2013 Optional ABS VS 2014 Deluxe ABS
Honda actually builds 3 ABS systems. The linked brakes on the gold wings and ST 1300's uses a secondary master cylinder on the left front caliper which is on a pivot and works automatically when the front end compresses. It is a very complicate system and Honda has had some trouble with it with 2 recalls on the Goldwings and many unhappy ST 1300 owners.
Ferret,
I had to run out to my garage and check out the left front fork on the ST. I never noticed that smc on there. It looks weird... Gonna have to read up on that.
I was always of the impression that the ABS systems between the 2013 and 2014 were different. I was never under the impression that the 2014 system was linked. I obviously read it some where as in my mind I believed the 2014 ABS was a little inferior but simpler than the 2013 version.
Think I found the answer. See link below, it appears the DLX may have a new "Electronically Controlled Combined ABS" system that allows use of the standard hydraulics/calipers, greatly simplifying the system while reducing unsprung weight. Since it's electronically controlled and the owners manual says the light doesn't go out until 6 mph, you probably can't test it by spinning the wheels on the center stand.
http://world.honda.com/motorcycle-pictur...BS/detail/
Just so you know, the speed sensor is on the rear wheel. Well, the sensor is not...
The ABS models have speed sensors on both wheels, ABS kicks in when the control unit senses a difference in front/back wheel speeds.
(04-25-2015, 11:35 AM)BestStandard_imp Wrote: Think I found the answer. See link below, it appears the DLX may have a new "Electronically Controlled Combined ABS" system that allows use of the standard hydraulics/calipers, greatly simplifying the system while reducing unsprung weight. Since it's electronically controlled and the owners manual says the light doesn't go out until 6 mph, you probably can't test it by spinning the wheels on the center stand.
Hmmm it says its used on Honda Supersport bikes which I would assume would be 600 and 1000 RR models. Doubt the CB 1100 falls under the supersport header, but I suppose it's possible. like I said I am trying to learn here as well. let me dig some more.
(04-25-2015, 11:44 AM)BestStandard_imp Wrote: The ABS models have speed sensors on both wheels, ABS kicks in when the control unit senses a difference in front/back wheel speeds.
I understand. But don't both ABS and NON ABS run the speedometer from the rear?
to add: I can run the ST on the center stand and it reads speed. It has ABS.
Ok heres the info from Honda on the CBR1000RR and CBR600RR which fall under the Supersport heading on Hondas website
Available Combined Anti-Lock Braking System (Electronic C-ABS)
Electronically controlled C-ABS distributes brake force over both wheels, helping to maintain braking confidence in less-than-ideal conditions. The system electronically measures rider input on the brake lever and pedal, and applies only the front or rear brake in some cases or combines both brakes in other situations. (Not available on CBR1000RR SP model.)
So I think this system relates just to those models
Your probably right, they would have listed it in the specs if it had the Electronically Controlled Combined ABS system... say that fast three times!
  2014 Deluxe, 65K miles spruce up. bflint 6 711 08-14-2025, 07:37 PM
  Can a 2013 centerstand be installed on a 2014? WRXer_imp 1 259 11-19-2023, 04:24 AM
Last Post: WRXer_imp
  2013 versus 2014 wheel size Houtman_imp 19 1,579 10-08-2021, 05:11 AM
  2014 CB1100 Deluxe No front brakes Roger the shrubber_imp 16 1,028 08-05-2021, 02:01 AM
  Two Brothers M2 - 2013 specific on a 2014? B Api_imp 1 240 06-14-2021, 11:57 PM
Last Post: cj599_imp
  Adreani inserts for 2013/2014 ? Houtman_imp 20 1,297 05-05-2021, 04:59 PM
  Does a 2014 have an optional power source? FLYTYM_imp 4 367 09-23-2019, 01:10 AM
   Deluxe seat on 2014 Standard FLYTYM_imp 4 849 06-04-2019, 07:54 PM
Last Post: FLYTYM_imp
  2013/2014 switchgear spartanheed_imp 2 278 04-23-2019, 04:23 AM
Last Post: spartanheed_imp
  Weight of the OEM Wheels on the 2013/2014 std models? misterprofessionality 7 535 04-04-2019, 09:24 PM
