Sissybar/backrest info (from sidecar pics)
Buffalohead_imp Offline
Threads: 10
Mike looked through the J&P site until he found it. Remember, you must have the factory rack because the sissybar/backrest mounts to the rack after holes are drilled in the rack. It looks like they belong together.
The J&P info is:
Jardine Short Backrest with Pad
Part #: ZZ82052 $113.99
jpcycles.com
08-21-2013, 02:49 AM
Firstfour_imp Offline
Threads: 2
RE: Sissybar/backrest info (from sidecar pics)
(08-21-2013, 02:49 AM)Buffalohead_imp Wrote: Mike looked through the J&P site until he found it. Remember, you must have the factory rack because the sissybar/backrest mounts to the rack after holes are drilled in the rack. It looks like they belong together.
The J&P info is:
jpcycles.com
Awesome! Thanks. Thumbs Up
08-21-2013, 03:24 AM
CB4ME_imp Offline
Threads: 183
Ordered the Jardine mini backrest version. It's 9" high vs. 11.5" high and has a shorter sized pad. Both are the same dimensions where they meet the Honda rear carrier.
Dennis Kirk has both the short and mini backrest for $108 plus free same day shipping. Right now they have 3 of the short and only 1 of the mini.
https://www.denniskirk.com/jardine/mini-...494859.sku
My wife and I really liked the short sissy bar on my old Triumph Bonneville. It was unobtrusive and gave my wife a secure feeling that she wasn't going to slide off the back when I goosed it. I think the Jardine mini will be similiar.
Buffalohead - many thanks!!!!!
08-21-2013, 04:07 AM
Bbref36_imp Offline
Threads: 14
(08-21-2013, 04:07 AM)CB4ME_imp Wrote: Ordered the Jardine mini backrest version. It's 9" high vs. 11.5" high and has a shorter sized pad. Both are the same dimensions where they meet the Honda rear carrier.
Great info! What mounting kit did you order?? There are many different options as you know.
08-21-2013, 05:52 AM
CB4ME_imp Offline
Threads: 183
According to Buffalohead, the backrest/sissybar will mount inside the Honda rear carrier. The sissybar is already drilled. The carrier will need to be drilled to match the sissybar holes at the desired angle. I may need some longer bolts and some spacers but the project seems relatively straight forward. I'll know more Monday when the sissybar arrives.
08-21-2013, 06:32 AM
Threads: 10
CB4ME is correct. Mike didn't need a mounting kit. He drilled holes and bought good bolts. That's all you'll need.
08-21-2013, 06:33 AM
Bbref36_imp Offline
Threads: 14
(08-21-2013, 06:33 AM)Buffalohead_imp Wrote: CB4ME is correct. Mike didn't need a mounting kit. He drilled holes and bought good bolts. That's all you'll need.
Another dumb question - where would I get good bolts? I know or at least don't think I would be able to get anything like that at a Honda shop. Anya suggestions!
08-21-2013, 09:22 AM
Threads: 10
We usually get them at Lowe's. They have them in stainless steel. They look good.
08-21-2013, 09:30 AM
Bbref36_imp Offline
Threads: 14
How much longer than the bolts for the luggage rack did you get? Thanks for all your help
08-21-2013, 11:06 AM
CB4ME_imp Offline
Threads: 183
Get long longish bolts and use one of those small hacksaws with thin blades and a fine tooth file to cut down and debur to achieve a perfect size. Use a vice to make the cut.
08-21-2013, 11:14 AM
  Backrest available Whit_imp 3 417 06-20-2024, 03:44 AM
  T Rex backrest jeffmazz_imp 7 742 09-16-2021, 06:09 AM
Last Post: skenzie1340_imp
  Sissybar Tony.Robbo1982_imp 0 237 01-24-2021, 04:37 AM
Last Post: Tony.Robbo1982_imp
  small passenger backrest CB1100 ex 2015 - with original Honda grill. Alfgaxatico_imp 3 389 11-24-2020, 06:14 PM
  Backrest? V65CigarFly_imp 22 1,678 04-09-2020, 10:49 PM
Last Post: mdharne_imp
  Backrest. Hardhead_imp 4 475 04-08-2020, 04:23 AM
Last Post: Hardhead_imp
  LED TURN INDICATORS - addition & sharing info peterbaron 5 770 12-08-2019, 09:28 AM
  Corbin aftermarket backrest jdinaz_imp 8 822 04-19-2019, 12:26 AM
  CB1100 Backrest Project metalmaven_imp 64 5,245 03-14-2019, 10:56 AM
  Affordable passenger backrest options? Rebel73_imp 8 674 02-09-2016, 04:33 AM
Last Post: Rebel73_imp
