Frequency of chain oiling?
Xring chains are so good nowadays all you really lube is where the chain contacts the sprockets. I dab a little axle grease on the inside of about 3 links. It will distribute and a can of grease lasts about 20 years. Clean it a couple of times a season with WD40 and grease it up. I get well over 20k out of my chains and that's on hyperbikes. This CB chain may last 30k.
Sounds like the guy wants to sell you chain lube on a consistent basis
What do you guys use to clean the chain?
Just a wipe-down with a clean rag, or use something like WD40 (I see that mentioned above)?
(05-17-2015, 11:36 AM)Townie_imp Wrote: What do you guys use to clean the chain?
I use kerosene. It's a lot less expensive to give the chain a good soaking with kerosene than WD-40. I've got a chain brush, but it's really not necessary unless the chain is heavily caked with lube sludge. If you're cleaning it fairly regularly (I do it every few thousand miles), just some heavy rags will do the job.
I oil my chain every 500mi. But the chain on this bike is amazing, because I have 2200 miles on the original chain and it still has never needed to be adjusted yet. Celebrate Being a brand new chain I would have thought some stretching would have occurred in the first 500 miles. Who needs shaft drive anyway!
Almost 12k on Eric's CB, yet to be adjusted.
Almost 12k adjusted once at 8400
(05-22-2015, 08:03 PM)Motogeezer1949_imp Wrote: Almost 12k on Eric's CB, yet to be adjusted.
Wow, I guess 2200mi is nothing to brag about with this chain. Like I said before, who needs shaft drive.
http://www.r3-forums.com/forum/530-oil-l...-life.html
Posts #7 and #8.
I use this stuff.
https://www.canadasmotorcycle.ca/tirox-c...brush.html
The cleaner isn't really that special, but that spiral brush it comes with works a treat -- you basically just hold it and spin the wheel and your chain gets spotless. Their chain lube also works really well.
  Oiling cylinders for winter storage? Searcher_imp 5 537 01-26-2023, 08:33 AM
Last Post: ichiban_imp
  Chain Lube Type and Frequency? Nappi185_imp 29 1,846 09-02-2017, 05:10 AM
Last Post: Nortoon_imp
  Oiling chain 1100rider_imp 57 5,777 07-29-2016, 05:21 AM
Last Post: flynrider
  Chain lube frequency? Michael252_imp 41 2,657 02-13-2014, 10:52 AM
Last Post: ride4now_imp
