01-05-2021, 03:30 AM
Rust and Corrosion
01-05-2021, 07:58 AM
(01-05-2021, 03:26 AM)peterbaron_imp Wrote: I would never like to have a heated garage while using salty roads....it speeds up corrosion due to higher temps = catalyst You're abs. right, but the problem with this ? what do you do if your garage is heated by design or location (under your parlor). Park outside until end of winter ? Or fool around with a tooth brush between the cylinder fins before you open the garage door? My bike and me loooove hibernation
01-05-2021, 08:08 AM
(01-05-2021, 07:58 AM)j3gq_imp Wrote:(01-05-2021, 03:26 AM)peterbaron_imp Wrote: I would never like to have a heated garage while using salty roads....it speeds up corrosion due to higher temps = catalyst You're abs. right, but the problem with this ? what do you do if your garage is heated by design or location (under your parlor). Park outside until end of winter ? Or fool around with a tooth brush between the cylinder fins before you open the garage door? My bike and me loooove hibernation If I got into situation as described by you, I would make an appropriate parking decision that keeps my soul and mind in a satisfactory balance. Dont't split hairs, live is too short to create problems
01-05-2021, 08:09 AM
YOU are SOOO right
01-05-2021, 08:45 AM
(01-05-2021, 07:58 AM)j3gq_imp Wrote:(01-05-2021, 03:26 AM)peterbaron_imp Wrote: I would never like to have a heated garage while using salty roads....it speeds up corrosion due to higher temps = catalyst "heated by design"? - turn off/redirect the heat from the garage. In theory (a well designed house), if there is a room above the garage, it ought to be properly insulated from the garage. In addition, heat rises, so any heat in the garage will tend to permeate up. Fix those issues and your garage should settle closer to outside ambient temperature without the wind chill. You will still have humidity and dryness issues, depending on your region. When you need heat, disable redirection or turn on an electric heater. An electric heater actually dries the air. Anyway, I don't have a garage so the bikes get nice 'n' cold.
My parking situation has a big tool box, a TV and a coffee maker. And it's under my house, so if I am needed, my wife can stomp on the floor to let me know.
My mind and soul are very happy.
01-05-2021, 08:50 AM
01-05-2021, 01:57 PM
Dave, you are not alone in having rust issues with the CB1100. I don’t think some of the materials used are fit for purpose.
01-06-2021, 01:51 PM
(01-05-2021, 01:57 PM)Cormanus_imp Wrote: Dave, you are not alone in having rust issues with the CB1100. I don’t think some of the materials used are fit for purpose. Thank you Cormanus. Out of all the bikes I have owned NONE have exhibited rust like my CB1100. I still love this bike, and I still plan to NEVER sell it. I just have to pay extra close attention to keep it clean and rust free.
01-06-2021, 04:10 PM
(01-06-2021, 01:51 PM)Dave_imp Wrote:(01-05-2021, 01:57 PM)Cormanus_imp Wrote: Dave, you are not alone in having rust issues with the CB1100. I don’t think some of the materials used are fit for purpose. Dave, I have to admire your admiration for the CB1100; I mean, you went through quite a bit with the high/low idle issue and got that sorted out and you have the rust issue. Yet you seem to thoroughly enjoy the bike still. I'm happy for you in that regard. |
« Next Oldest | Next Newest »
| 17 header corrosion | Boynton6spd | 13 | 635 |
07-24-2026, 10:32 AM Last Post: dave |
| Rust on mudguards | Classico_imp | 15 | 1,053 |
07-11-2022, 06:22 AM Last Post: Classico_imp |
| Rust on tank from crash | calipo223_imp | 6 | 589 |
09-17-2020, 05:06 PM Last Post: jtopiso_imp |
| Rust | dave | 1 | 217 |
04-02-2016, 02:13 AM Last Post: Ghost_diver_imp |
| Corrosion On Shocks and ABS | sorrentino100_imp | 10 | 878 |
08-06-2015, 08:00 AM Last Post: Pterodactyl_imp |
| Rust on lower fork bracket | LiveToRide_imp | 134 | 9,994 |
05-12-2015, 05:23 AM Last Post: Elipten_imp |
| triple tree Rust (not the Fork Brace) | LiveToRide_imp | 16 | 917 |
12-21-2014, 12:36 PM Last Post: Pterodactyl_imp |
| Corrosion Control Recommendation | Red Mist_imp | 6 | 520 |
03-20-2014, 05:51 AM Last Post: The Spaceman_imp |
