Auxillary USB Power Plug install for IPhone
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
RE: Auxillary USB Power Plug install for IPhone
Bob, Here is a post that shows the inside of my headlight bucket: http://cb1100forum.com/forum/showthread....9#pid87099
Notice the red connector at the bottom. That is the accessory connector in the bucket. Yours will be in the same area. It may be taped and a tad hard to find but it is there. The connector is capped to protect the pins.
There are 2 wires. Green is ground. The other is switched 12vdc.
To add your SAE plug or whatever, you will have 3 choices. Buy a connector, pins, and crimping tool and wire up your SAE or USB plug. Although I and a few other electronics nerds did this, it isn’t the way for most.
The second way is to tap into the wires and the last way and maybe the best is to cut the connector off and just connect to the wires.
Your SAE or whatever you have will have a black and a red wire, or a smooth black and a ribbed black wire. If red and black, connect black to green. If smooth black and ribbed black, connect ribbed black to green. Other wire to the hot wire.
To get your new addition where you can use it, run the wire out the back of the bucket and up to the handlebars or wherever you want. Make sure the forks will move lock to lock with out binding the cable.
05-12-2019, 11:31 AM
Bob750_imp Offline
Threads: 0
Thanks, Popgun!
05-12-2019, 02:20 PM
Bazbro_imp Offline
Threads: 16
(05-12-2019, 11:31 AM)Lord Popgun_imp Wrote: Bob, Here is a post that shows the inside of my headlight bucket: http://cb1100forum.com/forum/showthread....9#pid87099
A great, helpful post, thanks, Popgun. Smile
05-12-2019, 06:00 PM
  booster plug outback_imp 4 452 10-07-2022, 01:20 AM
Last Post: Denbow_imp
  Any aftermarket Turn signals plug and play? gretle_2.0 5 663 05-30-2022, 07:05 AM
Last Post: bioman_imp
  Can someone with a power commander on a 6-speed bike check something for me? PowerDubs_imp 10 816 05-15-2022, 11:42 AM
  Usb-c cable direct to battery or switched power capz65_imp 5 531 04-16-2022, 02:26 PM
  Windjammer ss. Install caddy425_imp 15 1,215 03-29-2022, 01:28 PM
Last Post: Canadianredneck_imp
  Puig Plus install question Rolls_imp 16 1,271 01-24-2022, 04:33 AM
Last Post: j3gq_imp
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,295 01-05-2022, 10:54 PM
Last Post: Nibis_imp
  Honda top case install Jonnyteabag_imp 11 886 12-31-2021, 09:22 AM
Last Post: Jonnyteabag_imp
  Power Distribution Module (PDM) - Europe/UK Tev62 5 533 11-16-2021, 07:49 PM
Last Post: j3gq_imp
  QUAD LOCK IPHONE SYSTEM Alfgaxatico_imp 33 1,760 01-25-2021, 08:39 AM
