Speedo dial - change from kph to mph
Ninemeister_imp Offline
Threads: 4
I think my 2014 6 speed K10 is a Japanese import (has Japan spec HyperPro shocks) and as a result has a kph only speedometer which I would like to change to a mph or combined mph/kph version. I have no issue leaving the trip in km. UK law says that the speed has to be in mph, hence the importer has carefully coloured out the k of the km/h to disguise the calibration.
Easiest way would be to change the speedo face plate for one from a used speedo or have the current one re-printed with the appropriate scale(s).
Any suggestions to where I can get this done (or does anyone have a spare speedo?).
Thanks in advance.
09-17-2020, 01:19 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
RE: Speedo dial - change from kph to mph
If you can take a picture of a meter face in miles, you can take it to a printing place that makes vinyl stickers. The center hole for the needle would have to be larger so you could slip the needle through. Or you could just do a curved perimeter strip.
If you don't have access to a picture of one, it can be done on Photoshop.
Fortunately, the cover on the CB1100 meter cover can be removed to access the face.
There was a discussion on speedometer faces with pics to show the meter face spacing. Most liked the mph only face compared to the mph/kph.
http://cb1100forum.com/forum/showthread.php?tid=15295
09-17-2020, 02:01 AM
Likes Given: 1,012
On some models, you can also switch the odometer between miles and kilometres I think. There was once a discussion about that ... http://cb1100forum.com/forum/showthread....#pid53527. However, I couldn't make it work on a kilometres-only Australian CB1100.
09-17-2020, 09:45 AM
peterbaron Offline
Likes Given: 996
Ninemeister, you can find a cluster/speedo/tach repair shop near you for a profesional service...
Google:
[url=https://www.google.com/search?q=speedo+cluster+repairs+near+Cheshire%2C+UK&oq=speedo+cluster+repairs+near+Cheshire%2C+UK&aqs=chrome..69i57.29558j0j15&sourceid=chrome&ie=UTF-8]https://www.google.com/search?q=speedo+c...e&ie=UTF-8
Smile
09-17-2020, 10:56 AM
Threads: 4
(09-17-2020, 02:01 AM)pekingduck_imp Wrote: If you can take a picture of a meter face in miles, you can take it to a printing place that makes vinyl stickers. The center hole for the needle would have to be larger so you could slip the needle through. Or you could just do a curved perimeter strip.
I have a good mate who is a dab hand with Photoshop so this is definitely an option - provided we can think of a work-around for the hidden warning icons at the bottom of the speedo.
The perfectionist in me knows that I wouldn't be happy to use a number overlay segment, however this might be a good temporary solution until I can find a used mph speedo.
09-17-2020, 10:57 AM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Given: 133
This is the cheapest I could find a new one.
https://www.bikebandit.com/oem-parts/det...sch=847989
You might want to see if you can locate that part number in the UK.
09-23-2020, 03:55 AM
(09-23-2020, 03:55 AM)Randy B_imp Wrote: This is the cheapest I could find a new one.
Yikes, a bit rich for something that is a linear conversion ...
Would be easier to print the mph scale on a clear "static cling" sheet and overlay on the speedometer dial? Maybe not the entire dial circle, but the overlay would be a crescent ring or a smaller pad that would be overlaid so you can still see the indicator needle clearly.
09-23-2020, 10:47 AM
Threads: 4
Yes, it would, I totally agree.
Unless you are a perfectionist who (from driving a lot of LHD cars) has enough experience to convert km/h to mph in my head.
I also suspect that something so "non-Honda" would diminish the karma from fitting a pair of RLETs, but that's a whole new conversation that's probably best discussed on another thread.
09-24-2020, 03:46 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
Like these, but reversed image. https://www.ebay.com/itm/SPEEDO-OVERLAY-...3768199598
or better yet:
http://www.speedofixer.co.uk/kph_to_mph_...rsion.html
09-24-2020, 05:36 AM
Threads: 4
You're not making it easy on me boys in the search for a genuine mph dial...
Cool
09-24-2020, 05:39 AM
  speedo healer 1973cb750 1 348 04-09-2023, 11:06 PM
Last Post: 1973cb750
   CB Custom - Speedo/Tach Wiring Issues CafeBandit_imp 38 2,888 10-13-2020, 12:53 AM
Last Post: Ninemeister_imp
  Paint Change spartanheed_imp 53 3,289 02-21-2019, 02:44 PM
  Air Filter change xNE0x_imp 4 359 02-14-2015, 10:57 AM
Last Post: xNE0x_imp
  It's the little things sometimes that really change the look silascopathic_imp 10 713 08-12-2014, 10:27 AM
Last Post: Gumby 1100_imp
  exhaust change sethrose_imp 28 1,654 03-28-2014, 08:27 PM
Last Post: Tortuga_imp
  Headlight and speedo chrome. Bbref36_imp 13 936 06-17-2013, 09:27 AM
