Smaller turn signal/running light choices
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
RE: Smaller turn signal/running light choices
I don’t think it hurts anything, but its not optimal.
03-16-2021, 11:43 AM
mvk24_imp Offline
Threads: 18
Likes Received: 2 in 1 posts
(03-16-2021, 11:43 AM)Lord Popgun_imp Wrote: I don’t think it hurts anything, but its not optimal.
Thank you Popgun
03-16-2021, 01:58 PM
tod.branko_imp Offline
Threads: 19
(03-16-2021, 10:37 AM)mvk24_imp Wrote:
(03-16-2021, 09:55 AM)Lord Popgun_imp Wrote: Yeah, should work. LED? Might be a different story as we’ve seen in other threads.
Sounds good thank you, I just found very small 6mm bolt LED turn signals on ebay. For the price ill see how bad the hyper flash is. At that size and 6mm bolts I can use the factory mounting and still clear hard bags no problem. I ordered the wiring adapter plugs for the rear too.
1. Is hyperflash bad for the bike in anyway or is it just an annoyance?
2. If someone made an integrated taillight for our bikes I'd probably jump on that and negate the rear turn signals entirely
Sent from my SM-G965U1 using Tapatalk I deleted both the front and rear turn signals with integrated LEDs, yes they hyperflash, and I was thinking of swapping the relay for an adjustable one, they are fairly inexpensive, however after a few months I realized the phenomenon does not bother me in the slightest, so decided to let it be as is. Front light was a plug and play thing, rear light needed to be spliced because it didn't come with Honda connectors, so I cut the connectors off the original tail light and signals. As for the front signals being on all the time and then cutting powered to blink, Max gave me a good idea to actually splice the new ones on the rear turn signals which will keep them off. Hope this helps
'14 CB1100 STD 5 speed
03-16-2021, 02:00 PM
mvk24_imp Offline
Threads: 18
'14 CB1100 STD 5 speed Sounds like a good idea, which lights did you use?
03-16-2021, 02:03 PM
Threads: 19
Sent from my SM-G965U1 using Tapatalk https://www.amazon.ae/dp/B07WQSHCC2/ref=...gXRtuSgWzY
This is the headlight I used, rear was an ebay special, really cheap, and have destroyed it since, so I'm waiting for the new different one
03-16-2021, 09:46 PM
mvk24_imp Offline
Threads: 18
#26
'14 CB1100 STD 5 speed Thank you Tod
03-17-2021, 02:00 AM
E11even_Hunnit Offline
California
Threads: 5
Likes Given: 33
#27
(03-16-2021, 04:57 AM)mvk24_imp Wrote: Figured it was easier to revive an old thread than to start another turn signal thread.
I am looking for smaller turn signals and to relocate the rears to the license plate mount.
- trying to get my information straight. I don't want to need a flasher or resistor. So what light specs do I need to look for?
* if I want plug and play* (aside from extending the rear wires)
1. my understanding is I need 3 wire, Incandescent lights for the front to retain the running lights. Correct?
2. Does single or dual filament bulb matter?
3. Can I use 3 wire lights for the rear and just not use the third running light connection? (If I found a 4 pack of 3 wire)
I really want small bullet turn signals but they all seem to be LED and that sounds like a pain to change resistors or flashers to make LED work.
Rather put the money and effort towards other modifications than making simple taillights become a project.
There's this, but then depending on your budget it may not be the best option since it doesn't include turn signals
https://www.samurider.com/?p=23031
03-17-2021, 06:23 AM
#28
I want to to do motorcycle maintenance in my living room.
Can gawk all day at with over drinks.
03-17-2021, 06:49 AM
mvk24_imp Offline
Threads: 18
#29
(03-17-2021, 06:49 AM)GoldOxide_imp Wrote: I want to to do motorcycle maintenance in my living room.
I'm trying to get an industrial loft with the freight elevator for that exact reason.
03-17-2021, 08:09 AM
#30
In NYC: That sounds luxurious.
03-17-2021, 10:12 AM
  Turn Signal Indicators balkanhound_imp 5 645 04-17-2025, 11:17 PM
  2014 CB1100 Clear Turn Signal Lenses Ngavrielidis1_imp 16 1,450 04-15-2025, 06:23 AM
Last Post: Ngavrielidis1_imp
  Extra turn signal on dash Mixagon_imp 7 732 06-24-2021, 07:20 AM
Last Post: 17-CB-002
  Turn Signal Relocation Cormanus 11 861 12-30-2020, 11:12 AM
  Killing the Buzz - Installing "Even Running" Cam? M3-SRT8_imp 8 719 08-02-2020, 03:17 AM
Last Post: M3-SRT8_imp
  Lockhart Phillips Turn Signals-Lucas Tail Light ChipBeck_imp 43 3,026 04-17-2020, 07:25 AM
Last Post: gman_imp
  Signal Relocation Ben70_imp 7 751 02-20-2020, 10:22 AM
Last Post: Ben70_imp
  Smaller rear sprocket? DBM_imp 11 864 08-14-2019, 10:50 AM
Last Post: jimgl3_imp
  Turn signal relocation -- Making room for my backseat rider JMA_imp 13 1,005 06-15-2019, 12:44 PM
Last Post: QUINTtastic_imp
  Where to tap speed sensor signal? egleaves_imp 93 5,131 10-19-2018, 08:49 AM
