Instrument Cluster A & B Button Repair
Hey PB, I can find them on the Honda parts fiche easily Wink
(08-11-2021, 12:54 AM)Lord Popgun_imp Wrote: Hey PB, I can find them on the Honda parts fiche easily Wink
MiLord, I acknowledge your thought...3D print out needed Big Grin
(08-10-2021, 10:48 PM)Phadreus_imp Wrote:
(08-10-2021, 08:37 PM)Cormanus_imp Wrote: I'm impressed:
(a) with your diagnosis and repair; and
(b) you survived tripping on the stairs.
Nice work all round.
It takes real talent to trip going up stairs.
Thx Cormanus! Cool
(08-10-2021, 08:56 PM)Houtman_imp Wrote: I am very impressed that you " pinned" the problem so cheaply .
Wah wah wah...it was really more of a MacGyver operation truth be told. Big Grin
Heh, heh - Put on cold weather riding boots, put on the full face helmet, shield closed, and heck, put on the cold weather jacket. Proceed to walk up a full flight of stairs. Smile
Phadreus dateline='nip>k' Wrote: [url=http://cb1100forum.com/forum/showthread.php?pid=302708#pid302708] cut some Round Stock to the correct length, and inserted them into the Cluster. Viola!
Did you put the sticks in exactly as shown in the picture ? It seems the ends were cut with a plier ...
(08-11-2021, 06:48 AM)j3gq_imp Wrote: Phadreus dateline='nip>k' Wrote: [url=http://cb1100forum.com/forum/showthread.php?pid=302708#pid302708] cut some Round Stock to the correct length, and inserted them into the Cluster. Viola!
Did you put the sticks in exactly as shown in the picture ? It seems the ends were cut with a plier ... Good eye, they were in their initial rough cut form when I took the picture. I did cut them with side cuts (it was .080" round stock, mild steel), then ran them across my bench grinder to smooth out, debur the ends. Didn't want the membranes or micro switches damaged.
I have a damaged cluster that I can take apart and send you the rods if you like. Just let me know. From a 2014 bike.
(08-11-2021, 09:38 AM)NHCB1100_imp Wrote: I have a damaged cluster that I can take apart and send you the rods if you like. Just let me know. From a 2014 bike.
I would absolutely take you up on that! Admittedly, I would absolutely prefer factory parts inside. Also, I think I damaged my right turn signal indicator LED in the process. Didn't notice it until I rode today, and noticed LH works fine, RH, no blinky. I'm betting I caused it during my repair process unknowingly. Can't find any indication if it's a 3.5V, 3.7V, 5V...was thinking I could find another PCB somewhere and move one of the LED's over. I'll PM ya!
Good job. From what I recall the pins just fall out when you take it apart, so I can see how they were misplaced on a prior assembly and I guess the guy couldn't be bothered to do the job twice?
I should have a couple of spare pins from a used cluster I broke for parts on my K10 build. Just shout if you want me to post them.
(08-12-2021, 10:23 PM)Ninemeister_imp Wrote: Good job. From what I recall the pins just fall out when you take it apart, so I can see how they were misplaced on a prior assembly and I guess the guy couldn't be bothered to do the job twice?
Thanks Nine! I think NHCB1100 (John) is fixing me up with everything I need. Will be nice to have the factory designed parts back in place. I'll feel like everything is right in the Universe again. Smile
I wish I knew why the original owner disassembled the cluster in the first place...very curious.
There are some good, kind and generous people on this forum.
  Instrument Cluster Needles Cormanus 14 973 02-04-2026, 02:29 PM
  Repair manual for 2017 RS TheLegend 21 2,398 07-10-2025, 05:58 PM
  Hibeam and hibeam flash button acting up. Jgarciajr40_imp 7 762 04-01-2024, 08:13 AM
  flat repair. ‘17 CB1100 EX sleeper_imp 15 1,195 08-29-2022, 06:31 AM
  Turn Signal Switch and Horn Button Locations pekingduck 26 1,962 07-12-2022, 08:04 PM
Last Post: tommymck
  Service and Repair Manual alexzanutto_imp 5 651 02-26-2022, 10:02 PM
Last Post: alexzanutto_imp
  Loose Instrument Panel / cluster ecka00_imp 12 775 06-07-2019, 06:50 PM
Last Post: Bazbro_imp
  Buzzing Instrument Cluster White Dog_imp 41 2,409 09-17-2018, 09:32 PM
  Lower Cover instrument panel linuxology_imp 5 451 11-01-2016, 10:19 AM
  Instrument panel cover removal help Stratus_imp 22 1,285 07-03-2015, 03:15 AM
Last Post: Redbird_imp
