Knocking noises; vibrations in the handlebar; oil sipping at valve lid gasket
#31
(06-06-2025, 04:12 PM)Cormanus Wrote: Vibration in the bars is a long-standing gripe. It's a product of the engine and some feel it worse than others. Use search and see what else you can find out, but here's one relevant thread https://cb1100forum.net/forum/showthread.php?tid=413
Thank you Cormanus, an illuminating thread that proofs I'm not the single one in this thankless situation of strong vibrations over 3500 rpm and knocking; sadly is worse, is a irreparable constructive mistake. I wonder how many owners admit freely they have this very serious problem, if they fix it somehow locally or if they where able to contact Honda Japan directly and find the solution for that(apart from selling it). I personally struggle for months to contact Honda Japan by mail but I haven't found the address anywhere or any specialist who can help me. I've already been at 5 independent experienced mechanics. Sad
PS: I contact two Honda dealers locally, Honda Germany and UK... nobody came up with a solution in order to help me and totally silent in disclosing a direct connection to Honda Japan, very disappointing.
 I'm back with the knocking engine problem that I see has gotten a bit louder and is always present after the engine warms up(town), only noticeable in idle, I'm also posting a recent video on YouTube for a better perception  https://www.youtube.com/shorts/zQEwKuHnDds
 What do you think it could be and where could it be located?
One of the mechanics suspects it could be an noisy actuator from the fuel line. I don't know if such a thing(with that name) exists in the supply line!? From what I can see on the Honda diagrams, on the supply line there would only be this: "36450-MCA-A62 Valve ASSY., ex. Air Injection" and "36162-PLC-003 Valve, Purge Control Solenoid", as mechano-electrical parts that could generate noises during operation if there are faulty.
What do you think, could that knock noise come from one of these assemblies of the fuel line or, the problem is from the engine? Sad
Has anyone else knows or experienced something like this, does anyone have these low-frequency knocking noises(Tok,Tok) and how worrying are them? What should I do and where should I look for the cause? I've been struggling with these since spring and no one has found their cause and location with certainty. Much appreciated any ideea, suspicion, comment etc.
the link says the video is private. Can you change that?
Holder of the CB1100forum Secret Decoder Ring
2012 ST1300
2013 CB1100
I find your lack of RLETs disturbing
PCSV is a duty type = on/off cycle valve operated by ECU ground , B+ constant supplied.
Its resistance is about 24 Ohms at 20*C
Mostly energized at idle and if working correctly, it generates a ticking noise, or gentle knocking noise.
It’s a part of an emission system.
Does not work when engine off/ign on.
Will not be heard at higher rpm.
If malfunctioning, it may trigger MIL.
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
Good morning. Here is the good news. I assert with the greatest respect that PekingDuck and PeterBaron are phenomenal mechanics. I read posts from them and treat those posts like a master mechanics' class. I strongly encourage you to explore their recommendations without deviation.
More good news: you own one of the very best engineered motorcycles that Honda has ever built. Many of the members of this Forum wished they had a CB1100RS because it leans a couple of clicks toward a sport bike relative to other CB1100 Models. Regrettably, we cannot import it into the United States because Honda did not complete the registration process with the United States government to enable it to be licensed. If they had, people on this Forum would be offering to purchase it from you! Hence, have faith and be patient. You have a great motorcycle, and it will in time get to where you want it to be.
I believe you have already received some great coaching. I encourage you to do only one thing at a time and put enough miles on the motorcycle to make a determination about is it right or is it not. Your CB1100 RS should have a smooth, sport ride courtesy of the inline 4 and suspension. It should handle brilliantly courtesy of the weight distribution and braking system. It is already beautiful motorcycle in its current forum.
Let me offer these additions to this thread:
Vibrations: I own a 2017 CB1100EX. it is a more refined, less sport version of your motorcycle. They share many of the same parts and the same engineering. I have absolutely no vibration. However, that was not the case when I purchased the motorcycle. The prior owner had removed the OEM bar weights from the handlebars because he preferred a different aesthetic. I ordered the entire bar-weight assembly from WeBike Japan and installed them to spec. I also checked the torque for every bolt associated with steering and adjusted accordingly. Most of the vibration disappeared instantly. I would also encourage you to check tire pressure and possibly have the wheels re-balanced.
I did still have two issues left following the bar-end replacement. When I came to a stop or accelerated quickly, I felt minor vibrations. While stopping, I experienced a brake squeal from the front disc brakes. In a move that is incredibly unusual for me, I re-installed a fork brace I had taken off the motorcycle. That non-OEM brace appears to help stabilize the front forks which handle a tremendous amount of weight in those situations. That brace coupled with my natural tendencies to keep everything very clean has eliminated the noise and the vibration I experienced. I am not naturally inclined to move away from OEM designs, but this particularly addition (inexpensive and easy to install) has made a difference on my CB1100EX. I cannot recommend it for your RS, but I can encourage you to consider exploring that option.
Valve-Lid Gasket: It surprises me that you have a leak. It suggests that an inexperienced mechanic worked on your motorcycle. I encourage you or someone you trust to purchase a replacement gasket and install it to spec. I cannot over emphasize the importance of cleaning everything prior to install and using a torque wrench.
Hope my contributions to this Thread help. If my input conflicts with the wise counsel of Lord Popgun, Cormanus, PekingDuck, and PeterBaron, I would defer to them. They have a much longer history than me with a CB1100. My only claim to fame is that I love the CB1100 more than anyone else on this Forum. Smile
Attached Files Thumbnail(s)
2017 Honda CB1100 EX
(11-10-2025, 08:41 AM)Lord Popgun Wrote: the link says the video is private.  Can you change that?
sorry, I do not use YouTube often, I switch the privacy to off I think now is OK
Well, it does seem to play, but there is no video or sound. Maybe Cormanus or someone can tell us what is happening.
2012 ST1300
2013 CB1100
Happy to try, but YouTube tells me the video is unavailable.
(11-10-2025, 02:31 PM)Lord Popgun Wrote: Well, it does seem to play, but there is no video or sound.  Maybe Cormanus or someone can tell us what is happening.
Maybe this time is working  https://www.youtube.com/shorts/zQEwKuHnDds
(11-10-2025, 03:02 PM)Cormanus Wrote: Happy to try, but YouTube tells me the video is unavailable.
Yep. It's working fine now. I'm going to go listen to my bike then I'll get back to you.
  Valve Adjustment Shims dave 13 666 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 615 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 852 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 913 07-26-2025, 11:27 AM
Last Post: bflint
  Valve Adjustment Intervals CBRider_imp 32 2,801 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  CB1100 EX CA K handlebar switches sprint 7 598 02-25-2025, 10:36 PM
Last Post: sprint
  2014 rear wheel knocking noise dunebuggy_imp 7 944 08-05-2024, 03:33 AM
Last Post: Yata-Garasu_imp
  Left Side Crankcase Gasket Part number. jbird06_imp 1 317 03-26-2024, 08:56 AM
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,477 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Observed Valve Clearance Cormanus 16 1,387 03-06-2023, 09:03 AM
Last Post: Tejas_imp
