Adreani inserts for 2013/2014 ?
That is interesting that you mention the spring rates and going up a little Aussieflyer. I did exactly that on my Triumph Daytona. I went with new fork springs with a heavier spring rate up front along with a fork refurb which involved a very light honing, new seals, bushings and new oil. That gave me a lot more of my compression stroke back and really smoothed out the front end. The forks already had rudimentary cartridge damping units and those were left as is. Although the heavier spring rate does create more work for the damping units I was lucky in that they had a good adjustable range, enough to compensate and the suspension crowd chose the fork oil weight and air gap perfectly.
Before spending a pile on new fork internals I would second Aussieflyer's suggestion of new springs rated for your weight and a fork overhaul. In Ireland a fork overhaul is about €200 parts and labour plus the cost of a new set of springs at around €120. The important thing to remember is springs for your weight, there are an awful lot of people out there changing fork springs and they have no idea why they are doing it or even if the spring rate is different to what they just took out.
  Can a 2013 centerstand be installed on a 2014? WRXer_imp 1 261 11-19-2023, 04:24 AM
Last Post: WRXer_imp
  2013 versus 2014 wheel size Houtman_imp 19 1,602 10-08-2021, 05:11 AM
  Two Brothers M2 - 2013 specific on a 2014? B Api_imp 1 245 06-14-2021, 11:57 PM
Last Post: cj599_imp
  2013/2014 switchgear spartanheed_imp 2 286 04-23-2019, 04:23 AM
Last Post: spartanheed_imp
  Weight of the OEM Wheels on the 2013/2014 std models? misterprofessionality 7 547 04-04-2019, 09:24 PM
  CB1100 2013/2014 REAR WHEEL INTERCHANGABLE? Searcher_imp 5 394 10-20-2016, 12:29 AM
Last Post: Jim_imp
  2013 & 2014 Seat Base the Same ? rocket_imp 8 629 08-17-2016, 09:48 PM
  2013 Optional ABS VS 2014 Deluxe ABS the Ferret 38 2,240 09-04-2015, 03:40 PM
Last Post: LongRanger_imp
