 Tire inflator, compressor: questions...
I went with this model: http://www.pashnit.com/product/cyclepump.html
Seems a bit wimpy, but does work. I wish it had more oomph. Otherwise; it comes with good rep.
Slime has a decent reputation, good choice. Get a good tire gauge also, and use it. I've grown accustomed to the digital ones but carry an old school "sliding stick" under the seat. No compressor with me so I don't know why I carry the gauge.
For a very long extension cord to your outdoor shed go to an industrial supply house (or online) and get a 10/3 cord in 100 ft.
Old buddy is a tire engineer for Goodyear, he is the reason I check air pressure in all of our vehicles religiously. Amazing how much longer the tires last when properly inflated.
Ural comes with a hand pump as part of it's tool kit - extensive kit that uses only the highest quality imitation Russian steel.
(01-09-2016, 01:03 AM)4 Paws_imp Wrote: Slime has a decent reputation, good choice. Get a good tire gauge also, and use it. I've grown accustomed to the digital ones but carry an old school "sliding stick" under the seat. No compressor with me so I don't know why I carry the gauge.
Ural sounds top notch...
And yes, I have a digital tire gauge.
My Slime rechargeable compressor came in the mail today... Got the thing plugged in and charging now. Will check and adjust my girls' tire pressure tomorrow.
Checked tire psi: In 3 weeks the front lost 4.0 psi. The rear lost 6.4 psi. Seems a bit high, although the bike (and tires) are still in a period of break-in, so it's possible that will slow some.
Got my new rechargeable compressor yesterday and used it for the first time. Also, the first time trying to adjust the psi on my new CB1100. The compressor has a lot of pumping power but I had a very difficult time uncoupling the nozzle from the valve stem on the front wheel. This resulted in a big loss of tire pressure before getting the dang thing off. I had to re-try 4 times before I was able to get the thing off quickly enough to not drain the front tire below the recommended 36 psi. PHEW! I had to develop a bit of a knack for getting it uncoupled 'fast'. During this pump fest, I filled the front to close to 40 psi knowing I was going to lose air...
The rear went a bit better - I had more room to work, and by then I knew enough to do a slight over-fill to make up for loss on coupling removal.
It was a Chore, to say the least.
Final result: F 36 psi, R 42.5 psi
All bikes should come with those wonderful nozzles with a 90º bend.
For all my bikes I pick up a set of 83 degree 11.3 mm Gen 2 angled valve stems from Kurveygirl.com They run about $30. I have a set in my toolbox now ready to go on the next time I get tires (sometime this spring I suppose). Makes checking and adding air sooo much easier.
Quietguy,
Seems like the (stock, at least) tires leak when new, then settle down to a pretty reasonable loss rate. Mine did.
(01-02-2016, 02:32 PM)Pauley_imp Wrote:
(01-02-2016, 01:11 PM)Flynrider_imp Wrote:
(01-02-2016, 10:56 AM)EmptySea_imp Wrote:
(01-02-2016, 09:13 AM)Pete Erickson_imp Wrote:
(01-02-2016, 09:05 AM)Cormanus_imp Wrote: I dunno, you blokes in the US get it easy— http://www.kathmandu.com.au/cycle-floor-...-blue.html
That is what I use and I have power in my garage. It only takes a few pumps to top the tires off.
+1. Bought a compressor and found that it's way easier to use a good bicycle pump like this one. Plus, a bike much more neighborly when filling tires per-dawn. I'm still going to purchase a portable electric pump for the road.
I bought this one.
http://www.amazon.com/Slime-40001-Motorc...B000ET9SB4
Fits under the seat and can be powered directly from the battery.
I bought this one.
That's the same one I carry around in my tail bag. I tested it in the garage once, but have not used it "for real" yet.
I bought this one.
That's the same one I carry around in my tail bag. I tested it in the garage once, but have not used it "for real" yet. Now that you have it along with a tire plug kit in your tail bag, chances are you'll never need it. Now if you didn't have it...
BTW popgun, if you don't already have the 83 degree stems on your ST you really NEED a set of them, especially for the rear tire.
  Basic Questions About Dynoject V on 2017 CB1100EX dougwene_imp 9 887 12-29-2024, 03:22 AM
Last Post: Karidis
  More oil questions Maturecheese_imp 10 776 06-27-2023, 03:53 AM
  Fuel tank interchangeability? Model difference questions.... 2014ltdltz 5 673 10-12-2020, 11:59 PM
Last Post: 2014ltdltz
  Chain & Sprocket Questions arse-onist_imp 12 880 08-14-2019, 09:39 PM
  Air compressor question 562loosenoodle_imp 39 2,795 03-30-2019, 08:27 PM
  OEM Fuel Tank Replacement Questions suhawk305 18 1,079 09-02-2018, 02:28 AM
Last Post: suhawk305
  Side engine cover questions. pedro_k_imp 10 561 08-22-2018, 11:57 PM
  Questions. In General MrJayGLA_imp 6 468 07-30-2018, 03:17 AM
Last Post: HansenCB_imp
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 940 07-18-2018, 06:50 AM
Last Post: SportsterDoc
  Questions For Moriwaki 4 Into 4 Owners 2017EX_imp 1 221 07-11-2018, 08:55 AM
