triple tree Rust (not the Fork Brace)
About 6 months after buying my CB the fork brace started rusting. I'm in the Pacific northwest and it is a bit moist here and I'm by the ocean but the bike is kept in a dry shed. Honda replaced the brace and here it is about 9 months later and it's rusting just like the 1st one. I haven't been back to the dealer yet to see if they will do anything about it this time. I've started keeping a coat of WD40 on it hoping it will keep it from getting worse. Anyone else run into this issue?
LTR, I've had a similar problem. Haven't really come up with a solution.
Would you post a picture of it when you get a chance? I'm also in the Pacific Northwest and wondering what I should keep coated. thanks
LTR or me? You can just see some of the stuff on mine below the indicator in the second picture in [url=http://cb1100forum.com/forum/showthread.php?tid=4450&pid=66951#pid66951]this post.
There's also some under the triple tree.
If you want close ups, I'll see what I can do for you.
I see what you mean. thanks
I'm assuming you guys have had other bikes in the past. Has this happened to you before, maybe due to where you're located, or just with this bike?
My 1st new bike since I moved to this area but have had lost of bikes. Here are some pictures of the rust.
Way too small. I can't see anything from those.
That's not a fork brace. That's your factory triple tree.
I had those problems living right on the gulf. I spray all the those areas with Motul shine and go wipe off and have not had a problem. I know this works because the guy that loves around the block further from the water has the same rust and he does nothing to prevent it I guess you could use WD-40 as I used that 5 years ago and it worked fine.
  Rust on mudguards Classico_imp 15 1,184 07-11-2022, 06:22 AM
Last Post: Classico_imp
  Rust and Corrosion dave 71 5,148 02-26-2022, 02:22 PM
Last Post: hondadownunder_imp
  Rust on tank from crash calipo223_imp 6 634 09-17-2020, 05:06 PM
Last Post: jtopiso_imp
  New Triumph Triple Middleweight coming pekingduck 10 827 08-29-2020, 05:15 AM
Last Post: Bheezy27403_imp
  Triple Trouble Ack-CB11_imp 10 740 01-15-2019, 12:48 PM
  Tree fell on my garage curlyjoe 31 2,235 10-20-2018, 10:52 AM
  Rust dave 1 228 04-02-2016, 02:13 AM
Last Post: Ghost_diver_imp
  Rust on lower fork bracket LiveToRide_imp 134 10,684 05-12-2015, 05:23 AM
Last Post: Elipten_imp
  Rare triple CB1100 sighting in the wild willsmith_imp 22 1,485 06-12-2013, 02:19 AM
Last Post: willsmith_imp
