Hauled bike out of storage wont start.
Oboro,
I'll send it tonight after work.
Email sent
Have you tried with the second key? Does the HISS light disappear when ignition on? Could be the antitheft system...
(05-07-2016, 02:04 AM)Speed_imp Wrote: Have you tried with the second key? Does the HISS light disappear when ignition on? Could be the antitheft system...
We don't have that in North America.
Any news, Oboro?
Cormanus, does your bike have the HISS?
Yes it does.
Fault finding section in the manual says possible MAP sensor failure. Sensor is mounted on the front air filter housing and has a vac hose attached. Reseat the connector and make sure vac hose is ok.
I've been following this thread with interest because my CB has been in winter storage since last November.
One year ago around this time I rolled it out for the season and it started instantly.
I rolled it out a few minutes ago for this season and just before I touched the starter I thought about this thread.
But I didn't have to worry as she roared to life instantly.
I'm not gloating or rubbing salt in the wound, just making an observation Big Grin
Does it run on an alternative fuel source? As in- remove the air filter and spray starting fluid. If not, try clear flood (full throttle) as previously mentioned.
Curious to hear results.
  High engine revs on start up CBX1000_imp 21 1,969 06-06-2024, 02:40 AM
  CEL after Jump Start rage91_imp 23 1,777 04-14-2023, 01:25 AM
  Oiling cylinders for winter storage? Searcher_imp 5 547 01-26-2023, 08:33 AM
Last Post: ichiban_imp
  Won't start RLS_imp 5 485 05-12-2022, 05:58 AM
Last Post: RLS_imp
  (End of) Winter Storage Wagonpeddler_imp 26 2,126 04-04-2022, 01:18 PM
Last Post: michael1954
  CB 1100 won't start GeorgiaRider_imp 30 2,361 12-19-2020, 11:19 PM
  Low rattle on cold start. shahyaan_imp 22 1,722 11-30-2020, 12:01 AM
  2013 cb1100 Left Directional Light wont cancel. M3-SRT8_imp 15 1,223 08-01-2020, 07:16 PM
Last Post: max
  Bike crank but wouldn't start. zirconxi_imp 67 4,508 04-25-2020, 01:37 AM
Last Post: White Dog_imp
  strange start pdedse 48 2,931 02-02-2020, 06:34 AM
