42 PM
Last Post: caddy425_imp
  Handlebar And Control Alignment Aka Tsubasa_imp 2 264 07-12-2017, 06:38 AM
  Idle Air Control Valve (IACV) dave 12 709 07-23-2016, 02:31 AM
Last Post: LongRanger_imp
   Oil Pressure Sending Unit Tap Ralph_imp 8 645 10-29-2015, 11:05 AM
Last Post: Ralph_imp
  "Headlight Unit" Replacement gmike_imp 2 254 09-04-2015, 12:42 PM
Last Post: gmike_imp
