Killing the Buzz - Installing "Even Running" Cam?
M3-SRT8_imp Offline
Threads: 7
It's been a long time, and the 2013 cb1100 runs fine.
Two things I never liked with the bike: The 4-1 Factory Exhaust, which I swapped out for a 4-4 Wyvern.
And the buzzing engine at 3500 to 4500 rpm. I don't like "added" roughness. To me, if it's turbine smooth at all RPMs you did the job right in the first place.
Anybody swap out the factory cam for a smooth running "even" cam, one that also might add a few more ponies?
Lee
08-01-2020, 09:03 AM
peterbaron Offline
Likes Given: 996
RE: Killing the Buzz - Installing "Even Running" Cam?
Yeah, one Canadian member just install front and rear cams, and both were "even"....and after that he once had a very rough time...but he actually lost 1/2 pony due to cams weight Tongue Smile
Now seriously, only PowerDubs and Ben70 played with cams, search the forum :
http://cb1100forum.com/forum/showthread.php?tid=9608
http://cb1100forum.com/forum/showthread.php?tid=15286
..... good luck
08-01-2020, 09:21 AM
IndianRider_imp Offline
Threads: 8
(08-01-2020, 09:21 AM)peterbaron_imp Wrote: Yeah, one Canadian member just install front and rear cams, and both were "even"....and after that he once had a very rough time...but he actually lost 1/2 pony due to cams weight Tongue Smile
..... good luck
I went for a taller gearing with 1 tooth larger in the front and 2 or 3 lower in the rear and the unexpected result was smoother engine at 3500-4500 until 70-75mph with very minor reduction in torque power and no lugging issues .. I can hold the gear longer in the twisties if I want to as well. You may try this before switching the cams
08-01-2020, 11:45 AM
M3-SRT8_imp Offline
Threads: 7
Any link to a cam grinder for smooth cams AND additional power and torque for this bike? Also fuel delivery changes.
I want turbine smooth power. More would be better.
Thanks.
08-01-2020, 09:21 PM
PowerDubs_imp Offline
Threads: 125
(08-01-2020, 09:21 PM)M3-SRT8_imp Wrote: Any link to a cam grinder for smooth cams AND additional power and torque for this bike? Also fuel delivery changes.
Thanks.
Web cams can grind whatever you want, but no promises of what the result will be.
I'd love to pick up a used cyl head to get a close look at the ports and measure to see if the cam timing is the only difference between banks.
If I could go back in time, I would actually pick a more aggressive grind than I did.
Anyone want to trade? Smile
08-02-2020, 01:05 AM
Likes Given: 789
I've never ridden an I-4 that was turbine smooth at all rpms
opposed 4 yes
inline 6 yes
but not an I-4
Not sure it could be done without mechanical trickery. An I=4, although balanced in the primary phase, is not inherently balanced in the secondary phase, therefore causing vibrations
From Wiki
Balance and smoothness
The inline-four engine is much smoother than one- or two-cylinder engines, and this has resulted in it becoming the engine of choice for most economy cars for many years. Its prominent advantage is the lack of rocking vibration, and the lack of need for heavy counterweights makes it easier to be sporty (quick revving up and down). However, it tends to show secondary imbalance at high rpm because two pistons always move together, making the imbalance twice as strong as other configurations without them.
08-02-2020, 01:20 AM
Roper_imp Offline
Threads: 32
As someone who has spent a lot of time riding thumpers, I smile when I read this thread.
08-02-2020, 01:32 AM
Likes Given: 789
ROFL no kidding
ride an old brit single or a Yamaha XS 650 twin and tell me again how bad the vibes are in a CB 1100
08-02-2020, 01:47 AM
M3-SRT8_imp Offline
Threads: 7
Well, if the cb1100's engine was so smooth that it needed roughening up, I would say that's smooth enough.
08-02-2020, 03:17 AM
  The OEM rack "How To" thread doesn't match the 2017 EX TooSlo_imp 15 1,498 02-01-2026, 08:12 PM
Last Post: 1973cb750
  need help installing slip on exhaust nw suburb, IL jm0327_imp 18 1,670 10-25-2024, 12:12 PM
Last Post: iamheero_imp
  finished "forward controls" today Griz53_imp 12 1,027 10-02-2022, 10:44 PM
  How to lower seat for short-legged "freeks" Crossfire_imp 25 1,830 01-30-2022, 06:45 PM
Last Post: jtopiso_imp
  Adapting to 17" CBR wheels? nsrrider_imp 42 3,049 10-10-2021, 11:34 PM
Last Post: nsrrider_imp
  Smaller turn signal/running light choices TxRonHarris_imp 33 2,662 07-06-2021, 10:00 PM
  Intalled DCC 12" Stainless Steel reverse shorty exhaust Garver_imp 10 922 10-13-2020, 03:00 AM
Last Post: Garver_imp
  Honda "Power of Dreams" License plate frames pekingduck 15 1,240 06-01-2020, 11:24 AM
Last Post: TXBikerGuy
  Best performance "mod" ever Bheezy27403_imp 16 1,389 10-09-2019, 05:56 PM
Last Post: the lodger_imp
  Delkevic 9" and a bunch of other small mods - Pictures! x(why)z_imp 32 2,765 09-11-2019, 07:11 AM
Last Post: Bheezy27403_imp
