Custom lavalier mic setup for GoPro vids…
Guaza14_imp Offline
Threads: 11
Hi,
GoPro mic sound is not the best so another alternative is a separate handheld recorder with a lavalier mic mounted close to exhaust. Here is my personal setup in case a member is interested.
The microphone I’m using is a Pro Lavalier Microphone JK MIC-J 044 purchased on ebay for around $35
[Image: d0523880e4bb1eebef8b68fe4376f251.jpg]
I found a good location on my ASAHI pannier case frame to mount the lav mic above the exhaust…
[Image: 8d5617a2922b99057c17d431b38a8203.jpg]
[Image: 1feccff465124af52aa33ba68a0adda1.jpg]
I wrapped some electrical tape around the mic and sealed it with silicon…
[Image: 65c9e69e77dd6d393c0821c14ef910cf.jpg]
Finally, I took a piece of foam and cut out a spot for the Tascam DR 100 MK III. Not pictured is another piece of foam I lay on top to keep things from flying around when riding and recording videos.
[Image: a8cf9c166eea1b0340c1f27ef5d2fcd6.jpg]
Note: You'll need to sync the audio from the recorder with your GoPro vid and that's it. Hope this helps. Biker
07-14-2019, 03:59 PM
RE: Custom lavalier mic setup for GoPro vids…
Interesting take on The Passion.
07-14-2019, 09:00 PM
max Offline
Threads: 39
Likes Received: 15 in 8 posts
It will be interesting to hear/see the result of that, appears to be stealthy enough so the recorder is not stolen.
Was wondering if the mic also picks up engine noise transmitted through the frame since it is connected to it, but that could also have a positive effect.
And just in case it rains does that matter to the mic?
Certainly a solution i have not thought about but i'm sure you've tested it out and my helmet mounted cam has an issue with wind noise and i also have no external mic input.
Think i found a new use for a piece of leftover sheepskin instead of "dead cat", must try that out soon, thanks.
07-15-2019, 12:52 AM
Stichill Offline
Kentucky, USA
Threads: 93
Likes Received: 9 in 4 posts
Likes Given: 6
Cool! Looking forward to hearing the results!
07-15-2019, 11:18 AM
Guaza14_imp Offline
Threads: 11
(07-15-2019, 12:52 AM)max_imp Wrote: It will be interesting to hear/see the result of that, appears to be stealthy enough so the recorder is not stolen.
I think this could be a good solution if your having problems with wind noise. The GoPro does the same thing so I’ll work on creating a video so you can hear the difference. The best sound for me is a mix between both mics. I isolated the mic from the frame by stuffing it into a small piece of foam and then wrapping it with the black wind muff in picture. Also, the bike was left outside twice during heavy rains with no problems at all.
07-17-2019, 03:19 AM
max Offline
Threads: 39
Thanks, i will try something similar today and try to start the camera first, go to the sound recorder and show it on the camera then start the audio record button and clap twice on camera for synchro purposes, see what happens, never tried this before but i'll let you know how it went.
07-17-2019, 04:34 AM
Guaza14_imp Offline
Threads: 11
Here’s a video so you can hear the difference.
07-17-2019, 12:55 PM
Yeah, no doubt superior results with your Lavalier configuration.
07-17-2019, 01:31 PM
max Offline
Threads: 39
Oh yes, that's very presentable, i guess you have lowered the input volume on the tascam, it sounds nice ( Of course ).
When i tried mine today i had it just on top of the seat and the mic volume was way too loud so i have some adjusting to do, i have just the cheapest little recorder but i'm working on it.
Clapping on the video did work, it actually lined up with the sound claps on the video recorder's audio channel, very simple to find and shuffles along just fine.
Thanks for posting, bookmarked your channel and enjoy outtro as well, first time i heard it was on "fazza sky diving from dubai"filmed on red epic camara's in 4k, very nice too.
07-17-2019, 03:11 PM
  custom seat by Mr. Ed's Moto tdbru 8 768 09-20-2025, 09:21 AM
Last Post: tdbru
  Custom Exhaust bnhanneman_imp 26 2,016 03-12-2022, 06:03 AM
  Custom saddle... gel or no gel? alexzanutto_imp 19 1,707 07-25-2021, 11:29 AM
  Custom paint and body work pricing misterprofessionality 3 481 04-30-2019, 05:09 AM
Last Post: spartanheed_imp
  Mounting a GoPro on the CB1100. Some ideas. Pterodactyl_imp 42 3,489 08-05-2018, 04:33 AM
Last Post: zbillster_imp
  Custom seat husky385_imp 9 941 06-10-2017, 04:21 AM
Last Post: husky385_imp
  Custom rear fender removal. Rebel73_imp 17 1,371 03-15-2017, 06:49 PM
Last Post: c-breezy_imp
  2014 CB1100 Custom Seat SBARacing_imp 3 464 02-15-2017, 10:31 AM
Last Post: Jim_imp
   Custom paint job underway... Rebel73_imp 52 3,668 02-05-2017, 05:12 AM
Last Post: rboe
  Custom painted helmet Papa Weeley_imp 24 1,756 08-26-2016, 06:45 AM
Last Post: Papa Weeley_imp
