2014 Deluxe, 65K miles spruce up.
I am toward the end of a 2 month retina eye surgery recovery during which time I decide to do a valve adjustment and refinish all the aluminum engine covers ... plus various other mech/electrical stuff. I did a spruce up of my front forks and adjusted my valves about 5 years ago so thought why not use some of the past experience to do the engine covers since they were showing some clear coat scaling (plus some road rock nicks).  Here's a summary of what I did.  Removed all covers.and cleaned everything with Simple Green Pro (it doesn't harm surfaces like others). Setup strip/paint station on a 2'x4' flat metal oil drip pan on saw horses .Used stripper to get as much of old clear coat off ... used 3m purple pad to aggresively go after hard stuf while stripper was still on.  Tried using a bench buffer (bench sander with buffing/polishing add on plus the various polish grit clay sticks that come with the polishing pads ... had some some success, but that clay grit seems to become adhered in soft alum finish and caused me to spend to much time trying to remediate the darn clay grit issue.   Utimately I just when with wet/dry (400 thru 2000) hand sanding then buffed/polished with bench buffer and Mothers Alum Polish.   Last prep set was to wash all with Simple Green Pro then wipe down with an automotive paint "pre-clean" that is some combo of alcohol and a few "enes'.  Setup each piece seperately at paint station and blew off with dry rag and air.  Painted 3 coats (5 min between each coat) of the SprayMax 2k Clear ... this stuff runs very easily so have to be careful about first coat.  I have attached some pics of everything I mentioned here.
Pic of original clearcoat condition.
Rest of pics.
Attached Files Thumbnail(s)
Bflint, great and professional work!!
Weren't you the one who already did the front forks a long while ago??
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
(08-09-2025, 04:07 AM)peterbaron Wrote: Bflint, great and professional work!!
Yes ... may do again when I do fork seals, but pretty good looking still.
I have most of the covers from the DLX I am restoring but never dreamed you could make them look new. I just bought new ones and still have the old ones. I may try this on them since even if I mess up, I still have new covers on the bike already.
http://cb1100forum.com/forum/showthread....#pid281093   Thumbs Up Thumbs Up
            *Grand Chancellor*
Here is the finished product:
Flawless. Nothing like a perfect DLX.
  2014 CB1100 Deluxe No front brakes Roger the shrubber_imp 16 1,019 08-05-2021, 02:01 AM
   Deluxe seat on 2014 Standard FLYTYM_imp 4 849 06-04-2019, 07:54 PM
Last Post: FLYTYM_imp
  Build your own 2014 CB1100 Deluxe LongRanger_imp 4 370 03-26-2017, 01:27 AM
Last Post: BestStandard_imp
  2013 Optional ABS VS 2014 Deluxe ABS the Ferret 38 2,141 09-04-2015, 03:40 PM
Last Post: LongRanger_imp
  Oil Change 2700 miles CIP57_imp 48 3,444 08-15-2014, 10:41 PM
Last Post: Pterodactyl_imp
  Which oil at low miles Tortuga_imp 29 2,427 04-26-2014, 10:12 AM
Last Post: flynrider
  How many miles will CB last? HikerToo_imp 33 2,138 04-24-2014, 05:28 AM
Last Post: Tortuga_imp
