Wheel sensors
#31
(07-19-2023, 01:26 AM)m in sc_imp Wrote: soft code is one that will appear and then go out.
if the abs module is seeing a brief period of low pressure at the sensor ( i assume it has one internally) by the trapped air being compressed, it would/could throw a code.
1st rule of diagnostics is: whats the last thing you touched? in this case, bleeding the system.
I didn't (want to) see it this way, but you are absolutely right. Problems started with a lot of delay, but the last thing I did .... months ago ...was changing the brake fluid. What doesn't fit is the fact that the ABS light does even when out on a straight road without touching the brakes. In this case the pressure inside the system should be constant. In other words the assumed sensor does not see a pressure change.
But you're putting me on a lead ... it's not much work, and the fluid is cheap. And it's due for a swap in a few months anyway.
At least you have fluid. Seems rare in my local community. Huh
I insist on a detailed, prompt explanation!
bacon
bacon
bacon
Been thinking of doing [maybe] a brake system flush. Unconvinced, but it would be a first for me in about 40 years. Every time I am keen on getting some DOT4 brake fluid for the little beasts, no stock. (*sigh*)
Didn't mean to get you somewhat excited Gecko.
Biker
bacon
bacon
Biker
bacon
Biker
You can get one free/DOT4, 2X FI cleaners from my house - professional stuff for forum members, and I can lend you brake fluid suction machine.
Beer
That is a nice gesture [url=http://cb1100forum.com/forum/member.php?action=profile&uid=3454]PB. But I must find my own way and use earth gravity.
(07-19-2023, 10:54 AM)GoldOxide_imp Wrote: That is a nice gesture [url=http://cb1100forum.com/forum/member.php?action=profile&uid=3454]PB. But I must find my own way and use earth gravity.
...or I supply DOT4 + the equipment and you/we do it together at my house garage, your choice....but if you screw up your bike during the flushing procedure, you might be forced to walk back to Burlington, 50 kms...Tongue
Let me know, so I can set up everything ready for ya.
... but, but, but, ... that means riding into the bowels of ...
(this is a reason why it never gets done)
Riding into bowels is not recommended by any motorcycle manufacturer.
BikerHeart
  Front wheel bearing noise? MagnaRider 20 1,635 03-31-2026, 08:20 AM
  This is why wheel bearings are failing 1973cb750 3 321 02-05-2026, 08:11 AM
Last Post: 1973cb750
  CB11OO EX wheel rims sprint 6 606 02-26-2025, 06:16 AM
  2013 replacement wheel Randy B 8 738 11-13-2022, 10:32 AM
Last Post: Randy B
  wheel imbalance j3gq_imp 7 607 07-03-2022, 09:35 AM
  Kink in rear (spoked) wheel Ayrshire Dunx_imp 1 242 04-09-2022, 09:37 PM
  Friction front wheel j3gq_imp 12 859 12-12-2021, 01:26 PM
Last Post: jimgl3_imp
  Tires yet again - spoked wheel options Rogerdj_imp 12 931 09-05-2021, 04:56 PM
Last Post: Henrik_imp
  O2 sensors on 2014 DLX Houtman_imp 15 983 12-18-2020, 10:02 PM
  Wheel weight Brad14_imp 7 527 07-25-2020, 01:56 AM
Last Post: Brad14_imp
