 Beam adjustment screw :)
Did any of you know of the Beam adjustment screw? Smile
Part 4 in the exploded view:
[Image: a141590fc1cda9bf9e0ca15812871d1c.png]
http://www.bike-parts-honda.com/pieces-h...S+ABS.html
picture of the screw
[url=https://picoolio.net/image/IdGY][Image: fef5bff2f553db4cfd57c60ceab82781.jpg]
centered
[url=https://picoolio.net/image/IdGc][Image: 4d5aff060b121d9b87edf9fd67114714.jpg]
aimed to the left
[url=https://picoolio.net/image/IdGa][Image: 20337d1c20f0dd77dbcafd3badc34d19.jpg]
aimed to the right
[url=https://picoolio.net/image/IdGt][Image: 9abb8ba964a0c88c8d60689653a3cc09.jpg]
So it allows a vertical adjustment rather than the known horizontal adjustment.
Edit: you can click on the pictures so they are much bigger
This is like a Where's Waldo..all the pics look the same to me Dodgy
pfff guess i have to re up them and use Paint to show the different ANGLE of the headlight
but even on those thumbnails you can see the difference...
Fixed Angel
centered
[url=https://picoolio.net/image/IdQd][Image: 6c65d34635db4cd3504e9e21ef93209b.jpg]
aimed to the left
[url=https://picoolio.net/image/IdQI][Image: dd44d4a9ee423c4669abfdfe29fc9f28.jpg]
aimed to the right
[url=https://picoolio.net/image/IdQq][Image: 66a81dbaba2637d47477b077323b8897.jpg]
I saw the difference without the red line(s), but how is the vertical vs horizontal alignment accomplished - "So it allows a vertical adjustment rather than the know horizontal adjustment." I assume you meant "known"
my bad, edited Smile
yep you can adjust by turning the crosshead screw, hence the picture of a screw Smile
Hmm I was looking at the hand and camera reflection and that white line, and they all looked the same. Didn't notice the rim pivoting horizontally, although I clearly see that now. However, I also don't understand how the horizontal adj has anything to do with the vertical adjustment.
On a bike where the headlight turns with the bars, I was at first baffled as to why Honda thought this adjustment was necessary. But the more I thought about it, I guess it makes good sense. Even if they attempted to make them perfectly straight from the factory, could there be a margin of error? This allows each bike to be adjusted to a suitable or desired precision.
Though I hate to admit it, I found this adjuster screw by accident. When I first went to disassemble the lamp to install the LED, I started here first.
After turning and turning and turning for what I found to be much too long of a time, there it was.....my headlamp was awkwardly turned hard to the left.
Definitely one of those "ah ha" moments.
(02-12-2016, 10:50 AM)The ferret_imp Wrote: Hmm I was looking at the hand and camera reflection and that white line, and they all looked the same. Didn't notice the rim pivoting horizontally, although I clearly see that now. However, I also don't understand how the horizontal adj has anything to do with the vertical adjustment.
it has nothing to do with it Smile I was just mentioning that there are 2 adjustment options for the direction of the headlights.
Adjust up and down at the 'ears' its horizontal
Left to right adjustment is vertical....
(02-12-2016, 11:48 AM)Bob Sdaman_imp Wrote: On a bike where the headlight turns with the bars, I was at first baffled as to why Honda thought this adjustment was necessary. But the more I thought about it, I guess it makes good sense. Even if they attempted to make them perfectly straight from the factory, could there be a margin of error? This allows each bike to be adjusted to a suitable or desired precision.
indeed, i thought it was funny when i discovered that tweak option Smile
I accidentally discovered it too when removing the headlight assembly Smile
Man, I really misread this thread. When you said
"So it allows a vertical adjustment rather than the known horizontal adjustment."
I thought you were talking about that screw allowing a vertical adjustment.
my bad
English, tough language
I haven't done it, but I assume the vertical adjustment is done by the headlight case side mounting bolts/screws.
  Valve Adjustment Shims dave 13 710 07-28-2026, 12:49 PM
Last Post: MagnaRider
  JIS screw drivers Ridem32_imp 26 1,733 06-12-2026, 06:56 PM
  Valve Adjustment and Camshaft Removal dave 5 637 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 869 08-29-2025, 10:46 AM
  Valve Adjustment Intervals CBRider_imp 32 3,039 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Rear Brake Pedal Adjustment Gone in 60 12 1,163 04-04-2024, 08:18 AM
  Sight Glass Screw Mickey Dublin_imp 16 1,620 11-22-2023, 08:25 AM
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,558 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Front forks adjustment Olyrider 5 528 05-16-2022, 11:04 PM
Last Post: Sparky80_imp
  Brake reservoir screw head issue satchit 72 5,435 04-24-2022, 11:55 PM
