Fork seal leak
I've heard that Aprilia's parent company Piaggio is an unbelievable pain when it come to dealer support, especially parts supply. (I was informed of this by my local Aprilia dealer.)
Regarding fork seal failures...what exactly happens when this occurs? Does the fork lose compression and gradually lower the front end? Or does it just lose all it's damping ability, etc?
I'm only curious about the consequences: If you're out on a ride, far from home, can you continue to ride the bike?
Jim, a bikes front end is held up by the springs, so it won't collapse. Loss of oil changes the damping on the bike, and a leaking fork seal generally makes a mess of the right fork leg. When the front end is compressed the oil is forced thru tiny holes in the damper rod, as the fork decompresses the oil is drained back thru the holes in the damper rod. I believe I am explaining that right. The spring and air inside the tube controls the compression and the amount of oil, the weight of the oil, and the size and number of holes in the damper rod control the damping.
I'm sure someone much smarter and an engineering background will be along to correct me shortly lol.
Here ya go, found this which may explain everything better than I did
http://racetech.com/HTML_FILES/DampingRodForks.HTML
The bigger concern for me was that it was leaking right onto the brake disc, which would have effectively cut my braking power in half (fortunately this is a dual-disc bike, my Shadow wouldn't have been so lucky...) Mostly I'm just glad I took the bike in to get that accessory removed, who knows when I would have noticed the leak. Very glad to have it back. It's scary to think that there are more powerful bikes out there than this one. 60 in 3.3 seconds is beyond enough for me!
Lol there are bikes out there so much more powerful than this it is almost inconceivable how someone can ride one not on a racetrack. Once they got over 125 horsepower they were effectively too powerful for me. There are some now approaching 200 horsepower. Street bikes. That is insane. Luckily they are all speed limited to only 186 mph Rolleyes
(02-28-2014, 05:53 AM)The ferret_imp Wrote: Lol there are bikes out there so much more powerful than this it is almost inconceivable how someone can ride one not on a racetrack. Once they got over 125 horsepower they were effectively too powerful for me. There are some now approaching 200 horsepower. Street bikes. That is insane. Luckily they are all speed limited to only 186 mph Rolleyes
yeah, those old Busas that would go 192 were pure insanity. What a relief that it was brought down to 186.
According to this page the CB1100 is plenty fast
https://en.wikipedia.org/wiki/List_of_fa...celeration
Although our bike hasn't been added to this page yet. We're at 3.3 seconds to 60 and 11.79 in the quarter mile!
(02-27-2014, 02:15 PM)Jim21680_imp Wrote: Regarding fork seal failures...what exactly happens when this occurs? Does the fork lose compression and gradually lower the front end? Or does it just lose all it's damping ability, etc?
In the vast majority of cases, seal leaks develop gradually. In those cases you can continue to ride, just make sure it's not leaking on the brake.
A few years ago I made a dumb mistake and installed some lower windshield supports too low on my cb750s fork legs. They were fine with just me on the bike, but when I loaded all my gear for a 3500 mile camping/road trip, the front suspension compressed way more than usual under heavy braking. About 500 mi. into the trip, the lower windshield clamps had punched right through the seals. Doh!
I finished the last 3K miles with leaking seals. Handling was still OK. When I finally got around to replacing the seals another thousand or so miles later, there was still 3/4 of the fork oil remaining.
The worst part about leaking seals is the mess.
Pipes covered with burnt fork oil
[Image: 6eb75d4984c64853591971a4af841c5f.jpg]
Lower fork covered with oil
[Image: ccb84cad2e32aaea645dcc15ebd98bf6.jpg]
I even had fork oil on the fuel tank
[Image: 6accf50118512db3d6f02129b22b852a.jpg]
Here's what a pair of jeans looked like after a few days on the highway.
[Image: e3415761262a0ca9c5531fa9459854b7.jpg]
Yuk
All my jeans looked like that when I rode my BSA 750 triple
yeah, those old Busas that would go 192 were pure insanity. What a relief that it was brought down to 186. Yes, we can all rest easy now.
Agree, 125 is about the limit for any sane street riding. Modern superbikes may claim more but the computer won't give it to you in the real world, except maybe in a straight line, to some limited degree.
These days you can buy far more motor than anyone can use, and the computer takes over when your skill runs out.
You hope.
  Slight Oil Leak DutchRutter 22 3,904 05-16-2025, 06:49 AM
  Oil Leak? bvictory_imp 0 213 06-14-2023, 07:05 AM
Last Post: bvictory_imp
  Just found a leak Gone in 60 20 1,343 06-17-2021, 10:18 AM
  slight oil leak Enzofour_imp 3 365 06-07-2021, 12:26 AM
Last Post: michael1954
  Oil Leak - Just got work done and then moved. NickyV_imp 34 2,294 10-15-2020, 02:13 PM
Last Post: max
  fork overhaul vs. fork replacement? misterprofessionality 20 1,714 09-20-2020, 07:13 PM
Last Post: DBM_imp
  Cylinder Head cover oil leak and valve clearance increase. zirconxi_imp 6 641 09-01-2020, 12:19 AM
  Oil leak from pulser cover? skatamutra_imp 4 426 06-14-2020, 07:17 PM
   Oil leak! Help me! steed_boy_imp 43 3,796 02-09-2019, 12:22 AM
  Clutch Cover Removal - How To Break Goo Seal ??? markT_imp 9 714 05-30-2018, 09:30 AM
Last Post: BayAreaRick_imp
