Hepco and Becker c-bow mounts and street bags
DaSwami_imp Offline
Threads: 25
RE: Hepco and Becker c-bow mounts and street bags
I guess I'm still confused. If the OEM wires have enough slack to relocate the turn signals, why do you even need to disconnect them in the first place?
04-14-2016, 01:43 AM
kennyw Offline
N9PHW
Sultan, WA
Threads: 42
Likes Received: 5 in 4 posts
Likes Given: 3
The OEM wires do not have any slack in them and require disconnecting in order to pull them out of the trim pieces that they are mounted on.
04-14-2016, 06:44 AM
DaSwami_imp Offline
Threads: 25
Gotcha, and so the wires do not remove from the base of the turn signal itself???
04-14-2016, 02:01 PM
kennyw Offline
N9PHW
Sultan, WA
Threads: 42
Likes Given: 3
(04-14-2016, 02:01 PM)DaSwami_imp Wrote: Gotcha, and so the wires do not remove from the base of the turn signal itself???
Only if you have the special tool.
04-14-2016, 04:04 PM
DaSwami_imp Offline
Threads: 25
Haha, good one. What type of connector would you recommend to reconnect cut wires (I am an idiot when it comes to electrical stuff)
04-15-2016, 02:07 AM
kennyw Offline
N9PHW
Sultan, WA
Threads: 42
Likes Given: 3
#26
In this case, I would just drop the fender and pull the wires loose. It only takes a couple minutes. Splicing wires is another opportunity for corrosion to sneak in.
04-15-2016, 02:28 AM
DaSwami_imp Offline
Threads: 25
#27
Eh, you lost me again. Maybe I will just get a tailbag and call it done.
04-15-2016, 08:37 AM
Likes Given: 1,010
#28
kennyw, I'm also a bit confused by 'just drop the fender and pull the wires loose' too. What happens then?
04-15-2016, 08:40 AM
kennyw Offline
N9PHW
Sultan, WA
Threads: 42
Likes Given: 3
#29
http://cb1100forum.com/forum/showthread.php?tid=6737
I took pics when I relocated my turn signals.
Dropping the rear fender down makes it easy to move the taillight wires.
04-15-2016, 11:53 AM
Likes Given: 1,010
#30
kenny, looks like your final mod used replacement indicators that had wires long enough to run all the way back under the seat. So, I guess, pulling out the original wires and replacing them makes sense.
What did you do with the original mod? It looks like your first signals may not have had wires long enough to reach back to the battery.
04-15-2016, 04:46 PM
  [SOLVED] Are Hepco & Becker C Bow mounts compatible with the OEM Rear Rack? JRD 14 982 07-09-2026, 07:38 PM
Last Post: JRD
  saddle bags for 2014 std ?? tdbru 7 1,096 06-22-2025, 01:03 PM
Last Post: 12milesout
  Soft Bags to throw on when needed Davidjill_imp 6 610 04-11-2025, 10:50 AM
Last Post: balkanhound_imp
  SW Motech Pro Blaze Honda CB1100 Saddle bags for sale CAN$350 peterbaron 3 455 02-07-2025, 01:01 AM
  Hepco & Becker luggage Nitro_imp 12 1,076 03-20-2024, 03:37 AM
Last Post: Mitch_imp
  Side bags soft for 2014 CB1100 omnimj_imp 17 1,440 12-07-2023, 08:51 PM
Last Post: CptMoustache_imp
  Hepco Becker Replacement Key tomcat_imp 5 598 08-10-2023, 03:20 AM
  Flipping the handle bar mounts around 1985CB450_imp 4 474 10-11-2022, 05:21 PM
Last Post: Mixagon_imp
  What to do with the handlebar mounts when converting to clip-on controls? misterprofessionality 7 746 04-08-2022, 03:41 AM
  Move the arrows back to clear the bags Enzofour_imp 5 659 01-25-2022, 06:20 PM
Last Post: Enzofour_imp
