oil filter cross threaded
#31
KN204 installs without cross threading.
However, a matter of very serious concern to me when I did my last oil change was the crush washer supplied by the dealer. The dealer was downright evasive when I asked if the washer, that outwardly seemed to be of the correct dimension (14mm), was fitted with an OEM hole. Rather than risk using an aftermarket hole I reinstalled the same crush washer that came with the new bike, some 70000kms ago. I felt that the hole on this washer would be OEM.
This whole hole matter has been an ongoing concern to me and is the reason that I chose an OEM rear rack rather than a Givi or other after market rack. The OEM rack is fitted with Honda holes thus ensuring a secure fit. So in the event of installing any after market accessories my strong recommendation is to insist that Honda holes are supplied with the item.
(05-05-2016, 01:37 AM)Pterodactyl_imp Wrote: KN204 installs without cross threading.
ROFLROFLROFL
(05-04-2016, 08:21 PM)TINK_imp Wrote: I'm still baffled as to how one manages to cross thread an oil filter?
I've changed hundreds of oil filters and never once managed to cross thread one.
I suspect the filter threads were not the Honda pitch and perhaps were for another bike brand.
I seem to remember my Suzuki's had a unique thread pitch.
They do indeed. They just wanted to make sure you get your filters from the authorized Suzuki dealer.
(05-04-2016, 10:23 AM)jjchowdy_imp Wrote:
(05-04-2016, 10:18 AM)The ferret_imp Wrote: You will have to jam two nuts together if you can get them started. The same for tightening up the new one.
unfortunately, if I could get the bolts on, I wouldn't have a problem. lol. It's apparent I'm not getting anything done tonight as it's getting dark. I think I'll look for the wife's Xanax and try to lower my blood pressure. I'm leaning towards the file/die solution because they don't appear to be too mangled. Admitting to my wife that I managed to screw up the bike she bought me the first time I tried to do anything to it will be another lesson in humility for me. Ugh. Thanks for all the replies guys.
JJ, Don't beat yourself up, we've all done things we wish we had not done on our machines. I won't tell you about the time I was winterizing my sailboat's diesel engine and I left the water intake hose in a bucket up high in the cockpit. Took a break for lunch and came back to find water had siphoned into the cylinders and was pouring out the air intake. Well I guess I just told you about it.
JJ. That's good advice from Sailor. If I had a dollar for every one of my cross-threads I would fly over and give you a hand to fix the issue. Just do what the corporate boys do and "Drill down to the root causes, take the learnings from this so, going forward, you can build on these to ensure more positive outcomes from your oil and filter changes".
Cheers and good luck with it.
Done that a few times, if the washer ain't crushed too much, crush it again.
On my track bike, I use a safety-wired drain plug which is another level of safety.
I will tell y'all one darn thing that I am OC-effin-D about.
Cross-threading.
I back off every single bolt or nut I install the opposite direction until I feel it "click" into the threads, and then I carefully, carefully begin to tighten it. Applies equally to valve stem caps, body panel fasteners, and spark plugs. You cross-thread a spark plug, or a cylinder head bolt...wow. I do the same with oil filters and while it sometimes drives me nuts because it takes several tries, I never worry about getting it cross-threaded.
I over torqued a spark plug when I was 10 years old...hasn't happened since on any bolt. I learned early.
I've decided my OEM Honda designed engine is not good enough for me. I know what is better for Honda motorcycles. Those idiot Honda engineers are fools. I'm replacing the four with an S&S V twin. It is a turnkey install except the bolts are different. Those S&S motors can use 5w50 oils which I know to be the best for riding on cool nights. I think I saw that spec in a Honda workshop manual for 2008 and earlier bikes, should still be good.
(05-06-2016, 04:55 AM)Toddman_imp Wrote: I over torqued a spark plug when I was 10 years old...hasn't happened since on any bolt. I learned early.
You have been making far too much sense lately. Always one dude on every forum seems to see things my way lol.
Just a suggestion. I recall Griots Garage catalogue online use to list a bolt thread chaser tool which might be ideal for this type of situation. I agree, replacing the filter mounting stud on the engine block is likely your best choice. If you can successfully chase the threads with the correct tool, you should be back in business. Good luck with it.
(05-07-2016, 12:32 AM)SUPERCRUZ_imp Wrote: Just a suggestion. I recall Griots Garage catalogue online use to list a bolt thread chaser tool which might be ideal for this type of situation. I agree, replacing the filter mounting stud on the engine block is likely your best choice. If you can successfully chase the threads with the correct tool, you should be back in business. Good luck with it.
The tool will cost more than the stud will.
  Oil Filter dave 12 542 07-26-2026, 02:33 PM
  frame gusset threaded hole question tdbru 0 219 10-27-2024, 11:27 AM
Last Post: tdbru
  Pod Air Filter Traumend_imp 15 1,459 03-06-2024, 08:42 AM
  K&N air filter fitment question nikolus_imp 28 3,445 05-20-2023, 09:26 AM
Last Post: Klamathonian_imp
  Fuel filter replacement Mafd2_imp 36 2,825 02-11-2023, 01:54 AM
  Oil filter won’t come off Jgarciajr40_imp 20 1,468 01-01-2023, 09:38 AM
   Oil Filter Options Yata-Garasu_imp 78 7,290 09-28-2022, 08:03 AM
Last Post: Yata-Garasu_imp
  Air filter options - W/ Part #'s PowerDubs_imp 10 900 09-21-2022, 04:02 AM
  Video: oil and filter change Scotty_imp 15 1,165 12-05-2021, 02:43 AM
  Air Filter Change Interval? dave 25 1,867 11-09-2021, 02:18 AM
Last Post: SportsterDoc
