Steering Lock
I can not seem to get the steering lock to engage. Is their a trick? I push and apply just a little pressure while slowly easing the handlebar but it just won't engage.
Turn bars all the way to the left, push key straight in and turn key counter clockwise maybe 1/4 turn
Assume you have no aftermarket device installed that prevent bars from full rest position ( wind shield brackets/holders that may rest against gas tank and obstructing desired bar position at full rest)...as a simple advice.
Thumbs Up
Just tried this on mine. Are you pushing the key down? The key needs to be pushed down about 1/4" and turned counter clockwise to engage the lock mechanism. The key won't turn until the bars are in the full left position.
  Helmet Lock? Wagonpeddler_imp 4 397 05-31-2022, 08:05 AM
Last Post: Wagonpeddler_imp
  Givi Tank Lock Adventure boy_imp 8 617 07-08-2020, 07:09 AM
Last Post: tsmetjen_imp
  30 second lock out 562loosenoodle_imp 1 228 03-31-2019, 09:53 AM
  Malfunctioning ignition lock geosar_imp 25 1,988 02-01-2019, 11:41 PM
  Need recommendation for throttle lock Jim_imp 36 2,279 07-18-2018, 12:37 AM
Last Post: Nortoon_imp
  Best disc and helmet lock pittycheria_imp 6 927 05-14-2017, 12:30 PM
  Anti lock brakes Mikestib1_imp 29 2,288 01-08-2017, 02:54 PM
Last Post: flynrider
  Steering shake. Tezza_imp 23 1,298 10-28-2016, 12:29 AM
Last Post: Red Baron_imp
  Steering Head Shake and Bar Grip. Pterodactyl_imp 16 1,035 10-03-2016, 03:52 AM
Last Post: Rolls_imp
  CB1100 "U" lock, One key type. Part number?? Roger the shrubber_imp 7 534 12-06-2015, 07:34 AM
Last Post: Django
