connection to control unit with OBD
(11-18-2020, 01:04 PM)GoldOxide_imp Wrote:
(11-18-2020, 09:22 AM)bflint_imp Wrote:
(11-18-2020, 07:03 AM)peterbaron_imp Wrote: Good to know about the other member who has that scanner ...in case if I am stuck on the road Big Grin
Beer
Absolutely. Also, I know there are some other members in the San Diego area so they would be welcome to use it .
That would be interesting to witness [url=http://cb1100forum.com/forum/member.php?action=profile&uid=3454]PB.
One would have to wait for this until eternity Tongue
...but I can tell you, bflint is a good man and willing to share his equipment
Thumbs Up
(11-17-2020, 01:10 PM)GoldOxide_imp Wrote:
(11-17-2020, 06:30 AM)Lord Popgun_imp Wrote: That is what I have. It works with a Windows computer. The only thing I have used mine for so far is data gathering for the idle problems some were having. It works with Hondas and even some outboards. I have a Honda outboard so that’s a plus! Haven’t tried it on the outboard though.
They also keep the software updated and you can update it when connected to the internet.
It connects to the red diagnostic connector located behind the left side panel.
I have seen that used with other late model Honda owners too.
I use this:
... and Bluetooth connect it to the "Torque Pro" app running on Android. It all works very well.
The blue OBD2 dongle also works in every car I've tried (e.g. Honda, Kia, Dodge, Toyota, etc.).
I use this:
great! do you have the code of the cable?:timido:
Beer
Thumbs Up
Thumbs Up
I have time, I'm only 71:timido:
(11-18-2020, 06:59 AM)bflint_imp Wrote: Noticed Mr Lord Popgun had previously bought HealTech OBD tool, so I ordered their OBD-H01 scanner today ($229 from Podium Bike in MI). These are "make specific" hence the H01 model is only for Hondas which I am more than ok with. Just shipped today, so maybe by Thanksgiving I can try it out Smile
2014 CB1100 Deluxe ... Red Smile
I use this:
I use this:
Beer
That would be interesting to witness PB.
Thumbs Up
Thumbs Up
I don't have the part number, but here is the site where I got and it has gone down in price. In addition, there is confirmation that the said cable works on the CB1100 2017 and later models.
[url=https://www.ebay.ca/itm/143465521559?ul_noapp=true]https://www.ebay.ca/itm/143465521559?ul_noapp=true
Looks like indeed year 2017 was a change in diagnostic management for Honda cycles.
equal:2014 cb1100 ex white:pollice su:
Help. Can't find connector on my 2014 CB1100 Deluxe Smile Found red 4-pole connector under left side cover in a wire bundle. It was taped in a bundle. Removed from bundle and removed cap. Connected to my new HealTech OBD unit .... it did not register with the OBD unit. Assume I connected to wrong connector. Connector I used in red one in the middle of the picture.
That is the connector. I had some trouble getting a connection too. Can’t remember exactly what I did and I haven’t connected it in a while, but either getting the program up and then turning on the ignition or ignition first then opening the program did it.
I do know that I could barely get a connection with an old notebook I had that was SLOW and had to use a better PC.
(11-22-2020, 03:31 AM)Lord Popgun_imp Wrote: That is the connector. I had some trouble getting a connection too. Can’t remember exactly what I did and I haven’t connected it in a while, but either getting the program up and then turning on the ignition or ignition first then opening the program did it.
Thanks. Have fairly new laptop so that's not the problem. Will try again and wiggle all connections. If no worky, then will contact HealTech support.
When you open the program, does it make a connection with the ODB device? It should at least do that even if its not plugged into the bike.
(11-22-2020, 03:59 AM)Lord Popgun_imp Wrote: When you open the program, does it make a connection with the ODB device? It should at least do that even if its not plugged into the bike.
If you mean does the Connect button become enabled on the software program, then No it does not. When I plug in the usb cable to my computer I get the windows ring-tone that signifies it recognized a new usb device being plugged in.
Problem is they sent me the wrong OBD Tool version. Looked at the tool case and the model number is K01, eg the Kawasaki version. I ordered the H01 version.
  Another source for plug-in LED flasher unit. FLYTYM_imp 7 628 01-31-2022, 09:53 AM
  Cruise control DougsZ28_imp 12 922 07-27-2021, 05:14 PM
  McCruise Cruise Control cmc1891_imp 28 1,783 07-06-2021, 11:40 AM
Last Post: DougsZ28_imp
   Fuel line connection came undone and left me stranded! Riko_imp 33 3,540 12-04-2020, 12:29 PM
Last Post: 17-CB-002
  Indicator connection Chris Goldson_imp 4 364 04-21-2018, 07:09 PM
Last Post: Chris Goldson_imp
  left control wiring caddy425_imp 2 308 03-26-2018, 12:42 PM
Last Post: caddy425_imp
  Handlebar And Control Alignment Aka Tsubasa_imp 2 245 07-12-2017, 06:38 AM
  Idle Air Control Valve (IACV) dave 12 674 07-23-2016, 02:31 AM
Last Post: LongRanger_imp
   Oil Pressure Sending Unit Tap Ralph_imp 8 626 10-29-2015, 11:05 AM
Last Post: Ralph_imp
  "Headlight Unit" Replacement gmike_imp 2 246 09-04-2015, 12:42 PM
Last Post: gmike_imp
