2013 Optional ABS VS 2014 Deluxe ABS
#31
Per Honda's US Web site, it states that the 2014 CB100 Deluxe module has "combined ABS".
The link is: http://powersports.honda.com/2014/cb1100/options.aspx
Excerpt from the web site:
Features & Options
•Timeless styling, modern technology
•1140cc DOHC PGM-FI engine
•Disc brakes, adjustable suspension
•Adds: Combined ABS, .5 gallon larger fuel tank, 4-2 Exhaust
So while the CB1100 is not a super sport model, it still looks like it has some type of "Electronically Controlled Combined ABS".
Read this thread and you will be glad that you don't have the (very expensive) C-ABS that the CBR1000RR has. When it works it is very good, but when it doesn't…
http://www.1000rr.net/forums/1000rr-gene...ssues.html
My first CBR1000RR had the C-ABS battery failure problem. Fortunately, it did not develop the other (more serious) problems. My second CBR1000RR I specifically bought without C-ABS due to the ongoing issues.
[Image: 7642e27e8ec43bdff57f7c257c84783b.gif]
Edit: The CB1100 ABS model uses one master modulator unit which is a hybrid of the two different systems in the diagram above. I haven't tested a CB1100 ABS model so I don't know if the front brakes can activate the rear brakes. If they do, then it is the fancier system. It should be easy to test for if someone is interested. Read this review to see how that system feels under use: http://www.ashonbikes.com/content/honda-c-abs
The M/C on the left fork is not a M/C it a anti dive device that activates with the rear brake petal. It keeps the front end from diving down during hard braking! No front suspension! I took mine apart drilled a hole in a nickel ( nickel acts as a spacer) now I have front suspension all the time. Sit on your bike push rear brake petal and push down on forks! Not sure about the ST but goldwing for sure. Over time it can blow out the left fork seal.
The Go.dwing and ST both have a secondary master cylinder bolted to the left front fork leg. The suspension working is what pivots the linkage and applies the linked rear brake when the front brake is applied. There have been 2 recalls on the SMC (secondary master cylinder) on the Goldwings, but no such recall for the ST even though owners have had issues with them. The SMC for the ST was re- designed in 08 I believe.
The CB has no SMC and uses a completely different system than the Goldwing or the ST 1300.
Honda's Supersport bikes like the CBR1000R use yet another ABS system.
Ferret on the ST boards the re-designed SMC appears to be just a change to the water drainage hole shape to help keep it from clogging up.
Mike, so where exactly did you put the drilled nickel? I looked at the parts list to see the parts you are talking about and am curious.
Yes but unfortunately thee are still guys having issues with the " new " units.
We don't have that system on the CB 1100's thankfully.
Popgun on a goldwing on the left side mounted to the left fork is a cylinder that that locks up the left fork leg when the rear brake pedal is applied. Take the top half off just 2 bolts and drill a nickel in the center and bolt back together with same bolts. They sell a kit on ebay but for 5 cents it works great. I'm not sure about the ST. On a goldwing its called a anti dive. And when it works it rides like crap no front suspension at all.
Ridem,
Ok, I see now. I thought you meant the CB ABS and was looking at that part diagram.
I read some on the Goldwing boards about this to see how it worked and I see how the nickel trick works. It appears that it is the cheapest(cost 5 cents!) and best way to take care of your problem.
I've found the specs on the Honda website to not always be accurate. For example, it states the exhaust on the '04 CB50R is a "single expansion chamber." This is true for the two-stroke NSR50, but not for the four-stroke CB50R. The bike actually has a dual headpipe, dual exhaust setup (single cylinder, 4-valve head, one headpipe and one exhaust pipe per valve). So the website claim that the '14 DLX has combined ABS might simply be an error or oversight as well.
  2014 Deluxe, 65K miles spruce up. bflint 6 724 08-14-2025, 07:37 PM
  Can a 2013 centerstand be installed on a 2014? WRXer_imp 1 269 11-19-2023, 04:24 AM
Last Post: WRXer_imp
  2013 versus 2014 wheel size Houtman_imp 19 1,611 10-08-2021, 05:11 AM
  2014 CB1100 Deluxe No front brakes Roger the shrubber_imp 16 1,064 08-05-2021, 02:01 AM
  Two Brothers M2 - 2013 specific on a 2014? B Api_imp 1 249 06-14-2021, 11:57 PM
Last Post: cj599_imp
  Adreani inserts for 2013/2014 ? Houtman_imp 20 1,403 05-05-2021, 04:59 PM
  Does a 2014 have an optional power source? FLYTYM_imp 4 370 09-23-2019, 01:10 AM
   Deluxe seat on 2014 Standard FLYTYM_imp 4 864 06-04-2019, 07:54 PM
Last Post: FLYTYM_imp
  2013/2014 switchgear spartanheed_imp 2 290 04-23-2019, 04:23 AM
Last Post: spartanheed_imp
  Weight of the OEM Wheels on the 2013/2014 std models? misterprofessionality 7 553 04-04-2019, 09:24 PM
