Adjusted valve clearances. Now it's clicking...
Jurlie, if you go to the bottom of the page showing your photo at imgbb you'll see a tab that says <Embed codes>. Click on it, hover over the bit under <Full Image> which says BBcode and then either select it all or click on the <copy> box at the end of it. Paste the result into your forum post and the image will be displayed on the forum.
(08-15-2019, 04:30 PM)Cormanus_imp Wrote: Jurlie, if you go to the bottom of the page showing your photo at imgbb you'll see a tab that says <Embed codes>. Click on it, hover over the bit under <Full Image> which says BBcode and then either select it all or click on the <copy> box at the end of it. Paste the result into your forum post and the image will be displayed on the forum.
Thanks Cormanus for editing and hint.
Sorry for late update...
I've decided not to disassemble what I dodn't touch previously; I've just opened the cylinder head cover yet again, measured valve clearances again, put everything back together, started the engine and... No ticking!
My optimism little bit lowered when I went for ride, as there was subtle ticking during agressive acceleration, and nane otherwise. I still don't understand what is it, but since it became subtle and rare, I decided it shouldn't be anything dangerous. Maybe in 12k, when it will be time for next clearance check, I'll open the PAIR valves compartments for check.
Now feel much more confident in doing mechanical jobs.
(08-26-2019, 04:11 PM)Jurlie_imp Wrote: Sorry for late update...
Some ticking during hard acceleration is normal. It's the fuel injectors.
Good to hear. Thanks!
I can't hear any [ticking] during hard acceleration. Smile
I can’t hear anything during hard acceleration. Big Grin
Jurly did you ever find that 10mm socket that was missing after the adjustment?
Just kidding but glad it went away, still wondering what it could have been.Huh
(08-27-2019, 11:40 PM)max_imp Wrote: Jurly did you ever find that 10mm socket that was missing after the adjustment?
Good joke! You made me think for a couple sec if I forgot anything inside. Big Grin
For guys who cannot hear ticking: I forgot to mention, you need to start the engine to hear it.
ROFL
  Valve Adjustment Shims dave 13 709 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 634 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 867 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 946 07-26-2025, 11:27 AM
Last Post: bflint
  Valve Adjustment Intervals CBRider_imp 32 2,998 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Engine clicking/ticking metallic noise! WTF? Tortuga_imp 28 2,332 10-11-2024, 04:53 AM
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,541 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Observed Valve Clearance Cormanus 16 1,452 03-06-2023, 09:03 AM
Last Post: Tejas_imp
  The OBSERVED Valve Clearance thread Pterodactyl_imp 162 13,065 12-27-2022, 08:35 AM
  Checking valve clearances Maturecheese_imp 74 6,558 12-11-2022, 12:56 PM
