01-04-2019, 09:06 PM
+1 loosen chain adjuster. if that doesn't work, it's almost surely the alignment of the brake part causing binding.
Rear Wheel problems
01-05-2019, 07:08 AM
Rear wheel issues: Clean and lube axle and holes it will go thru, pass axle through wheel alone and then through swing arm with rear brake in place, should be easy pass, no binding. Assuming bike is on center stand, jack up front end as you would to remove front wheel, and adjust height so swing arm and real wheel holes line up.
Slide the axle in. This an easy one person job.
01-05-2019, 09:16 AM
Success
![]() Thank you all for the help and tips. ![]()
01-05-2019, 09:26 AM
Sweet! Congrats!
01-05-2019, 09:48 AM
Positive feedback; awesome thanks sfmoto and best of luck to you!
Happy newyear.
01-05-2019, 10:26 AM
Excellent, congrats!
01-05-2019, 11:31 AM
Great news. Go riding now.
01-05-2019, 12:51 PM
Very good Sfomoto.
01-05-2019, 12:53 PM
During all the years that I have owned Honda motorcycles I have come to the conclusion that if something does not fit WE do something wrong.
01-05-2019, 12:55 PM
« Next Oldest | Next Newest »
| Front wheel bearing noise? | MagnaRider | 20 | 1,739 |
03-31-2026, 08:20 AM Last Post: peterbaron |
| This is why wheel bearings are failing | 1973cb750 | 3 | 354 |
02-05-2026, 08:11 AM Last Post: 1973cb750 |
| CB11OO EX wheel rims | sprint | 6 | 655 |
02-26-2025, 06:16 AM Last Post: Cormanus |
| 2014 rear wheel knocking noise | dunebuggy_imp | 7 | 955 |
08-05-2024, 03:33 AM Last Post: Yata-Garasu_imp |
| Delkevic 9" Oval Install Problems. | jbird06_imp | 4 | 462 |
06-11-2024, 08:25 AM Last Post: devildogdoc_imp |
| Light problems/electrical | Dude_imp | 6 | 573 |
09-13-2023, 07:21 PM Last Post: Dude_imp |
| Wheel sensors | The Gecko_imp | 48 | 3,927 |
07-27-2023, 03:51 AM Last Post: The Gecko_imp |
| 2013 replacement wheel | Randy B | 8 | 783 |
11-13-2022, 10:32 AM Last Post: Randy B |
| wheel imbalance | j3gq_imp | 7 | 643 |
07-03-2022, 09:35 AM Last Post: GoldOxide_imp |
| Kink in rear (spoked) wheel | Ayrshire Dunx_imp | 1 | 262 |
04-09-2022, 09:37 PM Last Post: GoldOxide_imp |
