05-16-2017, 09:57 AM
hd..I have never heard of it. Interesting though
Need recommendation for throttle lock
05-16-2017, 11:09 AM
05-16-2017, 11:15 AM
i thought it looked interesting. They're all a bit compromised, though, compared to a decent cruise control. I find it really hard to get my throttle lock exactly right. Either the bike speeds up or slows down and the slightest slope or change in air pressure can make a difference.
05-16-2017, 11:19 AM
(05-16-2017, 11:15 AM)Cormanus_imp Wrote: i thought it looked interesting. They're all a bit compromised, though, compared to a decent cruise control. I find it really hard to get my throttle lock exactly right. Either the bike speeds up or slows down and the slightest slope or change in air pressure can make a difference.I have a H-D touring bike that has a true cruise control and it really helps on long streches of highways. Sent from my VS990 using Tapatalk I liked this design because it doesn't use space on the grip. When I installed the heated grips I realized that they are shorter than the Honda stock grips. Sent from my VS990 using Tapatalk
05-16-2017, 11:26 AM
Oh, yes. I would find driving my car on the highway much less agreeable without the cruise control. While I try to avoid highways on the bike, there are occasions when they're unavoidable as well as straight, fast roads where an electronic cruise control would be a wonderful thing.
05-16-2017, 11:42 AM
(05-16-2017, 11:26 AM)Cormanus_imp Wrote: Oh, yes. I would find driving my car on the highway much less agreeable without the cruise control. While I try to avoid highways on the bike, there are occasions when they're unavoidable as well as straight, fast roads where an electronic cruise control would be a wonderful thing.I honestly don't like highways but I only have weekends and vacation days to do longer rides and sometimes you have to use them to get to the nice roads. I am participating for the second year on this sort of rally: http://www.tourofhonor.com Honoring military, police, firefighters and first responders. It is really a nice group of riders all over the country. And cruise control is almost a must for me. Maybe I should make a thread to let everyone know about it. Sent from my VS990 using Tapatalk
05-16-2017, 12:14 PM
I have had this Madco cam lock for a long time. It came on a used bike I bought many years ago. I just keep taking it off and putting it on the next bike. It works great and is very simple. It has a little tool to adjust the tension just right.
![]() ![]() Works on every Honda I have had with 1 inch handlebars. Did NOT work on my CB1100 because I had heated grips. I had no idea they are pricey lil buggers ( I got mine for free) til I googled the link: http://www.madcorider.com/cam-lock_honda_cruisers.html They almost look stock?
05-17-2017, 12:19 AM
(05-16-2017, 12:14 PM)Ole_imp Wrote: I have had this Madco cam lock for a long time. It came on a used bike I bought many years ago. I just keep taking it off and putting it on the next bike. It works great and is very simple. It has a little tool to adjust the tension just right. Thanks Ole! It does look like a good option and doesn't change the stock look as well. I guess since it is a single piece you have to remove the rubber and slide it in, is that right? I don't understand why they mention on their website that it does work with heated grips.
05-17-2017, 01:00 AM
Yep, remove grip and slide it on, reglue grip. I remove grips with WD40, a long thin screwdriver, and compressed air. Am unsure why it did not fit with heated grips on the CB. I provided my cam lock to the dealer mechanic before he put the heaters on and all he told me was "it was a no go"
sorry I can't help you more
05-17-2017, 01:10 AM
(05-17-2017, 01:00 AM)Ole_imp Wrote: Yep, remove grip and slide it on, reglue grip. I remove grips with WD40, a long thin screwdriver, and compressed air. Am unsure why it did not fit with heated grips on the CB. I provided my cam lock to the dealer mechanic before he put the heaters on and all he told me was "it was a no go"Not a problem, thanks. Sent from my VS990 using Tapatalk |
« Next Oldest | Next Newest »
| Helmet Lock? | Wagonpeddler_imp | 4 | 372 |
05-31-2022, 08:05 AM Last Post: Wagonpeddler_imp |
| Coin in right side of throttle body | slackerdeluxe_imp | 10 | 626 |
04-10-2022, 02:37 AM Last Post: Nachodaddy |
| Givi Tank Lock | Adventure boy_imp | 8 | 577 |
07-08-2020, 07:09 AM Last Post: tsmetjen_imp |
| 30 second lock out | 562loosenoodle_imp | 1 | 227 |
03-31-2019, 09:53 AM Last Post: Cormanus |
| Malfunctioning ignition lock | geosar_imp | 25 | 1,899 |
02-01-2019, 11:41 PM Last Post: GoldOxide_imp |
| Steering Lock | DarthKickass_imp | 3 | 812 |
08-10-2018, 09:48 AM Last Post: flynrider |
| Windshield Recommendation | jdinaz_imp | 13 | 974 |
11-04-2017, 10:05 AM Last Post: 736cc_imp |
| Best disc and helmet lock | pittycheria_imp | 6 | 923 |
05-14-2017, 12:30 PM Last Post: Cormanus |
| Anti lock brakes | Mikestib1_imp | 29 | 2,190 |
01-08-2017, 02:54 PM Last Post: flynrider |
| CB1100 "U" lock, One key type. Part number?? | Roger the shrubber_imp | 7 | 509 |
12-06-2015, 07:34 AM Last Post: Django |
