Fork seal leak
#31
(02-28-2014, 08:31 AM)shdwghst457_imp Wrote: According to this page the CB1100 is plenty fast
https://en.wikipedia.org/wiki/List_of_fa...celeration
Although our bike hasn't been added to this page yet. We're at 3.3 seconds to 60 and 11.79 in the quarter mile!
It also tops out at 110 mph before the !/4 mi.
I've not had any trouble with the fork seals on my CB1100 but I used to have a Honda Shadow 1100 that had a very similar set of struts. I found that on the Shadow occasionally a bit of dirt or the remains of a particularly crusty bug would find it's way done into the seal. I would just pop the dust cover and take a .010 feeler gauge and slide it down between the strut and the seal and move it around gradually pulling it upwards. That would usually clean the seal lip out well enough to get things back to normal. Put over 100,000 miles on that bike and only had to change the seals once.
Yep. Motion Pro sells a thin piece of plastic (called a fork seal cleaner) for under $5 that does the same thing. It seems well worth it if it's only a bug or piece of grit that's causing the seepage. Certainly cheaper and less time consuming than doing a full seal replacement.
In the past I've seen a strip of camera negatives used for that. But I haven't seen camera film for 30 years.
(03-25-2014, 12:40 PM)Deanohh_imp Wrote: In the past I've seen a strip of camera negatives used for that. But I haven't seen camera film for 30 years.
I think I might have one lying about somewhere if you want to make me an offer. Big Grin
That's actually what I started using on my Shadow until a piece broke off and stayed down in the strut. I found the feeler gauge was much more durable.
Maybe a couple of fork gaiters could solve the problem.
Rolleyes
Adding a bit of classic look too.
Wink
(03-26-2014, 01:06 AM)Mad Max_imp Wrote: Maybe a couple of fork gaiters could solve the problem.
Rolleyes
Wink
Unfortunately that adds a new set of problems. They have a tendency to trap moisture and create corrosion.
Guy over on the UK board is having all of problems we are seeing at the same time on his bike, fin rot, rust and fork seal leak. he's done, trading it in on a BMW.
http://www.cb1100.co.uk/index.php/topic,328.0.html
There's a lot mentioned on there about attending to the headers with wire wool, which I assume is what we call steel wool. I hope y'all are using stainless steel wool because, depending on how agressively it is rubbed, the regular stuff will leave tiny particles of steel imbedded in the surface which WILL rust and cause an ugly stain.
  Slight Oil Leak DutchRutter 22 3,975 05-16-2025, 06:49 AM
  Oil Leak? bvictory_imp 0 216 06-14-2023, 07:05 AM
Last Post: bvictory_imp
  Just found a leak Gone in 60 20 1,403 06-17-2021, 10:18 AM
  slight oil leak Enzofour_imp 3 387 06-07-2021, 12:26 AM
Last Post: michael1954
  Oil Leak - Just got work done and then moved. NickyV_imp 34 2,467 10-15-2020, 02:13 PM
Last Post: max
  fork overhaul vs. fork replacement? misterprofessionality 20 1,814 09-20-2020, 07:13 PM
Last Post: DBM_imp
  Cylinder Head cover oil leak and valve clearance increase. zirconxi_imp 6 658 09-01-2020, 12:19 AM
  Oil leak from pulser cover? skatamutra_imp 4 442 06-14-2020, 07:17 PM
   Oil leak! Help me! steed_boy_imp 43 3,896 02-09-2019, 12:22 AM
  Clutch Cover Removal - How To Break Goo Seal ??? markT_imp 9 761 05-30-2018, 09:30 AM
Last Post: BayAreaRick_imp
