Threads: 347
Likes Received: 863 in 473 posts
Likes Given: 994
I'm with you on the baby side of the equation MrP. Many people on this forum are both amazingly knowledgeable and incredibly helpful.
Have a spare fuse or two on hand, I guess.
BTW, what's the spare plug from the indicator?
Threads: 126
Likes Given: 1
as if i would even know what fuses go to what...
the leftover wire is a black wire with a white stripe. i've been led to believe that this is a wire for a running light. i think it connects when you connect the front end signals, but it's useless on the rear signals. anybody can feel free to correct me on that.
Threads: 125
Do you have a service manual?
Threads: 126
Likes Given: 1
god no. the only reason i'm messing with this stuff is it's something i couldn't possibly mess up enough to cause permanent damage. i won't start working on a bike in any real meaningful way until a few years from now when i buy my cadaver.
Threads: 125
....would be helpful for things like which color wire does what, where the fuses go, etc.
Threads: 347
Likes Given: 994
There's a link to a colour picture of the wiring diagram somewhere on the forum.
Ah ...
https://imgur.com/IxWXkk3
Likes Received: 191 in 112 posts
Likes Given: 139
Cormanus, at one time that one was accidentally made with 2 different year models. Left and right sides don’t match. Unless it was corrected when we discovered it.
However, I now have full sheet high res scans I had made at the UPS store. PM me if you need one Mr. P. (I don’t have a ‘17 diagram)
Threads: 126
Likes Given: 1
(09-02-2018, 01:18 PM)PowerDubs_imp Wrote: ....would be helpful for things like which color wire does what, where the fuses go, etc. ![[Image: 2ebd4f492887350e5d139d24138dbac7.png]](https://cb1100forum.net/forum/uploads/imp/201809/2ebd4f492887350e5d139d24138dbac7.png)
as long as that information is available somewhere on the internet, it's hard to come to terms with paying for it.
big thanks Cormanus and Popgun! i'll study it (if i can make sense of it at all, no guarnatees!)
I have a significant update: the signals will not work at all. I connected my makeshift adapter to the wire harness and they signaled and blinked perfectly. However, once i began to take apart the front signals (which was an outrageously difficult thing to maneuver, let me tell you). it became clear that these signals are equiped with a mounting bolt that is about twice the necessary size. there's absolutely no way to bolt these in place of the original signals. basically, the website utterly lied to me about their compatibility. i'm processing a return now, but it seems i'm back to square one.
I do get to keep my nifty little connection adaptor/wire extensions, though, since I had the foresight to make those without altering the signals at all. Looks like i'm going to have to go back to shopping for different signals though.
Threads: 125
Pics? Some things take adaptation to make work and aren’t always plug and play.
Threads: 126
Likes Given: 1
oh, sorry dubs. i've already re-assembled everything. I can't leave my bike in pieces, it's my only ride.
If you've ever taken apart your signals, you might have seen what i mean, though. the signal mounts via one bolt, which takes an allen wrench, and the wire running independently through a different hole. the aftermarket signals used a 6 point nut and bolt, with the wire running through the threaded bolt. that threaded bolt is roughly double the size of the original bolt that mounts the OEM signals. I am not interested in drilling or otherwise permanently modifying the bike, so that pretty much means these signals are a bust, sadly.
edit: for reference, these are the signals I got:
https://www.amazon.com/gp/product/B01DJN...UTF8&psc=1
you can see the larger bolt coming out of them.
and these are a set of signals with a mounting setup that looks much closer to OEM (just guessing)
[url=https://www.amazon.com/dp/B01FU92JAY/ref=psdc_9002277011_t2_B01DJNK76Q]https://www.amazon.com/dp/B01FU92JAY/ref=psdc_9002277011_t2_B01DJNK76Q
