Sissybar/backrest info (from sidecar pics)
pwyakjr@stny.rr.com_imp Offline
Threads: 1
RE: Sissybar/backrest info (from sidecar pics)
#31
(09-22-2013, 09:43 PM)CB4ME_imp Wrote:
(09-22-2013, 01:19 PM)Buffalohead_imp Wrote: pw, yours is the best backrest done yet. I know SS is really tough and hard to work with but your final product was well worth it. Congrats!
BH
Totally Agree! Exceptionally nice work. Very clean and professional looking. eautifully finished. Going to pick up some stainless steel and redo mine this winter when I have a few days. May I ask how did you bend the SS plate in 2 directions so smoothly?
Bravo! Clap
Bravo! Clapi used grade 5 ss bolts and nuts.i installed the plates to the back rest first and tightened them down, i then installed the rear bolt and nuts first and snugged them up rather tight to the rack i then installed the front bolts and nuts and would turn the left 5 turns then the right 5 turns and so on untill the plate was touching the rack all along its length. i did that so both sides bent in a similar manor. you have to use grade 5 bolts or the bolts will either break or strip out. have a couple of extras on hand just in case, i did but i did not need them. i did not use a lock washer i instead put a few drops of locktite on the nuts. the stainless steel was difficult to cut and drill. the rack holes were 5/16 and were not a problem at all. the back rest holes were either 3/8 or 1/2 and they were a cuss. i did use a step drill bit for the first couple of holes but burned it up (i was using oil as a lubricant). the larger the hole the more difficult it became. the holes in the rack i used a dremmel bit made of titanium to square the hole for the carriage bolts, it worked well. thanks cb4me for supplying me with the idea. i had a picture of your set up on my bench as i worked.
09-23-2013, 01:46 AM
CB4ME_imp Offline
Threads: 183
#32
Those Jardine mounting holes and mounting bolts are 10mm or 0.40".
I was able to use a 3/8" drill bit and then a round rasp to make appropriate sized holes on my ALUMINUM mounting bracket. Different proposition when using stainless.
Where do folks find metric drill bits in the local marketplace? Haven't found them at Lowes, Home Depot, Tractor Supply, etc.
09-23-2013, 05:01 AM
Buffalohead_imp Offline
Threads: 10
#33
Just a thought. Maybe some of the numbered drill bits would get close. (?)
09-23-2013, 05:53 AM
Threads: 1
#34
I used only sae drill bits. I was able to get it close enough. remember the dremmel titanium grinding bit it was a big help. it wasn't cheap 14.00 from true value hardware.
09-23-2013, 09:11 PM
  Backrest available Whit_imp 3 417 06-20-2024, 03:44 AM
  T Rex backrest jeffmazz_imp 7 742 09-16-2021, 06:09 AM
Last Post: skenzie1340_imp
  Sissybar Tony.Robbo1982_imp 0 235 01-24-2021, 04:37 AM
Last Post: Tony.Robbo1982_imp
  small passenger backrest CB1100 ex 2015 - with original Honda grill. Alfgaxatico_imp 3 387 11-24-2020, 06:14 PM
  Backrest? V65CigarFly_imp 22 1,670 04-09-2020, 10:49 PM
Last Post: mdharne_imp
  Backrest. Hardhead_imp 4 475 04-08-2020, 04:23 AM
Last Post: Hardhead_imp
  LED TURN INDICATORS - addition & sharing info peterbaron 5 762 12-08-2019, 09:28 AM
  Corbin aftermarket backrest jdinaz_imp 8 819 04-19-2019, 12:26 AM
  CB1100 Backrest Project metalmaven_imp 64 5,211 03-14-2019, 10:56 AM
  Affordable passenger backrest options? Rebel73_imp 8 674 02-09-2016, 04:33 AM
Last Post: Rebel73_imp
