Handlebar Risers
jerrycon_imp Offline
Threads: 11
RE: Handlebar Risers
I'm thinking about risers. I like the idea of fully adjustable, pivoting risers like the [url=http://www.amazon.com/Rox-Speed-FX-Pivoting-Handlbar/dp/B0041PXMIM/ref=cm_cr_pr_product_top?ie=UTF8]Rox Speed FX 2-inch pivoting risers. The only downside of that would be a near certain need to reroute cables and get a longer brake line. Price is good, though, at only U.S.$61.
Maybe just go with the [url=http://www.genmarmfg.com/shop/universal-risers/universal-risers,-7-8-bar-style-handlebar-risers-1-up-detail.html]GenMar universal risers (U.S.$76) to see if that does the trick? No need to reroute or extend based on what I've read here.
04-24-2015, 04:24 PM
geosar_imp Offline
Threads: 10
I put the Rox 2 inch adjustable risers on two nights ago and the lines and cables on the right are pretty tight.
It was dark so I just left everything loose. Can you get a longer brake line from the master cylinder to the front disks? Seems complicated.
It's a shame because the risers place the handlebars in a much better position.
04-24-2015, 10:51 PM
jamboa_imp Offline
Threads: 10
I did genmar risers and also added a tall SuperBike bar. i love it
i did this when I also installed custom length braided stainless steel brake lines
Braided stainless steel brake lines firm up brake feel andvlook great for quality upgrade.quote='jerrycon' pid='85797' dateline='1429943058']
[/quote]
04-25-2015, 03:05 AM
geosar_imp Offline
Threads: 10
I adjusted the Rox 2 inch riser in the daylight. They are not a breeze without a stubby allen wrench which I made.
I avoided the tight brake line issue by rotating the master cylinder for the front brakes and clutch.
Feels pretty nice and I must say the adjustable risers offer a lot of variability in sitting positions.
Next ride, I will take the allen wrenches and fine tune the handlebar position.
George
04-25-2015, 09:10 AM
Threads: 11
If possible, I would be very interested in seeing a photo of your rotated master cylinder positioning.
04-29-2015, 12:30 PM
1100rider_imp Offline
Threads: 41
#26
Yesterday I installed the 2" ROX risers and really like them. I had 2" solid risers installed before but wanted something to bring the bars a little closer to me. The cable seem to be loose enough from full right to full left on the handlebars. I was able to tilt the bars back towards me and and am satisfied.
04-30-2015, 02:03 AM
Ghis_imp Offline
Threads: 31
#27
I used the Bike Masters risers. You can choose your height. I decided to go conservative with 3/4 inch rise, as the brake cable seemed stressed with a full inch (though everyone says 1" is just fine). They were $36.95! However I must warn you that none of the bolts length options that came in the package worked. Can't remember what length, but I had to get slightly shorter bolts than the shortest offered. The shortest would have worked with the full 1", I think.
[url=http://s429.photobucket.com/user/ghislainsabre/media/IMG_6191_zpslr6xfv8o.jpg.html][Image: 084b2f742fbe7d75fedfceb63d75fd31.jpg]
05-20-2015, 02:20 PM
Chapomis_imp Offline
Threads: 64
#28
I'm putting risers on my CB. Does anyone know the torque number for the 4 bolts ?
06-03-2015, 09:02 AM
Likes Given: 802
#29
Alan 15 ft lbs and you tighten forward ones first rearwards last
06-03-2015, 09:44 AM
treytexag_imp Offline
Threads: 5
#30
(06-03-2015, 09:02 AM)Chapomis_imp Wrote: I'm putting risers on my CB. Does anyone know the torque number for the 4 bolts ?
Chapomis, which risers did you buy for the CB?
06-03-2015, 08:06 PM
  USB ON HANDLEBAR - connection at battery direct . Alfgaxatico_imp 38 2,943 05-17-2026, 10:20 PM
  Quad Lock handlebar vs clutch perch and bar-end mirrors Uncle Sixer 1 331 01-04-2026, 01:26 PM
  Handlebar control symmetry Uncle Sixer 17 1,763 08-07-2025, 05:24 AM
  VOIGT Risers Duderino_imp 3 465 11-23-2024, 01:09 AM
Last Post: Obleo
  Handlebar Risers?? bubblerboy64_imp 16 1,549 07-16-2022, 06:04 AM
Last Post: calipo223_imp
  What to do with the handlebar mounts when converting to clip-on controls? misterprofessionality 7 764 04-08-2022, 03:41 AM
  CB 1100 EX Handlebar original or other? MALACAY_imp 4 553 04-03-2022, 01:00 AM
  ROX Risers and longer brake line? MrBob_imp 3 470 06-14-2021, 12:19 AM
Last Post: MrBob_imp
  Rizoma risers on the cb1100 Zee9_imp 20 1,617 05-28-2021, 02:20 PM
Last Post: Zee9_imp
  Handlebar from 919 motorider6_imp 10 958 05-27-2021, 12:47 PM
Last Post: Stichill
