How to empty the fuel tank?
This is a lot of thinking and labor to defuel a tank. I use a length of clear hose with primer bulb near the outward end. Stick the suck end into the tank, to the lowest point of the tank, put the discharge end into the container, pinch the hose closed with a pair of pliers, and squeeze the bulb a few times. Be sure you are working the bulb in the right direction. There is an arrow on the bulb to show fuel flow direction. When the hose is full of fuel, let go of the pliers and the fuel will begin to flow.
Picked [url=https://www.autozone.com/test-scan-and-specialty-tools/fluid-pump/performance-tool-rubber-siphon-hose/147205_0_0]this up last night at Autozone for $4.00 and it drained about 4 gal out of my 2017 tank just fine. Total time may have been 15 minutes or so from the time I opened the package to the nearly empty tank. Draining time was half of that or less.
It's exactly the level of quality you'd expect for $4. But it worked.
Note on the 2017 tank (I haven't seen the others so don't know if this applies.) There is only 1" (maybe 1.25") of vertical space from the filler spout opening hole to the bottom of the opening (see pic.)
That's not a lot of space for maneuvering things around to get down into the tank. For example, I have it on good authority that the brass fitting on the Original Super Siphon is exactly 2.5" long. It doesn't work on this tank. Related, let me know if you may have a different use for a never-used Original Super Siphon. I know where you can find one.
without going thru all the posts, did you try a squeeze bulb?
(07-20-2020, 03:12 AM)Charlie Bravo_imp Wrote: without going thru all the posts, did you try a squeeze bulb?
Yep. That's what I linked to and attached a picture of. Cheap little squeeze bulb option from Autozone. Don't know how long it will last or work--but for $4 it got what I needed done. Big Grin
  CB1100RS fuel tank rust Narciso 12 1,352 09-27-2025, 02:06 PM
Last Post: tdbru
  CB1100 fuel tank upgrade johnnyH_imp 3 445 03-13-2024, 01:31 AM
   Resistance of Fuel Tank 2014CB1100 itsok_xman_imp 7 652 04-01-2021, 02:34 AM
Last Post: itsok_xman_imp
  Fuel tank interchangeability? Model difference questions.... 2014ltdltz 5 691 10-12-2020, 11:59 PM
Last Post: 2014ltdltz
  Fuel Tank Removal Gabby_imp 11 923 06-19-2020, 10:54 AM
  Fuel Tank overflow drain tube. zirconxi_imp 11 888 05-29-2020, 11:36 AM
Last Post: LakeWylieJoe_imp
  What's living in your fuel tank? max 4 363 11-05-2019, 08:42 AM
  OEM Fuel Tank Replacement Questions suhawk305 18 1,099 09-02-2018, 02:28 AM
Last Post: suhawk305
  Best way to drain fuel tank? Rebel73_imp 10 646 08-08-2016, 08:18 AM
Last Post: Rebel73_imp
  Empty oil filter LongRanger_imp 1 227 06-15-2016, 11:03 AM
Last Post: Ulvetanna_imp
