Another Failed K&N Oil Filter
I still have a couple older K&N oil filters in my lot, and still get a little freaked out when I see this. I have not used one since I read about the first oil leaking here, but had one on my Z900RS at that time. I have used these for years and never had one fail. Maybe I just lucked out and had ones built in a different plant or country.
I use only Honda ones now on my CB's. Still use the K&N oil filters in the Suzukis since they are internal and cannot leak.
(04-15-2021, 04:45 PM)Tev62_imp Wrote: I am always amazed at the force people use to put an oil filter on on YouTube videos. An oil filter really doesn't require a nut on the front but if excessive force wasn't used to tighten it up in the first place I doubt the failure would of happened at all. Still, it is obviously a flawed design. Thank god you had the nouse to realise something was up.
I'm in full agreement. The filter only needs be put on hand-tight, with the o-ring supplying the tension. Oil the o-ring, tighten it by hand (no tools at all), and you need a strap wrench to remove. Even on cars, in 50 years in the car/motorcycle field, I never heard of one backing off by itself.
The nut is useful only at removal, and it wouldn't matter if it did tear then. Tighten it with a wrench, and the spot-weld can tear the cannister.
  Oil Filter dave 12 543 07-26-2026, 02:33 PM
  Pod Air Filter Traumend_imp 15 1,464 03-06-2024, 08:42 AM
  K&N air filter fitment question nikolus_imp 28 3,454 05-20-2023, 09:26 AM
Last Post: Klamathonian_imp
  Fuel filter replacement Mafd2_imp 36 2,842 02-11-2023, 01:54 AM
  Oil filter won’t come off Jgarciajr40_imp 20 1,475 01-01-2023, 09:38 AM
   Oil Filter Options Yata-Garasu_imp 78 7,300 09-28-2022, 08:03 AM
Last Post: Yata-Garasu_imp
  Air filter options - W/ Part #'s PowerDubs_imp 10 901 09-21-2022, 04:02 AM
  Video: oil and filter change Scotty_imp 15 1,166 12-05-2021, 02:43 AM
  Air Filter Change Interval? dave 25 1,880 11-09-2021, 02:18 AM
Last Post: SportsterDoc
  Oil change - filter differences. Mixagon_imp 41 3,226 09-07-2021, 07:44 AM
