Malfunctioning ignition lock
Recently I have been experiencing difficulty in turning the ignition lock on and also pulling the key from the lock. I have injected graphite material designed to lubricate the lock without improvement.
Has anyone experienced this and does any one have a suggestion regarding a repair.
Thank you
George
Arizona
By any chance has your key bent? My did which caused a similar problem.
That would have been my question as well. HAve you tried another key to see if it's the same?
Same problem for me since new. I put a bit of WD-40 in there. Seems to have helped.
Thank you for the help. I do not believe I bent the key but cannot rule it out. If I ever find my spare key I will try it out. WD40 is my next attempt I squirted lithium grease in the lock with no help.
Thank you again
George
Arizona
(01-31-2019, 12:16 PM)geosar_imp Wrote: Thank you for the help. I do not believe I bent the key but cannot rule it out. If I ever find my spare key I will try it out. WD40 is my next attempt I squirted lithium grease in the lock with no help.
Thank you again
George
Arizona
For electrical-related components, if you have to inject anything, consider silicone spray lubricant.
The issue here is the mechanical operation of the ignition key and lock. But silicone spray will be in my list of things to try.
Thank you
George
For this case, silicone may be a better choice over WD-40. In any case, your call.
Not sure if it is possible, but also peek down the switch to determine if there is any plastic "switch debris" or other possible foreign matter there. Give it a blow with some air pressure? (wear eye protection)
We use talcum powder to grease locks. Those liquids tend to glue after some time.
(01-31-2019, 08:38 PM)Django_imp Wrote: We use talcum powder to grease locks. Those liquids tend to glue after some time.
Silicone spray lubricant does not.
  Key won’t go to ignition Presasx2_imp 17 1,354 09-27-2023, 07:49 PM
  Helmet Lock? Wagonpeddler_imp 4 400 05-31-2022, 08:05 AM
Last Post: Wagonpeddler_imp
  Givi Tank Lock Adventure boy_imp 8 619 07-08-2020, 07:09 AM
Last Post: tsmetjen_imp
  30 second lock out 562loosenoodle_imp 1 231 03-31-2019, 09:53 AM
  Steering Lock DarthKickass_imp 3 831 08-10-2018, 09:48 AM
Last Post: flynrider
  Need recommendation for throttle lock Jim_imp 36 2,295 07-18-2018, 12:37 AM
Last Post: Nortoon_imp
  Frequent/occasional difficulty inserting key in ignition? jerrycon_imp 23 1,498 10-15-2017, 07:57 PM
Last Post: Rocky_imp
  Best disc and helmet lock pittycheria_imp 6 936 05-14-2017, 12:30 PM
  Anti lock brakes Mikestib1_imp 29 2,303 01-08-2017, 02:54 PM
  CB1100 "U" lock, One key type. Part number?? Roger the shrubber_imp 7 538 12-06-2015, 07:34 AM
Last Post: Django
