16,000 Lumens Spot Lights to complement 2017 Led headlights
TXBikerGuy Offline
Threads: 9
RE: 16,000 Lumens Spot Lights to complement 2017 Led headlights
Save you the search. Here's where I recently picked up the 2-pin male connector for the headlight-based accessory plug. [url=http://www.cycleterminal.com/hm-sealed-series-090.html]CycleTerminal
This is a screen shot of the specific plug you want to scroll down and order.
08-12-2020, 02:24 PM
bflint Offline
San Diego
Threads: 72
Likes Received: 24 in 7 posts
Likes Given: 7
Nice set of lights! When riding at night I hate to ride faster than I can see ... Smile
08-12-2020, 02:49 PM
mvk24_imp Offline
Threads: 18
Likes Received: 2 in 1 posts
(08-12-2020, 02:24 PM)TXBikerGuy_imp Wrote: Save you the search. Here's where I recently picked up the 2-pin male connector for the headlight-based accessory plug. [url=http://www.cycleterminal.com/hm-sealed-series-090.html]CycleTerminal
Thanks so much!
08-13-2020, 04:35 AM
17-CB-002 Offline
Threads: 45
(08-11-2020, 05:42 AM)mvk24_imp Wrote: Also did you use a relay and fuse or did you just hardwire it to the switch?
Hi MVK, As a helpful hint, it is preferable to use a mini type fuse holder so that you don't have to carry other style of fuses - If required, you can use the same fuses as used on the CB.
08-13-2020, 04:59 AM
mvk24_imp Offline
Threads: 18
Hi MVK, As a helpful hint, it is preferable to use a mini type fuse holder so that you don't have to carry other style of fuses - If required, you can use the same fuses as used on the CB. Appreciate that, what fuse are you using for these 60w lights?
08-13-2020, 06:18 AM
17-CB-002 Offline
Threads: 45
#26
Using the formulae I = P/E (45W/12v = 4A)
My spot lights are rated at 45 Watts each (x2), so a fuse of 8 Amps should suffice.
Just to be safe, I went up to a 10A fuse.
Also a 7 ft of 18 gauge wire should be able to handle 90 watts easily.
Regards.
Alain
08-13-2020, 12:38 PM
mvk24_imp Offline
Threads: 18
#27
Regards.
Alain
Regards.
Alain Very cool. I could take anything apart and put it back together but electrical is usually a grey area for me!
08-13-2020, 12:56 PM
17-CB-002 Offline
Threads: 45
#28
MVK, if you said that you purchased the same light as mine, where does the 60 watts comes from.
Which model did you get?
Mine is a 9 LED at 45 watts each.
Regards
Alain
08-13-2020, 02:15 PM
mvk24_imp Offline
Threads: 18
#29
(08-13-2020, 02:15 PM)Alain Lee_imp Wrote: MVK, if you said that you purchased the same light as mine, where does the 60 watts comes from.
Regards
Alain
Ah I confused the 45watts and 60$.
I made an offer on an off brand that looked to be built similar to yours and the description said 60watts. I just messaged the seller to find out if it's 60w each or 30w x 2.
These are off brand as I couldn't find the motowolf but these appeared to have the same specs (thinking they were 60w). [Image: e430f9f390c34edc85ab0c1056f4e59d.jpg]
08-13-2020, 02:46 PM
17-CB-002 Offline
Threads: 45
#30
FYI,
I tried to understand the 2017 LED headlight circuit, this is the best I can get to.
Cannot figure out the grounding part.
That's the reason I added a pair of auxiliary spot lights without messing up the factory wiring.
Regards
Alain
[Image: 220d7c04d439c9ff5bdb168b90fa9dba.png]
08-14-2020, 06:24 AM
  Additional front driving lights Davidjill_imp 6 578 08-28-2024, 12:46 PM
Last Post: michael1954
  Where to mount auxiliary lights Gone in 60 42 2,275 04-20-2021, 09:17 PM
  2017 CB1100EX Clearwater Darla Lights Install TXBikerGuy 7 585 07-25-2020, 08:51 AM
Last Post: TXBikerGuy
  Advice on aux Brake lights. hawk123_imp 6 713 08-18-2019, 04:03 AM
Last Post: hawk123_imp
  amber LED fog lights Chuckk_imp 14 1,192 06-20-2019, 01:46 AM
  Choice of Fog /Accessory Lights Ennsync_imp 5 460 10-16-2018, 05:20 AM
Last Post: Ennsync_imp
  Installed Denali D2 driving lights bflint 9 834 08-05-2018, 02:58 AM
Last Post: bflint
  Added Denali Running Lights Mscb1100_imp 3 421 03-27-2018, 12:39 PM
Last Post: Mscb1100_imp
  LED Headlights Spiderwatts_imp 24 1,698 12-10-2017, 06:11 AM
Last Post: Spiderwatts_imp
  upgrade head lights? bflint 4 405 04-08-2017, 02:21 PM
Last Post: bflint
