Stock Suspension Adjustment
Go to any motorcycle shop, or motorcycle junk yard, and ask if they have any old tool kits laying around. They used to come standard in old tool kits.
(10-03-2019, 12:25 PM)The ferret_imp Wrote: Go to any motorcycle shop, or motorcycle junk yard, and ask if they have any old tool kits laying around. They used to come standard in old tool kits.
(+1) At a m/c junk yard, reach down into the mud and pull up a suspension wrench.
Mate, you’re desperate if you have to pull seals.
If this attempt at humour falls flat outside the UK, I’m sorry.
(10-01-2019, 03:52 AM)riggies_imp Wrote: what direction on the rear do I need to go to set it up for a heavier rider?
The easiest way for me to adjust to heavy rider is to "Leave the wife at home!!!!"
I adjusted the preload of the front and rear to the max setting. It makes hardly any difference from what I can tell. I just need to work on some personal weight loss mods...
(10-10-2019, 10:25 AM)riggies_imp Wrote: I adjusted the preload of the front and rear to the max setting. It makes hardly any difference from what I can tell. I just need to work on some personal weight loss mods...
lol - that can be some of the most difficult projects!
(10-01-2019, 03:17 AM)riggies_imp Wrote: Is there a way to adjust the stock suspension for a heavier rider? It looks adjustable, but Since I have no idea what I am doing with it I was going to defer to you guys. 220 pounds geared up I am, I’m not going to spend any money on new fork oil or springs. So, is there any preload or sag I should adjust on the stock suspension? Thanks!
Ferret is 240lbs naked!
You'll be fine!
Lol no I'm not. I'm only 180 , probably close to 200 geared up. I just look heavy cause I'm so short.
(10-16-2019, 12:02 PM)The ferret_imp Wrote: Lol no I'm not. I'm only 180 , probably close to 200 geared up. I just look heavy cause I'm so short.
LOL just kidding my friend! ....."cause I'm so short" LOL again! Would love to have a beer with ya one day!
  Valve Adjustment Shims dave 13 666 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 616 03-21-2026, 04:49 PM
  Stock Cylinders dave 5 868 10-14-2025, 10:41 AM
  Valve Adjustment dave 6 852 08-29-2025, 10:46 AM
  How much do stock pistons weigh? jikemenkins 4 641 04-28-2025, 10:06 PM
Last Post: Whoops
  Valve Adjustment Intervals CBRider_imp 32 2,804 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Rear Brake Pedal Adjustment Gone in 60 12 1,114 04-04-2024, 08:18 AM
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,477 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Front forks adjustment Olyrider 5 487 05-16-2022, 11:04 PM
Last Post: Sparky80_imp
  Stock handlebar measurements misterprofessionality 5 558 04-12-2022, 05:47 AM
