Small quiz; brakes are dragging.
(11-29-2021, 02:11 AM)Lord Popgun_imp Wrote: iPad at home, Windows at work. All I see is a sentence or 2 then a big blank space.
I'll try my Phone. iPhone 6+. Oldie, but works good!
Same. Have to remote from my iPad to my desktop to see the content on those posts.
So Popgun i think this is the first time you miss out on a video clip, i am trying to work out what works for your ipad/windows;
Can you see the "thanks pdedse" video but not the "thanks Cormanus" one?
In other words does the link in red work but not the link with the player in it ?
Try a non-native and higher capable browser than the default iPad offering?
Example: Chrome is typically reliable.
Max and Au₂O₃, us Apple users can see the red link, but not the embedded video. On a Mac desktop, the embedded video displays in Chrome but not Safari, on an iPad neither browser will display the embedded video.
(11-29-2021, 02:40 AM)max_imp Wrote: So Popgun i think this is the first time you miss out on a video clip, i am trying to work out what works for your ipad/windows;
In your "thans Pd" I see the red link and can click on it and view it.
In the post above that by Pd I one see the words remove and install with big blank spaces between them.
In the thanks Cormanus post all I see is Lets try this (or whatever you said) a big white space, then Oh Boy!
(11-28-2021, 07:54 PM)max_imp Wrote: Thanks Cormanus, let's try;
Oh boyBanana
This was a most-enlightening video, using the boards as bead breakers, as was the "adjustable" 2x4 framework against the wall in tat manner - simply genius. I've changed hundreds of tires, and being able to use your knees to keep the tire bead in the valley is key. Worst part for me is always feeding the valve stem through the rim. Ouch! Don't like working on the ground though.
One thing though. The point he made about the red (or yellow, or white) dot/circle) was that it is the heavy spot on the tire (not true), and must always aligned next to the valve stem to compensate for the weight of the metal removed where the valve stem hole is drilled.
He is correct in that it should be aligned there, but not because it is the heavy spot. It is actually the spot that is 180 degrees across from the heaviest spot, although it it is usually referred to as the lightest spot (splittin' hairs here).
But I wondered if there was any validity to his assertion about removed metal, so, just for fun, I weighed some stuff, with results in the pic below. In the lower right scale is a trio of 1943 steel pennies, any one of which is larger and thicker than the hole in a steel rim.
(11-28-2021, 02:23 PM)max_imp Wrote: The longest day HoutmanBeer
The solution was very simple; i knew something was wrong but everything looked in place, except....
The wheel ROTATION was backwards so the pads were bedded in on the disks but now did not match the pattern of wear.
Simple but interesting effect, once the wheel was turned around everything was fine as usual.
Dave i just use 3 large 600 mm. tyre irons, you can see them in the middle picture and plastic rim protectors in between the rim.
With the cable ties on the tire and lube on the working surfaces it was easy to get the tire back on the rim, once on you just remove the cable ties with a stanley knife to move the locking tabs back to unlock the ties and re-use them next time, place the tire so there is no force on the tire and inflate until the beads set.
I use a 5 liter garden pressure weed sprayer ( the orange thing in the last picture ) and a clear plastic hose that just fits the sprayer and the valve, i clamp the hose, pump up the pressure in the tank and release the clamp to quickly get the pressure inside the tire and it seats on the rim, done the same thing last time with a co2 cartridge, same effect.
Max, trying to think about this without overthinking it, but going to anyway. Aside from different width axle spacers, there is another anomaly. The wheels for ABS and non-ABS 2013 models are different, most likely because the ABS model has a flat steel pulsar ring bolted under the right disc.
So it's possible the disc on the right is not supposed to be perfectly centered on one model or the other, compared to the left side. We're talking 2mm
The ABS model also has a different right-side caliper and fork leg, so any alignment issue could be taken up in a variety of ways.
Anyway, it's corrected and not an issue.
Thanks PD and all others for some very good tips.
Cormanus i think if i am going to post any more links in the future i will post both systems and thanks for the explanation, made perfect sense to me.
Chris Harris has some nice tips but as most of the posters makes mistakes too, by reasoning most can be corrected.
One of those is the effect of scoring the alu rim with a non protected tire iron, not good with moisture and salt on the road over time but refreshing to see the bead breaking/setting procedure.
Individual methods vary with skill , available tools and frequency of tire changes.
Wondered too if the removed metal would equal the weight of some valves and had my doubts about this claim, appreciate your explanation how that works, a fine detail for sure
The main reason for posting was to jog someone's memory when they made the same mistake, give the symptom and the explanation why, similar to " when the neutral light dims during startup its time to replace the battery"
Thanks all !
Max , I am sorry that I accused you of drinking the wrong beer ! just stick to the good old Heineken and think of Holland.
Max, posting both the embedded video and a link would be a big help to Apple users. I hope, though, it will not be an enduring problem and will be fixed with an update of Mac OS, iOS and iPadOS. Interestingly, it also affects photo screen savers which no longer display properly. I'll try to remember to post if/when it's fixed.
(11-28-2021, 03:39 PM)pdedse_imp Wrote: This might be the idea:
Install
Removal
Wow! I learn something new every day! I've been changing tires for almost 50 years and I have never seen this tie-wrap method used. I was shocked at how easily this appeared.
  Big Feet, Big Shoes, Small shifter MagnaRider 8 475 04-17-2026, 12:13 AM
Last Post: LucienLeFranc
  Front Brakes ain't what they used to be misterprofessionality 11 1,356 05-09-2025, 09:10 PM
Last Post: Whoops
  What's the function of these small holes beside injector zirconxi_imp 5 539 03-02-2024, 03:58 PM
  Bleeding brakes with ABS j3gq_imp 31 2,207 12-22-2021, 08:31 AM
  2014 CB 1100 Front Brakes troubleshooting mustang462002_imp 23 3,084 11-17-2021, 06:53 AM
Last Post: max
  Bleeding brakes (CB1100A non-ABS) tod.branko_imp 5 526 09-20-2021, 07:43 AM
  2014 CB1100 Deluxe No front brakes Roger the shrubber_imp 16 1,028 08-05-2021, 02:01 AM
  brakes simulating T.Rex j3gq_imp 8 772 10-12-2020, 02:49 AM
  Rear brakes... what I did wrong and where to go now? Inhouse Bob 32 2,253 07-11-2020, 01:37 AM
  Linked Brakes Cormanus 11 1,235 12-11-2019, 08:10 PM
Last Post: jtopiso_imp
