Low rattle on cold start.
Heya
Is it normal for the CB to rattle a tad bit when cold? This engine is so smooth and quiet compared with my Harley. I’m guessing it’s the valve clearance that then shrinks when warm.
At 1,000rpm at idle, a given valve will cycle open and closed at just over 8 times per second (8 & 1/3 Hz, or approx every 1/8th of a second). If the clearance is too loose or there is insufficient oil pressure for some reason, the valve will click.
Find yourself an engine stethoscope and see if you can identify the area the sound is coming from.
Between the injectors, valves, and all the moving bits, including external stuff like the PAIR valve, there are plenty of sources for minor ticking.
(11-09-2020, 02:56 AM)LakeWylieJoe_imp Wrote: At 1,000rpm at idle, a given valve will cycle open and closed at just over 8 times per second (8 & 1/3 Hz, or approx every 1/8th of a second). If the clearance is too loose or there is insufficient oil pressure for some reason, the valve will click.
This is usually during the warm up phase so idle is higher. Once the bike is warm I don’t notice it.
I don't believe it is normal, though whatever it is, it might not be harmful. A valve with too much lash might tick, but likely not "rattle." The advice above to use a stethoscope when it is cold and making noise is sound advice.
(11-09-2020, 09:52 PM)apex1_imp Wrote: I don't believe it is normal, though whatever it is, it might not be harmful. A valve with too much lash might tick, but likely not "rattle." The advice above to use a stethoscope when it is cold and making noise is sound advice.
I guess it could be described as a ticking. That’s a better choice of words over rattle.
My engine has 35,000+ miles on it. The valves are all center of spec range (checked and adjusted every 8,000). My engine has no ticking at all when I first fire it up cold. It develops little ticks from several places as it warms up. I attribute this to the oil (Honda GN4 10W-30) getting thinner with the heat. It's done this since brand new. All the noises are quite subtle, though.
(11-10-2020, 02:55 AM)LakeWylieJoe_imp Wrote: My engine has 35,000+ miles on it. The valves are all center of spec range (checked and adjusted every 8,000). My engine has no ticking at all when I first fire it up cold. It develops little ticks from several places as it warms up. I attribute this to the oil (Honda GN4 10W-30) getting thinner with the heat. It's done this since brand new. All the noises are quite subtle, though.
Ok looks like I’ll need to investigate.
Based on my experience, I generally concur.
Actually now I read it in detail. It could be oil as well. Oil is a bit old from previous owner not using it much. I was planing on doing a quick oil change.
I’ll have to decide on the ideal choice for this bike. At the risk of starting another oil debate may go semi synth within the temperature range for my location.
(11-10-2020, 03:41 AM)shahyaan_imp Wrote: Actually now I read it in detail. It could be oil as well. Oil is a bit old from previous owner not using it much. I was planing on doing a quick oil change.
I always used 10W40, and initially Honda GN4. I changed to semi and then full synthetic and the engine was quieter and clutch [even more] buttery.
(I think the statement covers much of the oil genre.)
  Rattle on right side exhaust / battery CB1100i_imp 4 683 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  High engine revs on start up CBX1000_imp 21 1,812 06-06-2024, 02:40 AM
  2017 tail light rattle Venteuri_imp 2 387 05-14-2024, 05:55 AM
Last Post: Venteuri_imp
  CEL after Jump Start rage91_imp 23 1,581 04-14-2023, 01:25 AM
  Won't start RLS_imp 5 462 05-12-2022, 05:58 AM
Last Post: RLS_imp
  Rattle-can Magic Phadreus_imp 4 388 08-30-2021, 04:35 AM
  CB 1100 won't start GeorgiaRider_imp 30 2,057 12-19-2020, 11:19 PM
  Rattle when going over bumps. cheddarcheese_imp 15 1,067 06-15-2020, 12:00 AM
  Cam chain rattles when cold Speed_imp 24 1,562 05-28-2020, 05:41 AM
  Bike crank but wouldn't start. zirconxi_imp 67 3,921 04-25-2020, 01:37 AM
Last Post: White Dog_imp
