Tire Options for our CB1100
(03-12-2023, 02:40 AM)j3gq_imp Wrote:
(03-12-2023, 02:23 AM)Pauley_imp Wrote: I recently switched from the Metzeler Z8 tires to the Bridgestone T32. Radials, stock sizes. A little grippier than the Z8s. I like them.
@Pauley, going from any old tire to any new tire will most likely make the new one (after run-in) "feel" grippier, don't you think ?
@Pauley, going from any old tire to any new tire will most likely make the new one (after run-in) "feel" grippier, don't you think ? My frame of reference is overall after "scrub in". The T32s are better performers. Just feel more confident with the grip.
Whats your riding habits like? Deep twisties? Hard cornering? Id have to look and see if the t32 comes in the oversized profiles of 120/70 and 160/60 because the stock sizes are too narrow for me. Id run out of contact patch and it would limit my lean angle significantly.
I do a lot of deep twisties with hard cornering and my tire wear patterns reflect that. One of my regular rides: from my house to the top of Mt Diablo a few times a week - 13 miles up from the park entrance and 13 miles down on a very twisty road.
Looks like the Bridgestone T32s come in 120 70 18 and 160 60 18 in addition to 110 80 18 and 140 70 18 stock. I prefer the stock tire profiles.
Interesting...the last time i rode on a 140 rear i felt very unsteady when reaching the point where my pegs might touch down, and as it turned out it looked like my contact patch was shrinking. That was one of the main reasons i jumped on the 160 tires when i found outi could do that. Sure enough even when throwing sparks i still have plenty of room on the tread.
Speaking of tires, I think availability is still rather limited, my search anyway. My 2014 needed new tires last year, ordered some a week ago through the local dealer.
He was able to find my 2nd choice of Bridgestones available. I went with the OEM size.
There may well be a better tire out there, but a fresh, adequate tire is better than an aged, worn tire.
Absolutely!
I'm running a 160 tire. Is the performance better? I don't know, I am doing it for looks. It certainly isn't worse though. The tire works great. My big change was going from the stock tires that were on the bike when I got it, to a Conti Road Attack CR (classic race) 2 tire. OMG, totally transformed the bike. I will never mount another tire! These are sticky and transform the handling. I know they probably not wear as well as my stock tires, but the improvement is worth it. I never scrub these out to the outside edge, and believe me I use ALL the handling this bike can manage (my feelers were ground-off long ago). BUT, the grip and performance of the tire is absolutely shocking compared to the stock kit.
(04-04-2023, 12:55 AM)skidmarkart_imp Wrote: I'm running a 160 tire. Is the performance better? I don't know, I am doing it for looks. It certainly isn't worse though. The tire works great. My big change was going from the stock tires that were on the bike when I got it, to a Conti Road Attack CR (classic race) 2 tire. OMG, totally transformed the bike. I will never mount another tire! These are sticky and transform the handling. I know they probably not wear as well as my stock tires, but the improvement is worth it. I never scrub these out to the outside edge, and believe me I use ALL the handling this bike can manage (my feelers were ground-off long ago). BUT, the grip and performance of the tire is absolutely shocking compared to the stock kit.
well yea, those stock bridgestone tires are basically cruiser tires. they're universally awful for any kind of spirited riding. you could have gotten literally anything else sport-touring oriented and it would have been a massive improvement.
I could run my 140 tires to the edge, no matter how hard I try can't do that with the 160. Comforting to know if I get too hot into a corner there is a margin for (my) error with the 160's.
Currently running Bridgestone Battlax T31’s, 110/80 on the front, 160/60 on the rear.
Today I got myself a pair of Bridgestone T32 sport touring tires on the glowing recommendation of a forum member. They'll get slapped on tomorrow to replace my balding Avon tires. The compound on the sides of the tire feel appropriately grippy to the touch and the profile is a bit less rounded over than the Avons and Michelin tires I've used before. They're still 120/70 and 160/60 though. I may have a little bit less contact to work with at extreme lean angles but maybe just enough to satisfy the admittedly meager maximum lean of the bike. I don't see a lot of thin runnels for water displacement though, which reminds me of some Dunlop tires I've ridden on....it may be a bad set to ride in the wet.
More to come
Can you provide tread depth, front and rear
  NGK spark plug options Jonnyteabag_imp 6 629 08-05-2026, 11:35 PM
Last Post: JRD
  Chain and Sprocket Options? Yata-Garasu_imp 22 2,012 12-23-2024, 04:47 AM
  Software options? josh mcelfresh_imp 2 371 08-09-2023, 03:46 AM
Last Post: josh mcelfresh_imp
   Oil Filter Options Yata-Garasu_imp 78 7,322 09-28-2022, 08:03 AM
Last Post: Yata-Garasu_imp
  Air filter options - W/ Part #'s PowerDubs_imp 10 905 09-21-2022, 04:02 AM
  Tires yet again - spoked wheel options Rogerdj_imp 12 953 09-05-2021, 04:56 PM
Last Post: Henrik_imp
  Cb1100 EX tire dilemma Cqrlm911_imp 20 1,553 06-19-2021, 11:21 PM
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 952 07-18-2018, 06:50 AM
Last Post: SportsterDoc
