 CB Custom - Speedo/Tach Wiring Issues
CafeBandit_imp Offline
Threads: 1
New here, working on my first custom 2014 CB1100 "Standard" non-abs. I decided to go with a digital gauge (daytona) but im having trouble finding the right wiring diagram for my model. The one I have doesnt add up. Wrong colors, missing wires. Im just trying to tap into the existing harness but having trouble decoding the ecm and looking for anyone who has went digital or has the proper diagram and wiring description they can share. I know most on here are "traditionalists" when it comes to the CB which I respect but Im new school and dont like having matching bikes. Thanks in advance.
10-07-2020, 06:32 AM
peterbaron Online
Likes Given: 996
RE: CB Custom - Speedo/Tach Wiring Issues
pm sent
10-07-2020, 08:22 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
(10-07-2020, 06:32 AM)CafeBandit_imp Wrote: New here, working on my first custom 2014 CB1100 "Standard" non-abs. I decided to go with a digital gauge (daytona) but im having trouble finding the right wiring diagram for my model. The one I have doesnt add up. Wrong colors, missing wires. Im just trying to tap into the existing harness but having trouble decoding the ecm and looking for anyone who has went digital or has the proper diagram and wiring description they can share. I know most on here are "traditionalists" when it comes to the CB which I respect but Im new school and dont like having matching bikes. Thanks in advance.
Welcome CafeBandit. If you would send a CLEAR picture of the wiring diagram for the aftermarket gauges, we'll see if we can help.
10-07-2020, 08:29 AM
Hey, welcome to the Forum CafeBandit.
10-07-2020, 11:56 AM
Threads: 1
https://daytona-europe.com/en/index.php?...achment=43
Sorry the picture files were to big. But this should take you to it. Thanks for your time.
https://daytona-europe.com/en/index.php?...achment=42
That was the back.. this is the front
10-07-2020, 01:33 PM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
I've installed Trail-Tech Vapor digital meters on other bikes, but I doubt you'll find anyone on this forum who's installed a Daytona Deva 01 on a CB1100.
This is not simply plug-and-play. It is a universal meter and some functions are not compatible. Some calibration and troubleshooting may be needed, and some things will simply not function.
There will be no FI warning light, so you won't know if there is a code or be able to read it. Also, no low fuel warning light, and the temp indicators will be blank. There's also a good chance the speed sensor impulse won't work, in which case you'll have to use the supplied magnetic speed sensor.
In looking at the instructions and the wiring diagram, I marked where I would connect wires were it my bike, but consider it just my interpretation. If a wrong wire is attached in the wrong spot, you could fry your meter, the ECM, and the harness - it's your risk to take. You might want to get other opinions first, or you might want to disregard this post and pic - I won't be offended.
10-07-2020, 04:31 PM
Likes Given: 1,016
I can't remember who it was, but someone started a thread on an aftermarket digital instrument cluster. There was discussion about how to make it work properly and whoever it was eventually had success. I think.
I've had a quick look, but I don't have time now for the long search that might be required.
10-07-2020, 09:45 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Here is one of the threads: http://cb1100forum.com/forum/showthread....#pid239653
and a link to a pic: https://photos.google.com/share/AF1QipN0...dzNGZkOG13
10-07-2020, 11:01 PM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
If anyone wants to weigh in on the harness connections, please do.
10-08-2020, 02:40 AM
Threads: 1
Thank you all. Yeah, its a brand new gauge from Daytona. They themselves dont even have a lot of info for me, too soon for google also. Im just winging it at this point. I know its risky but it will be worth it in the end. Thanks to the plandemic I have nothing but time.
I currently still have the original gauges connected and stored under the seat so hopefully it will run as designed but with the digital aesthetics if i could just tap in. The install manual showed that if the rpm and speed pulse were connected to the ecm , it would give me the gear indication. But i just cant figure out the ecm wires. The ones i followed from the rear speed sensor (pink/white) (green/red) are not giving me anythingm ive tried many variations to get a reading but nothing.
Ive read before about the serial data bus but again I cant figure out which wire, to test it out. The tacho is labled clearly but again nothing happens when I tap in. I grounded the new gauge, connected positive to batt. Dont know if that matters or not but cant think of what else could keep it from reading. I got the power, nuetral, gas, turn signals so far, not concerned with the temps or warnings because of the stock gauges.
I guess I will have to used the after market speed sensor, and rpm reader on the coil but that leaves me with no gear indicator, unless of course I install a seperate one. Kinda defeats the all in one digital but thats worse case.
10-08-2020, 03:09 AM
  custom seat by Mr. Ed's Moto tdbru 8 738 09-20-2025, 09:21 AM
Last Post: tdbru
  speedo healer 1973cb750 1 348 04-09-2023, 11:06 PM
Last Post: 1973cb750
  Custom Exhaust bnhanneman_imp 26 1,967 03-12-2022, 06:03 AM
  Phone mounting issues ride4now_imp 37 2,728 09-29-2021, 05:42 AM
  Custom saddle... gel or no gel? alexzanutto_imp 19 1,597 07-25-2021, 11:29 AM
  Speedo dial - change from kph to mph Ninemeister_imp 21 1,397 10-06-2020, 03:33 AM
Last Post: Randy B
  Custom lavalier mic setup for GoPro vids… Guaza14_imp 8 683 07-17-2019, 03:11 PM
Last Post: max
  Custom paint and body work pricing misterprofessionality 3 472 04-30-2019, 05:09 AM
Last Post: spartanheed_imp
  Custom seat husky385_imp 9 916 06-10-2017, 04:21 AM
Last Post: husky385_imp
  Custom rear fender removal. Rebel73_imp 17 1,268 03-15-2017, 06:49 PM
Last Post: c-breezy_imp
