JIS screw drivers
I've had a set of JIS screwdrivers for years, going back to my old Hondas. These days, they're broken out every two years for the brake and clutch fluid flushes.
Now all I need is a set of Whitworth wrenches...
GIN60, this will throw you, took me a while to get my head around this. On the MG TD, the engine and gearbox fasteners are known as "Nuffield Mad Metric." They feature old French Standard Metric threads paired with imperial Whitworth-sized hexagonal heads.
The MG XPAG engine and transmission were built using old French metric tooling from the Hotchkiss factory, which Morris/Nuffield had acquired. The threads are fine-pitch metric, not the standard metric you find in modern hardware. They had to keep the heads Whitworth to keep everyone happy.
The Story behind Whitworth is fascinating and his legacy still has a bearing in England with a Scholarship that still runs today.
In the 18th and early 19th centuries, complex machinery like steam engines and early automobiles required hundreds of fasteners. However, blacksmiths and mechanics created their own taps, dies, and thread profiles. If a bolt broke, you couldn't simply buy a replacement from a different factory; you had to have the exact machine shop that built the bolt forge a new one.
Sir Joseph Whitworth recognized the inefficiency of this system and began collecting samples of screws from workshops across England. Using these samples, he designed a system that struck a middle ground. His 1841 proposal to the Institution of Civil Engineers specified:
  • A standardized thread angle of 55°.
  • Defined thread pitches (threads per inch) for various diameters.
  • Rounded roots and crests, which reduced stress risers and made the bolts significantly stronger.
Whitworth's system allowed manufacturers to buy compatible nuts and bolts from different suppliers, revolutionizing global mass production. The Royal Navy's Crimean War gunboats were one of the first major projects to utilize these mass-production techniques with standardized parts.
"You can only make as well as you can measure"
       - Sir Joseph Whitworth
       - Sir Joseph Whitworth "You can only make as well as you can measure"
Fine looking CB1100, Tev! Smile
Very informative, Tev! I had just visited a good friend who restores early Phantoms. I was using his drill press and bench grinder to whip up a few box mounting plates for our company bikes. The tool chest nearest to the drill was labeled Whitworth, and his collection is necessarily impressive for his work.
Plus, I get the question at my other job… “are these metric?”
Attached Files Thumbnail(s)
Thanks, Tev. A bit of history that helps me understand a basic system I had always taken for granted. Getting a bit more educated after 85 years.
There's a difference in riding a naked bike and riding a bike naked.
Won't make that mistake again.
2013 Honda CB1100 Standard. Gone, but not forgotten.
Since we're on the topic of JIS screw drivers, and it may be another twelve years till we return to the topic,  Big Grin I have a question:
I stripped a bolt head or two on my CL175 before I realized JIS was a thing.  Bought some JIS driver bits, and resumed the job using the correct JIS bit and an impact driver.  I stripped even a perfect bolt head using the JIS bit and driver (and a good amount of pressure).
So, I drilled out all three stripped bolt heads which held on the the clutch cover.  To my amazement, after the heads were drilled off, the remaining bolts came out easily by hand, all looking shiny and new.
My question is, did the bolt heads corrode and freeze themselves to the clutch cover over 56 years, while the threads remained in perfect condition?  Is this common?  Is it better to use a hand JIS screw driver rather than an impact driver?  If an impact driver, more pressure or less?
I'll probably replace all the JIS with hex head bolts eventually, but I would like to not have to drill out every bolt head.
I had a similar issue on one of the BMWs recently, Lunchbag. Not a 56 year old bike, but 11 years old. Not sure what BMW uses to make their screws, but they're all T-25 Torx, have varying shoulders depending on how many layers of plastic body parts they are supposed to secure, and are very prone to stripping. Just slightly magnetic, so they're not completely stainless. There's one screw in particular that holds on a lower body panel on the right side that's frozen on all of the bikes I've worked on. I imagine water must collect at that low point and creates just enough corrosion to make the screw not want to budge. I have learned to work around that one and pivot the body panel out of the way on that screw to access the battery and main electronics.
Anyway, before I learned to leave this one alone, I stripped, then drilled out the screw head. The shaft of the screw then came out by hand and was clean and shiny. I think maybe because I had already squirted some penetrating lubricant all over it, then the vibration from the drill massacring the upper portion of the screw must release whatever was holding it to the frame.
  Sight Glass Screw Mickey Dublin_imp 16 1,395 11-22-2023, 08:25 AM
  Brake reservoir screw head issue satchit 72 4,483 04-24-2022, 11:55 PM
  Dealing with a stuck JIS screw Stichill_imp 28 2,071 06-27-2021, 10:21 AM
Last Post: Stichill_imp
  JIS Cross Head Screw Drivers 2017EX_imp 15 1,208 04-15-2020, 01:53 AM
  Speedometer Allen Head screw loose mhicks17_imp 1 233 09-15-2018, 02:55 PM
Last Post: max
  JIS Screw Drivers & Screw Driver Bits 2017EX_imp 8 676 06-04-2018, 12:22 PM
   Beam adjustment screw :) Riko_imp 13 980 06-11-2017, 10:50 PM
Last Post: White Dog_imp
  screw in front tire Krupator_imp 25 1,344 06-20-2016, 11:10 AM
Last Post: pw363_imp
  Crankshaft Balancer backlash adjustment screw tomas_imp 12 820 05-17-2016, 07:28 AM
Last Post: furious_blue_imp
  Idle screw? Jayimpalaman_imp 12 940 05-05-2015, 04:34 AM
Last Post: 1953andrejrigoli_imp
