05-05-2021, 02:24 AM
Hi Gone, yes, you can re-use the rubber seal. More like O-ring than gasket. Be careful of the four little seals around the air injection passages. Those can be re-used too unless you lose them.
Ben
Ben
valve adjustment
Ben
05-05-2021, 02:37 AM
Sweet. Thank you sir.
If everything checks out, I can just button it back up. If anything needs adjusting, it will be down while I order shims, so I'd just order a gasket as well. ... or I'll wait till 12k and check it then. Haven't decided yet.
05-05-2021, 04:52 AM
(04-28-2021, 08:07 AM)PowerDubs_imp Wrote: The ZRX forum has a box of shims that travel from user to user...I guess I didnt catch up after seeing you were trying to source custom cams. Didn't realize you got them! Hows the bike sound with different cams? 2014 CB1100, 1981 KZ440 LTD, 1993 Yamaha XJ600 Seca, 1994 Yamaha XJ600 Seca
05-05-2021, 05:34 AM
i have a hot cams kit for the 599 i bet their the same as the 1100 most honda shims are the same
05-05-2021, 07:13 AM
One of our members sent me this link for a shim kit. You may not want this one, but it does show the dimensions: https://www.aliexpress.com/item/32883204...4477UPasgi
05-05-2021, 07:42 AM
(05-05-2021, 05:34 AM)cj599_imp Wrote: i have a hot cams kit for the 599 i bet their the same as the 1100 most honda shims are the same The kit I used was Hotcams as well. Don't bother...as I mentioned above the factory Honda shims come in sizes half of what the Hotcam kit has- so they are much more accurate. By the time I ended up buying what I needed that wasn't in the kit- I spent more time and money than if I just measured and ordered what I needed piece meal.
05-08-2021, 12:35 AM
(05-05-2021, 07:42 AM)PowerDubs_imp Wrote:(05-05-2021, 05:34 AM)cj599_imp Wrote: i have a hot cams kit for the 599 i bet their the same as the 1100 most honda shims are the same The kit I used was Hotcams as well. Don't bother...as I mentioned above the factory Honda shims come in sizes half of what the Hotcam kit has- so they are much more accurate. By the time I ended up buying what I needed that wasn't in the kit- I spent more time and money than if I just measured and ordered what I needed piece meal. Where did you order your shims from? 2014 CB1100, 1981 KZ440 LTD, 1993 Yamaha XJ600 Seca, 1994 Yamaha XJ600 Seca
05-08-2021, 04:25 AM
Dubs as a second question; most values seem to be around 2 millimeters, say from 1.80 to 2.20 including "half"sizes as well as used in most honda's as far as i could find out in various forums at the time and bertypower's excellent info on the spreadsheet
http://cb1100forum.com/forum/showthread....#pid258193 , is that your experience as well? Could be beneficial for other members to know what to order in advance if they wanted to.
05-08-2021, 11:12 AM
My sizing is different than anyone else would have since I have different cams.
I just ordered my oddball shims online from a Honda dealer. Sent from my iPhone using Tapatalk
05-31-2021, 12:33 PM
(04-27-2021, 12:52 PM)mvk24_imp Wrote: Decided im gonna do the valves adjustment on my I used to have a 440 LTD belt drive. Valves were super easy as they are simple tappets. I haven’t worked with the shim over bucket yet but I am confident I can figure it out eventually. |
« Next Oldest | Next Newest »
| Valve Adjustment Shims | dave | 13 | 615 |
07-28-2026, 12:49 PM Last Post: MagnaRider |
| Valve Adjustment and Camshaft Removal | dave | 5 | 582 |
03-21-2026, 04:49 PM Last Post: Cormanus |
| Valve Adjustment | dave | 6 | 829 |
08-29-2025, 10:46 AM Last Post: dave |
| Valve Cover Baffle lining ? | bflint | 6 | 878 |
07-26-2025, 11:27 AM Last Post: bflint |
| Valve Adjustment Intervals | CBRider_imp | 32 | 2,660 |
04-21-2025, 02:24 PM Last Post: Jurlie_imp |
| Rear Brake Pedal Adjustment | Gone in 60 | 12 | 1,041 |
04-04-2024, 08:18 AM Last Post: Gone in 60 |
| Valve Adjustment Tolerances - How Far Do You Go? | dave | 14 | 1,433 |
10-18-2023, 09:28 PM Last Post: The Gecko_imp |
| Observed Valve Clearance | Cormanus | 16 | 1,336 |
03-06-2023, 09:03 AM Last Post: Tejas_imp |
| The OBSERVED Valve Clearance thread | Pterodactyl_imp | 162 | 11,560 |
12-27-2022, 08:35 AM Last Post: Cormanus |
| Checking valve clearances | Maturecheese_imp | 74 | 6,029 |
12-11-2022, 12:56 PM Last Post: GoldOxide_imp |
