 CB Custom - Speedo/Tach Wiring Issues
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
RE: CB Custom - Speedo/Tach Wiring Issues
What I said previously about mounting the speed sensor at the sprocket was a bad idea because the alignment will change when the chain is adjusted. It looks like the magnetic sensor comes with a bolt with a magnet in it's head to replace a rotor bolt. If that bolt is the wrong diameter you can buy different size bolts with magnets from Trail Tech.
10-09-2020, 10:18 PM
CafeBandit_imp Offline
Threads: 1
(10-09-2020, 10:18 PM)pekingduck_imp Wrote: What I said previously about mounting the speed sensor at the sprocket was a bad idea because the alignment will change when the chain is adjusted. It looks like the magnetic sensor comes with a bolt with a magnet in it's head to replace a rotor bolt. If that bolt is the wrong diameter you can buy different size bolts with magnets from Trail Tech.
Yeah its too small. I may just find a replacement rear sensor all together. But the stock one in non magnetic and only has 2 wires and the aftermarket ones have 3. The Daytona one has two wires but ive tried many combos to catch the signal but nothing. Im considering the gps option now.
10-10-2020, 02:04 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
Yeah its too small. I may just find a replacement rear sensor all together. But the stock one in non magnetic and only has 2 wires and the aftermarket ones have 3. The Daytona one has two wires but ive tried many combos to catch the signal but nothing. Im considering the gps option now. I would stick with the sensor they supplied since you know it should be compatible with the meter. Almost all other speed sensors do not use a magnetic pickup, and there is no standard diameter or length or bolt pattern. The sensor needs to be positioned where the magnet passes under the end, not the center. Air gap needs to be about 0.020" - 0.050".
Do you have a picture of your sensor mounting?
10-10-2020, 04:11 AM
Threads: 1
Do you guys know the firing order for the spark plugs or if theres a primary?
10-11-2020, 07:47 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
Here ya go: http://cb1100forum.com/forum/showthread....3#pid86283
10-11-2020, 07:58 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
#26
(10-11-2020, 07:47 AM)CafeBandit_imp Wrote: Do you guys know the firing order for the spark plugs or if theres a primary?
It's 1-2-4-3 as counted from the left when seated on the bike. But the firing order shouldn't matter here. When the instructions say "primary", it means the low voltage wire coming from the ECM to the coil. You could choose either coil, and it would be either blue/black on one or yellow/white on the other coil - not either of the black/whites.
In the RPM setup mode, PPR setting, it probably is the first choice, 1 spark per 1 revolution.
10-11-2020, 08:01 AM
Threads: 1
#27
Awesome thanks!
10-11-2020, 08:18 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
#28
Keep us updated on your progress!
10-12-2020, 08:15 AM
peterbaron Offline
Likes Received: 573 in 311 posts
Likes Given: 954
#29
...and pics as well, we love seeing things Thumbs Up
10-12-2020, 08:27 AM
Threads: 1
#30
I will. My CB is far from stock and I guess it really bothers some people but I will try to post pics when it all put back together. I caught the rpm reading from the spark plug, and found a couple sensor mount options on the inside of the forks (right side).. never noticed them before. Hopefully that will line up and read correctly. Just need to swap out the bolt with a magnetic one. Already on order. Thank again, ive learned a lot reading your comments throught out this forum.
10-12-2020, 09:08 AM
  custom seat by Mr. Ed's Moto tdbru 8 653 09-20-2025, 09:21 AM
Last Post: tdbru
  speedo healer 1973cb750 1 318 04-09-2023, 11:06 PM
Last Post: 1973cb750
  Custom Exhaust bnhanneman_imp 26 1,751 03-12-2022, 06:03 AM
  Phone mounting issues ride4now_imp 37 2,452 09-29-2021, 05:42 AM
  Custom saddle... gel or no gel? alexzanutto_imp 19 1,522 07-25-2021, 11:29 AM
  Speedo dial - change from kph to mph Ninemeister_imp 21 1,311 10-06-2020, 03:33 AM
Last Post: Randy B
  Custom lavalier mic setup for GoPro vids… Guaza14_imp 8 644 07-17-2019, 03:11 PM
Last Post: max
  Custom paint and body work pricing misterprofessionality 3 443 04-30-2019, 05:09 AM
Last Post: spartanheed_imp
  Custom seat husky385_imp 9 833 06-10-2017, 04:21 AM
Last Post: husky385_imp
  Custom rear fender removal. Rebel73_imp 17 1,184 03-15-2017, 06:49 PM
Last Post: c-breezy_imp
