Flipping the handle bar mounts around
1985CB450_imp Offline
Threads: 5
Well in my quest to get the bars as low and far forward as the stock mounts/tank will allow I decided to swap the bar mounts around as they have a pretty good offset
I had already switched out the stock bar on my 2013 for an Emgo 7/8 Superbike bar
Here is the Superbike bar with stock mount orientation
[Image: 950e1592d3e9db6c661db94846f770bd.jpg]
Same bar with the mounts flipped
[Image: 6ff18d7f9a889010f8181b64e43fe64c.jpg]
[Image: ea6061f2781d213ef2b821f0b94b55fc.jpg]
By getting the bars just a little more forward I was able to rotate it more rearward giving it a perfect angle at the grips and plenty of tank clearance. Very happy with the end result
Below shows tank clearance at full lock
[Image: f985dbfdf4a29edc981a37de28a72d9d.jpg]
[Image: 6abf96057e1a9a173cdfd9e697589e3e.jpg]
10-09-2022, 04:45 AM
RE: Flipping the handle bar mounts around
Nicely done 1985CB450.
10-09-2022, 05:42 AM
ymtnpoah11_imp Offline
Threads: 9
Thumbs UpClap
10-11-2022, 08:13 AM
Threads: 5
Thanks, it puts the bars at just the right length
10-11-2022, 11:46 AM
Mixagon_imp Offline
Threads: 35
What a good idea, pleased it worked for you. The bars on my RS are lower and to far forward so I'll look into this to see if flipping mine would bring the bars back a little.
10-11-2022, 05:21 PM
  [SOLVED] Are Hepco & Becker C Bow mounts compatible with the OEM Rear Rack? JRD 14 987 07-09-2026, 07:38 PM
Last Post: JRD
  Garnish/grab handle problem Twiggy_imp 1 341 10-01-2023, 04:20 AM
  What to do with the handlebar mounts when converting to clip-on controls? misterprofessionality 7 750 04-08-2022, 03:41 AM
   Handle Grip Options Yata-Garasu_imp 24 1,801 10-26-2021, 11:28 AM
Last Post: rboe
  Options for handle bar riser itstuantran_imp 1 310 06-21-2019, 03:49 AM
Last Post: Bazbro_imp
  Handle Bar Clamp adds character to bike 17-CB-002 26 1,746 03-25-2019, 10:05 AM
Last Post: LikeAfox_imp
  One More Handle Bar Thread Perry_imp 1 312 06-30-2018, 11:21 PM
Last Post: jeffmazz_imp
  Passenger handle EX my2018 Vincentvega88_imp 2 381 06-17-2018, 08:23 AM
  Universal Side Bag Mounts BIGGREEK_imp 0 215 04-06-2017, 05:01 AM
Last Post: BIGGREEK_imp
  Rear sets, seat and handle bar CB Cycles_imp 10 839 02-17-2017, 10:58 AM
Last Post: jamestkirk_imp
