04-26-2021, 07:47 AM
MVK24 , if you put a sign in your bar "free beer tomorrow " they will come every day.
valve adjustment
04-26-2021, 10:10 AM
04-27-2021, 12:52 PM
Decided im gonna do the valves adjustment on my
- 1981 kz440 LTd first (screw and lock nut) - Then 1 of my 1993 Yamaha XJ600 Secas second (25mm shim and bucket) - And then ill check the honda. Watched a few videos and its easy enough. The hard part will be reading the Valve shim chart. Sent from my SM-G965U1 using Tapatalk
04-27-2021, 04:46 PM
(04-27-2021, 12:52 PM)mvk24_imp Wrote: Decided im gonna do the valves adjustment on my The shim charts look busy to start with but then when you have a good look they are actually very straightforward. You just mark your valve clearance as measured Vs the shim size already in place and where they intersect on the table is you new shim size or the note to say in range. Here is me selecting shims from a table for my 1995 Daytona after measuring the gaps and the existing shims. https://youtu.be/l9v68sRz9bs?t=1786 Luckily I can remove the shims without taking the camshaft off as it is shim over bucket. If you have a box of shims to hand it will save a lot of effort as you can change them as you measure them. In my case I didn't so I had to put the old shim back in and order up the correct shims.
04-27-2021, 11:14 PM
(04-27-2021, 04:46 PM)Tev62_imp Wrote:(04-27-2021, 12:52 PM)mvk24_imp Wrote: Decided im gonna do the valves adjustment on my The shim charts look busy to start with but then when you have a good look they are actually very straightforward. You just mark your valve clearance as measured Vs the shim size already in place and where they intersect on the table is you new shim size or the note to say in range. Here is me selecting shims from a table for my 1995 Daytona after measuring the gaps and the existing shims. https://youtu.be/l9v68sRz9bs?t=1786 Luckily I can remove the shims without taking the camshaft off as it is shim over bucket. If you have a box of shims to hand it will save a lot of effort as you can change them as you measure them. In my case I didn't so I had to put the old shim back in and order up the correct shims. Thanks you that clears it up for me, great video tutorial. I was looking at shim kits but they seem to be pretty expensive. What size shims do we have in the CB? If we have the same 25mm size as my 2 yamahas then it might be worth ordered a kit. The XJ forum has a shim pool and I believe its 1 of the moderators. They pitched in for a big kit of shims and whenever needed a member gets the shims they need from him and sends him back the one you didn't need anymore and it keeps the pool going round and round. Sent from my SM-G965U1 using Tapatalk
04-28-2021, 12:56 AM
I think the CB with shim under bucket will be the smaller size unfortunately. Some dealers used to be nice to customers and do free shim swaps but that practice seems to of faded somewhat. I had mis ordered one when I did mine and I put out an ABP for a shim with a bike group I belong too and ended up with several offers which was great. The shim boxes are pretty expensive as you say, I wasn't prepared to splash out that much for the convenience either but then I did have the time.
04-28-2021, 01:37 AM
"Some dealers used to be nice to customers and do free shim swaps but that practice seems to of faded somewhat."
Yup. When I did my Bonneville a while back, I called the two local dealers to ask about swapping shims. One of them answered with "What's a shim?"
04-28-2021, 04:19 AM
(04-28-2021, 01:37 AM)Gone in 60_imp Wrote: "Some dealers used to be nice to customers and do free shim swaps but that practice seems to of faded somewhat." That, ... is so sad.
04-28-2021, 08:07 AM
The ZRX forum has a box of shims that travel from user to user...
I bought a kit when I installed my custom cams- but then discovered that the factory Honda shims come in half sizes compared to the kit. Regardless, even if it didn't- I would have still needed to order shims.. so if I ever adjust again- I will just disassemble, measure, order, reassemble. Thought I was saving time- and I was just wasting $.
05-05-2021, 02:13 AM
Call me cheap, but....
For those of you who have removed your valve covers for valve inspection, were you able to reuse the gasket without any leakage? Might actually take a peek at mine since I'm bumping up on 8,000 miles. I dunno, might be good to have one in the box if needed, but... |
« Next Oldest | Next Newest »
| Valve Adjustment Shims | dave | 13 | 615 |
07-28-2026, 12:49 PM Last Post: MagnaRider |
| Valve Adjustment and Camshaft Removal | dave | 5 | 582 |
03-21-2026, 04:49 PM Last Post: Cormanus |
| Valve Adjustment | dave | 6 | 829 |
08-29-2025, 10:46 AM Last Post: dave |
| Valve Cover Baffle lining ? | bflint | 6 | 878 |
07-26-2025, 11:27 AM Last Post: bflint |
| Valve Adjustment Intervals | CBRider_imp | 32 | 2,660 |
04-21-2025, 02:24 PM Last Post: Jurlie_imp |
| Rear Brake Pedal Adjustment | Gone in 60 | 12 | 1,041 |
04-04-2024, 08:18 AM Last Post: Gone in 60 |
| Valve Adjustment Tolerances - How Far Do You Go? | dave | 14 | 1,433 |
10-18-2023, 09:28 PM Last Post: The Gecko_imp |
| Observed Valve Clearance | Cormanus | 16 | 1,336 |
03-06-2023, 09:03 AM Last Post: Tejas_imp |
| The OBSERVED Valve Clearance thread | Pterodactyl_imp | 162 | 11,560 |
12-27-2022, 08:35 AM Last Post: Cormanus |
| Checking valve clearances | Maturecheese_imp | 74 | 6,029 |
12-11-2022, 12:56 PM Last Post: GoldOxide_imp |
