clanking when shifting
#31
(04-30-2014, 08:32 AM)dBuster_imp Wrote:
(04-30-2014, 07:40 AM)AzBob_imp Wrote:
(04-28-2014, 10:18 AM)dBuster_imp Wrote: Shifting from first to second at 3000 rpms? Now I wish the weather wasn't so rainy as I think I shift well before that... Maybe that could be why so clunky a shift, a high rpm shift?
I could be wrong though.. Hard to tell when you are rained out...
Sent from my XT1055 using Tapatalk
3000 rpm isn't a high rpm shift at all. It's not even half-way. The redline is 8500rpm. It's not a car.
Has anyone noticed, when clutch-less up-shifting, that the gear shifter will hang, and you can't up shift again unless you put reverse load on the transmission (i.e. get off the gas)? Mine does this often enough to be annoying. I forget if it does it during high-rpm shifts, or just randomly, but I'm thinking the former.
I was not saying that it was a high shift by far as I have shifted at 4000 rpm's myself. As it also doesn't say that you have to wait until you get near or to redline to shift either. We all shift at different points.
But normally I don't think I break 3000 rpms when I shift when driving in the city. If anything I just barely get to 3000 then I am already shifted.
Like I said though, need some dry weather to get out and check out how I shift and at what RPM I am shifting at. This 5th day straight of rain is for the birds. The second wettest April on record if we have not broke it with todays rainfall.
guess it is time for me to leave this shifting thread alone and go back to the oil threads. Personally my bike is not a clunky or noisy shifter at any RPM or speed. It does have the typical Neutral to 1st clunk or noise but that is all. I think I hear the 30 weight oil debate calling. this thread is getting above my head.
Just wait for some dry weather, get out and give it the beans.
Mine's done 575 miles. Yesterday I redlined it trying to get away from a tailgating git driving a Works Mini Cooper S.
Some motorcycles are not designed for clutch less shifting. Maybe this is one of them.
I have given it the beans but no where near redline. Don't have plans on pushing to redline as the bike for me pulls away without needing to redline. I am over 1000 miles on my bike. I just don't see the point in trying to ride to the redline.
Like I said back to the oil threads I go..
No point unless you're in the mood to accelerate as quickly as possible. Even then, dyno charts show power peaking at around 7300 rpm, so there's no point in going much beyond that.
Interesting post! When I first got my 1976 CB750 I complained to the dealer about clunky shifting and they told me I just didn't know how to ride it correctly yet. For the most part, they were correct, it/I got better.
The only motorcycle I have ever shifted without clutching was my motocross yz125, mainly because I so busy "hanging on" to it I needed all my fingers for the handle bar!
I'm been experimenting with RPM range, accelerating, peaking, de-accelerating looking for the smoothest shift. I've hit it a few times, even 1st to 2nd, making me think it's me, not the motorcycle. When I get it perfected (400mi on 2014std) I'll post my results.
The whole reason I bought this motorcycle was for the shifting! Now if I can just get some exhaust noise out of it I'll be set!
My old Quota could teach you guys about a clunky tranny. Very tractor like with good clunks up and down the range. Nature of the beast.
Okay things have dried up.. regarding shifting near 3000 rpm's... my normal riding I shift between 2200 and 2800 tops. I did for the sake of testing, pushed it a few times upwards of 4000 rpm's but would not shift that high normally.
My gearbox in my opinion is not any noisier or clunkier shifting than anything else I have ridden. I am going to bow out of this conversation...
I find the other bike comparisons with the CB to provide the most information. Comparing the CB1100 with the Honda 919 (2006) and Suzuki SV650 (2000), the CB "[url=http://cb1100forum.com/forum/showthread.php?tid=1032&highlight=clunk]clunks" in the lower gears more than the others. The 919 has the smoothest gearbox of the three and has no clank or clunk. Perhaps it's mileage - the CB is under a 1000 miles; the other bikes are in the 5000 mile range and broken in more. Perhaps its the CB's chain; will check and report after my next maintenance.
Okay well I now have almost 1000 miles on the bike so far. I have noticed that no matter what shifting from neutral to first is always a little clunky. I have taken it as just normal and don't worry about it anymore. I have also noticed that it is a lot more quite when shifting from first to second when it's a little cold.
So it is what it is.
It does noticeably clunk into first from neutral. I'm used to it now and it's almost reassuring in a way; if it stopped clunking I'd be worried!
  Shifting issue Cormanus 31 2,350 05-15-2024, 12:59 AM
  Smooth shifting DougsZ28_imp 16 1,396 07-09-2021, 07:32 AM
  No clutch shifting Mixagon_imp 26 1,735 06-21-2021, 10:35 AM
Last Post: cj599_imp
  Trouble shifting CB1100AZ_imp 27 1,946 03-01-2021, 08:25 AM
  Chain making clanking grinding sound. bflint 36 2,839 11-09-2020, 05:04 AM
Last Post: LakeWylieJoe_imp
  I have two challenges... shifting down and checking the oil level Inhouse Bob 15 1,213 02-11-2019, 01:55 PM
  I fixed my clunky-shifting transmission dave 11 1,310 11-20-2017, 05:22 AM
Last Post: SportsterDoc
  Bike stalls shifting into 1st gwallis_imp 19 1,240 11-07-2016, 04:10 AM
Last Post: kennyw
  Trouble With Shifting From 1st to 2nd & 2nd to 1st goldeneye_imp 14 904 09-26-2015, 05:31 AM
Last Post: wiredgeorge_imp
  Very clunky shifting kDiqq_imp 39 2,618 04-26-2015, 10:42 AM
Last Post: Zappertomm_imp
